Mooncool POP
85/100
7 Hours
60 Miles
85 Nm
48V 13.6Ah
67 lb
We have read all expert and user reviews on the Mooncool POP. In summary, this is what cyclists think. Published Jul 31, 2026 by Jordan Grimes.
  • Mooncool’s POP comes with fenders, lights with brake activation and turn signals, a bell, a bottle cage, and cargo netting.
  • Testers say the turn signals and brake light are brighter than average.
  • The rear rack is MIK-compatible and supports 59lb.
  • Reviewers praise the responsive throttle and pedal assist.
  • Experts enjoy the smooth, natural power delivery.
  • A 305lb tester praises the climbing power, overcoming hills using only the throttle.
  • Testers say the suspension does a good job of smoothing out rough roads.
  • Experts say the hydraulic disc brakes offer ample stopping power.
  • The 3" tires grip well on hard-packed gravel.
  • The frame has a built-in carry handle, and reviewers say it folds quickly.
  • The color display is readable in bright sunlight.
  • This bike is offered in five colorways.
  • A 305lb reviewer gets just 16.1 miles of range using maximum assist and throttle on a hilly route.
  • Mooncool publishes conflicting specs for range, peak power, and rider fit. A 6'0" tester is at the seatpost's maximum extension.
  • The POP is bulkier than average when folded.
  • The turn signals don't self-cancel, and they don’t make any sound.
  • The folding stem rattles over rough ground, according to a tester.
  • One expert finds play in the kickstand mounting and recommends checking the bolts.
  • The 2A charger returns lengthy charging times.
The Mooncool POP is the brand’s first two-wheeler, a folding utility bike with a 750W motor and full suspension. Both reviewers rate the bike highly, praising the instant throttle response, smooth pedal assist, comfort, and strong climbing performance. The meager range, slow charging, and weight count against this bike, as do the reports of a rattling stem and play in the kickstand mount. Disappointingly, Mooncool's website also lists several conflicting specs. From early testing, the POP seems a reasonable option in this segment, but it faces strong competition from the Velotric Fold 1 and Lectric XP4.
87/100 based on 2 scored reviews
IMBruceECLECTIC
Mooncool POP New Model Folding E-Bike That Delivers Great Value! Live Electric Bike Life!
If you wanted to improve this… give the front fork 80mm of travel with adjustment, and make the rear shocks a little bit softer for lighter riders. It’s a good bike.
Alex "Buggs" Marentes
I Took the Mooncool POP Folding E-Bike Into a Dinosaur Arroyo!
When I saw that it was a 3″ wide and I’m used to riding 4″ fat tires, I thought it might be an issue, but it’s not. It’s actually doing pretty good.
Mooncool POP in comparison to averages
