Heybike Hybrid Review
Our verdict
The Heybike Hybrid is a step-through commuter e-bike that Heybike calls its longest-range commuter. At maximum assist in Sport mode, it covered 32.45 miles, above the average for the commuter e-bikes we've tested, at the highest average speed in our comparison group. It stopped from 20 mph in 17.5 feet, the best brake result in the group, and climbed the steep hill second-fastest. Assist is well tuned, the ride is comfortable and stable at top speed, and every commuter accessory is in the box. The main disappointment is the misleading spec sheet; that aside, Heybike's Hybrid is easy to recommend.
- Shortest stop in the group: 17.5 ft
- Second-fastest steep climb in the group: 2:21
- 32.45 miles of range at max assist
- Switchable torque and cadence sensing, both well tuned
- Quietest motor we have measured: 60.9 dB(A)
- Comfortable and stable at top speed
- Fenders, rack, lights, signals and horn included
- Throttle runs to 27.1 mph in Sport mode
- Range is 32% of the 100-mile claim
- Heavy for a commuter at 70.4 lb
- Slowest throttle run in the group: 10 s
- Least efficient in the group: 26.6 Wh/mi
- Rack stamped 60 lb, not the claimed 66 lb
Claimed vs. measured
Heybike sells the Hybrid on range ("Up to 100 Miles") and its Class 2/3 switch. We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
| Claim | Heybike says | We measured | Verdict |
| Top speed | 28 mph | 27.1 mph (GPS) in Sport mode | ✓ Verified |
| E-bike class | Class 2 (Eco) or Class 3 (Sport), switchable | In Sport mode the throttle keeps pulling past 20 mph, to 27.1 mph | ✗ Misleading |
| Weight | 69 lb | 70.4 lb as shipped | ≈ 2% over |
| Range (max claim) | Up to 100 mi (155 lb rider, PAS 1) | 32.45 mi at max assist in Sport mode | ✗ 32% of claim |
| Rear rack capacity | 66 lb | The rack itself is stamped 60 lb | ✗ Stamped 60 lb |
| Fits our tester (6'0", 33" inseam) | 6'0" is inside the claimed range | Yes, with seatpost travel to spare | ✓ Yes |
| Claimed height range accuracy | An 11" span of rider height on 7.3" of seatpost travel | (11" − 2") ÷ 7.3" = 1.2×, inside our 2.0× limit | ✓ Verified |
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
| This bike |
Lectric XPress 750 |
Velotric Discover 2 |
Aventon Level 4 REC |
| BikeRide Score | 87 | 84 | 93 | 93 |
| Best price | $1,199.00 | $1,299.00 | $1,799.00 | |
| Motor | 750W rear hub (1,200W peak) | 750W rear hub | 750W rear hub (1,100W peak) | 750W rear hub (1,440W peak) |
| Battery | 864 Wh | 672 Wh | 706 Wh | 733 Wh |
| Range tested (max assist) | 32.45 mi | 28.36 mi | 30.34 mi | 44.20 mi |
| Gradual hill climb | 3:08 | 3:04 | 3:08 | 3:02 |
| Steep hill climb | 2:21 | 2:22 | 2:43 | 2:13 |
| 0–20 mph (throttle) | 10.0 s | 8.0 s | 9.0 s | 7.0 s |
| Brake 20–0 mph | 17.5 ft | 20 ft | 18 ft | 22 ft |
| Measured weight | 70.4 lb | 62.8 lb | 69.0 lb | 69.3 lb |
| Payload | 440 lb | 330 lb | 371 lb | 300 lb |
| Top speed | 27.1 mph (GPS-verified) | 28 mph | 28 mph | 28 mph |
| Torque (claimed) | 75 Nm | 85 Nm | 75 Nm | 80 Nm |
| Charge time | 6 h | 7 h | 4.9 h | 5 h |
| Suspension | 100 mm fork, preload + lockout | 80 mm coil fork | 80 mm hydraulic coil fork | 80 mm coil fork + 50 mm suspension seatpost |
| Drivetrain | 8-sp Shimano Altus | 7-sp Shimano Tourney | 8-sp Shimano Altus | 8-sp Shimano Altus |
| Tires | 27.5×2.4″ Kenda | 27.5×2.1″ Chaoyang | 27.5×2.4″ Kenda | 27.5×2.2″ Kenda |
| Frame | Aluminum, step-through | Aluminum | Aluminum, step-through | Aluminum |
| Assist sensor | Torque + cadence, switchable | Torque | Torque + cadence (via app) | Torque + cadence |
| Water rating | IPX5 bike, IPX6 electrical | IP65 | IPX6 | IPX5 bike, IPX6 components |
| Certification | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 |
Who should buy the Hybrid
We believe the Heybike Hybrid is a good choice for:
- Commuters who want range and the accessories in the box. 32.45 miles at maximum assist, above the commuter average, with fenders, rack, lights, signals and a horn fitted (accessories).
- Riders living in hilly areas. The steep climb took 2:21, second-fastest in the group, and the brakes stopped it in 17.5 feet, the best in the group.
- Those who can't decide between torque and cadence sensing. The Hybrid has both, each well tuned, switchable from the bars while riding.
Who should NOT buy it
- Anyone who needs a legal Class 3 e-bike. In Sport mode the throttle pulls to 27.1 mph, where Class 3 allows 20 mph, so it won't comply in most places.
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, a verified weigh-in and a timed assembly. Every result is stored in our database and shown against similar bikes and against the 88 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
- Tester
- 6'0", 33" inseam
- Rider + gear
- 200 lb
- Weather
- 60–65°F, clear
- Wind
- ≤ 6 mph
- Tires
- 40 psi
- Battery
- 100% within 12 h of test
- Speed limit
- Sport mode as shipped: 28 mph pedal assist, throttle ran to 27.1 mph
The Hybrid ships with a Class 2/3 switch.
Score breakdown — how the 87 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the Hybrid lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
6 tests · 3 ratingsAcceleration 0–20 mph
MeasuredWe measured 7 seconds to 20 mph on maximum pedal assist and 10 seconds on the throttle alone, the slowest throttle run in this comparison group, though it builds speed steadily without being jerky. Against the 750W hub-motor e-bikes we have tested, it is slightly slower than average on the throttle (9.6 s) and a second quicker on pedal assist (8.1 s).
Climbing Test 1: Gradual Hill
MeasuredOn the gradual hill (0.99 miles at up to a 6% grade) the Hybrid finished in 3:08 at an average of 18.7 mph with the 20 mph cap in play, level with the Velotric Discover 2 and mid-pack. Uncapped in Sport mode, the Hybrid climbed it in 2:30 at a 23.1 mph average.
Climbing Test 2: Steep Hill
MeasuredOn the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the Hybrid reached the top in 2:21 at an average of 16.7 mph. Only the Aventon Level 4 REC (2:13) was quicker in this group; the others were slower. The 750W hub-motor e-bikes we have tested average 2:28 here.
Top speed and speedometer accuracy
MeasuredWe clocked a GPS-verified 27.1 mph against Heybike's 28 mph claim. At a true 20 mph, the display read 21 mph, a 5% overread. In Sport mode, the throttle doesn't cut off at 20 mph but keeps pulling to top speed. Class 3 rules allow only pedal assist above 20 mph, so Sport mode won't comply in most places. Eco mode is true Class 2 with nearly identical acceleration.
| Check | Reference | Result | Verdict |
| Top speed, Sport mode | Claimed 28 mph | 27.1 mph (GPS) | ✓ Verified |
| Throttle cutoff, Sport mode | 20 mph under Class 3 rules | Throttle pulls to 27.1 mph | ✗ Not Class 3 |
| Speedometer at a true 20 mph | 20.0 mph (GPS) | Display reads 21 mph | ✓ +5% |
Class 3 e-bikes are limited to 28 mph on pedal assist and 20 mph on the throttle. Many trails and multi-use paths restrict Class 3 access, so check local rules before riding there, and ride in Eco mode where Class 2 is the limit.
Motor noise
MeasuredMeasured indoors with the rear wheel spinning unloaded at 20 mph, the Heybike-branded hub registered 60.9 dB(A), the quietest result of the 7 e-bikes we have measured this way and about 7 dB below their 68.0 dB(A) average. Out on the road the motor stayed quiet under heavy load too.
Assist engagement and cutoff
MeasuredThe Hybrid has both a torque sensor and a cadence sensor. Both are well tuned, and you swap between them from the bars while riding. Torque mode responds instantly, with no measurable delay (0 crank revolutions), and scales with how hard you pedal. Cadence mode takes about half a crank rotation to wake up, then delivers steady power regardless of your input. The five assist levels can be customized in the app.
Range and Charging
4 tests · 2 ratings · 6 factsRange Test 1: Max Assist (Sport mode, highest assist level)
MeasuredHeybike claims up to 100 miles. On our standard loop, in Sport mode at the highest assist level with a 200 lb rider, the Hybrid lasted 32.45 miles with 1,489 feet of climbing at 18.9 mph. That is fourth in the comparison group but above the 30.7-mile commuter average. The battery gave full power until roughly the last third, then tapered to stretch the remaining miles, which we noticed only on hills.
Range vs. claimed
DerivedHeybike claims up to 100 miles, from a 155 lb rider in the lowest assist level. The Hybrid's 32.45 miles at maximum assist is 32% of the claim, outside our tolerance, but we did not run our medium-assist test, where the bike would compare more favorably. Either way, the Hybrid offers plenty of range for the average commuter.
Efficiency
DerivedAt 26.6 Wh per mile the Hybrid is the least efficient bike in this comparison group and among the five least efficient commuter e-bikes we have tested, well above the 21.7 Wh/mi commuter average. The 18.9 mph average speed of our run, the fastest in the group, is part of the explanation, alongside the relatively high weight for the category.
Charge time
CalculatedThe 48V 18Ah pack charges on the included 3A charger. By our calculation a full charge takes around 6 hours (18Ah divided by the charger's 3A output). That is a touch quicker than the 6.3-hour average across our database.
Fact checkThe 48V 18Ah pack (864 Wh) is the largest in Heybike's commuter lineup. It locks into the down tube, comes out for charging indoors, and weighs 11.2 lb on our scale. The battery is certified to UL 2271 and the electrical system to UL 2849. The electrical components are rated IPX6, the bike as a whole IPX5.
Braking and Safety
2 tests · 2 ratingsBrake test: 20 to 0 mph
MeasuredThe Tektro HD-E3520 two-piston hydraulic discs with 180 mm rotors brought the Hybrid from 20 mph to a complete stop in 17.5 feet. That is an excellent result: the best in this comparison group, and the second-shortest stop of the 23 commuter e-bikes we have tested, tied with the Fiido Nomads and behind only the Rad Power Bikes Radster (16.5 ft). The commuter average is 19.9 feet.
Lights, signals, and visibility
MeasuredThe Hybrid comes with a headlight, a rear light with brake activation and turn signals, and a horn. On our center-beam measurement the headlight put out 242 lux at 15 feet, well below the 873 lux average of the e-bikes we have measured.
Ride Quality and Handling
1 descriptor · 8 ratingsRiding the Hybrid
The Hybrid is heavy for a commuter e-bike, and you notice the heft when you lift it or pedal without assistance. We found the bike very comfortable throughout testing: with the adjustable handlebar set at a 10-degree angle we had a nice straight-backed riding position, the Hybrid feels solid and stable cruising at its top speed, and it corners well for its size and weight.
One of the Hybrid's most notable ride characteristics is the motor's tuning. The throttle builds speed steadily from a stop without being jerky, and the two sensor modes offer distinct performance: torque mode responds instantly and scales with how hard you pedal, while cadence mode wakes up after about half a crank rotation and then delivers steady power regardless of your input. Swapping between them while riding is quick, and the motor stays quiet under heavy load.
Stability at top speed
RatedOn our stability run we ride the bike straight, take our hands off the bars to check for shimmy, shift our weight, corner, and deliberately shake the bike to see whether we can start a wobble or a wander.
Comfort, suspension, and vibration
RatedSuspension comes from a 100 mm fork with preload adjustment and a multi-stage lockout. It is typical for this price point and works perfectly well for normal urban riding once it is adjusted properly, but don't expect it to handle big hits. A wide comfort saddle, lock-on ergonomic grips and the upright position do the rest.
Riding position
DescriptorWhere the Hybrid sits on the spectrum from fully upright to fully aggressive. With the adjustable bar at a 10-degree angle, the position is straight-backed:
Fit and Sizing
2 measurements · 2 checks · 2 ratingsTrue to size?
VerdictYes, as far as we can tell. Heybike says the one frame size fits riders from 5'3" to 6'2", an 11-inch span served by 7.3 inches of saddle-height adjustment (31.5" to 38.8" from the ground, measured on our test bike). At 6'0" with a 33" inseam, Scott found a comfortable position with room left to extend the seatpost, so the top of the range looks realistic.
| Measurement | Heybike claims | We found |
| Rider height range | 5'3"–6'2" | Realistic at the top end for our 6'0" tester, with seatpost to spare |
| Saddle height, ground to top of saddle | 31.5"–38.8" | 7.3" of adjustment, measured on our test bike |
| Fits our tester (6'0", 33" inseam) | Inside the claimed range | Yes, with the seatpost short of full extension |
| Claimed height range accuracy | 11" span on 7.3" of travel | (11 − 2) ÷ 7.3 = 1.2×, inside our 2.0× limit |
| Standover | Step-through | 18.1" (460 mm), low and easy |
| Our verdict | One size fits 5'3"–6'2" | Realistic |
Cockpit adjustability
RatedThe stem is angle-adjustable and the seatpost has 7.3 inches of range, so there is real scope to tune the position. We set the bar to a 10-degree angle and got a nice straight-backed posture.
Build and Components
1 test · 6 ratings · factsWeight, verified
MeasuredHeybike claims 69 lb. Our scale read 70.4 lb as shipped, with the fenders, rack and lights fitted, 1.4 lb (2%) over the claim and just outside our 1.5% tolerance. The Hybrid is heavy for a commuter: second-heaviest in this comparison group and 4.5 lb above the 65.9 lb average of the commuter e-bikes we have weighed.
RatedThe 6061 aluminum step-through frame comes in one size and carries the battery inside the down tube. Our bike arrived well packaged and without damage. What you won't find on the frame is a bottle cage mount.
Drivetrain and shifting
RatedThe drivetrain is a Shimano Altus 8-speed with a 48t chainring and a 12–32t cassette, worked by a trigger shifter. Stopping comes from Tektro HD-E3520 hydraulic disc brakes with 180 mm rotors.
Tires and accessories
RatedThe 27.5"×2.4" Kenda Kwick Seven.5 Sport tires have reflective sidewalls, roll quickly and grip well on dry pavement and light off-road trails. For accessories you get front and rear fenders, a rear rack (stamped 60 lb), a headlight, a rear light with brake light and turn signals, a horn and a kickstand. Everything a commuter needs is in the box, but no bottle cage mount.
Display, Controls, and App
3 ratings · factsDisplay and controls
RatedA color display sits at the center of the bar. From it, or from the app, you switch between the Class 2 and Class 3 settings, customize the five assist levels and swap between torque and cadence sensing. The sensor swap works from the bar while riding, and we appreciated how quickly it happens. At a true 20 mph the display read 21 mph, a 5% overread. The left-hand pad also drives the turn signals and the horn.
Companion app
RatedThe Heybike app pairs with the display and duplicates its settings: the Class 2/3 switch, the five assist levels and the torque or cadence sensing, with speed settings for the assist levels and the throttle under its Personalize menu. A QR card in the box links to it.
2 tests · 6 ratings · factsAssembly and setup
MeasuredThe Hybrid arrived well packaged, with the assembly tools, the charger, and cards linking to Heybike's app and the assembly documents. One link didn't work, so we had to find the user guide online. Assembly is relatively simple: we installed the kickstand, handlebar, front wheel, front fender, headlight and pedals. It took us 38 minutes, well under the 56-minute average of the e-bikes we have timed.
Support response, tested
MeasuredEvery brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Heybike the first useful answer arrived after 17.5 hours, right on the 17.7-hour average across the brands we have tested.
RatedThe mechanical side is standard: a Shimano Altus 8-speed drivetrain, chain, Tektro brake pads, tubes and 27.5" tires are available everywhere. The motor, battery, display and controller are Heybike's own, sold through the brand, which has a two-year warranty on bikes bought from its website. A hardtail with a suspension fork and the accessory set means a few more bolts to keep tight than a rigid commuter.
Component level for the price
RatedAn 864 Wh UL-certified battery, Tektro hydraulic discs, a Shimano Altus 8-speed, switchable torque and cadence sensing, and a full complement of commuter accessories: at this price, that is an impressive package.
Value for money
RatedWeighing everything we measured against the price at the time of publication: 32.45 miles of range at the group's highest average speed, the best brake result in the group, a second-place steep climb, well-tuned assist on both sensor types and every commuter accessory in the box. Overall, the Heybike Hybrid is easy to recommend at this price.
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 88 e-bikes we have tested.
| Test | Heybike HybridThis bike | Average of similar bikesSimilar | BikeRide averageAll bikes |
| Motor and performance | |||
| 0–20 mph, throttlevs. 33 other 750W hub-motor e-bikes | 10.0 s | 9.6 s | 10.7 s |
| 0–20 mph, max pedal assistvs. 34 other 750W hub-motor e-bikes | 7.0 s | 8.1 s | 8.4 s |
| Gradual hill climb, 20 mph capvs. 21 other 750W hub-motor e-bikes | 3:08 | 3:09 | 3:18 |
| Steep hill climbvs. 31 other 750W hub-motor e-bikes | 2:21 | 2:28 | 2:36 |
| Speedometer deviationvs. 6 other e-bikes | +5% | +5% | +5% |
| Motor noise @ 20 mph, unloadedvs. 6 other e-bikes | 60.9 dB(A) | 68.0 dB(A) | 68.0 dB(A) |
| Assist engagement delayvs. 6 other e-bikes | 0 crank rev (torque mode) | 0.4 crank rev | 0.4 crank rev |
| Range and charging | |||
| Range (max assist)vs. 22 other commuter e-bikes | 32.45 mi | 30.7 mi | 30.5 mi |
| Range vs claimedvs. 21 other commuter e-bikes | 32% | 60% | 55% |
| Efficiencyvs. 22 other commuter e-bikes | 26.6 Wh/mi | 21.7 Wh/mi | 25.2 Wh/mi |
| Charge time 0→100%vs. all e-bikes tested | 6 h | 6.3 h | 6.3 h |
| Braking and safety | |||
| Brake test, 20–0 mphvs. 22 other commuter e-bikes | 17.5 ft | 19.9 ft | 19.3 ft |
| Headlight @ 15 ftvs. 6 other e-bikes | 242 lux | 873 lux | 873 lux |
| Build and ownership | |||
| Measured weightvs. 19 other commuter e-bikes | 70.4 lb | 65.9 lb | 74.4 lb |
| Battery weightvs. 4 other e-bikes | 11.2 lb | 15.8 lb | 15.8 lb |
| Assembly timevs. 4 other e-bikes | 38 min | 56 min | 56 min |
| Support response, tested (weekday hours)vs. 29 other brands | 17.5 h | 17.7 h | 17.7 h |
Similar bikes: for acceleration and the hill climbs, e-bikes with a 750W nominal hub motor; for range, efficiency, braking and weight, commuter e-bikes; for the other rows, all e-bikes; support is averaged per brand. The gradual-hill row compares capped runs only. Charge times are calculated from charger output and battery capacity. Battery weight and assembly time use the all-bikes pool (no other commuter figures yet). Not measured: medium-assist range.
Detailed specs
As published by Heybike for the 2026 Hybrid. Values we verified or debunked in testing are covered in Claimed vs. measured.
| Electric bike class | Class 2 (Eco) or Class 3 (Sport), switchable (see Top speed) |
| Motor | Heybike Galaxy eDrive 750W rear hub (1,200W peak) |
| Max torque | 75 Nm (claimed) |
| Battery | 48V 18Ah (864 Wh), removable |
| Range claimed | Up to 100 miles |
| Top speed | 28 mph (27.1 mph GPS-verified) |
| Throttle | Thumb |
| Pedal assist | 5 levels, app-tunable |
| Sensor | Switchable torque and cadence |
| Charger | 54.6V 3A |
| Charge time | 6 hours (calculated) |
| Display | Color LCD |
| Certification | UL 2849 (electrical system), UL 2271 (battery) |
| Water/dust rating | IPX5 bike, IPX6 electrical components |
| Warranty | 2 years |
| Frame | 6061 aluminum, step-through, one size |
| Fork | 100 mm suspension fork, preload adjustment and lockout |
| Brakes | Tektro HD-E3520 two-piston hydraulic, 180 mm rotors |
| Drivetrain | Shimano Altus 8-speed, trigger shifter |
| Chainring / cassette | 48t / 12–32t |
| Rims / tires | 27.5" aluminum / 27.5" × 2.4" Kenda Kwick Seven.5 Sport, reflective sidewalls |
| Handlebar | 700 mm aluminum, 31.8 mm clamp, angle-adjustable stem |
| Grips | Lock-on ergonomic rubber |
| Saddle | Wide comfort-style |
| Pedals | Alloy platform, reflective |
| Lights | Headlight, rear light with brake light and turn signals, horn |
| Fenders | Front and rear, included |
| Kickstand | Included |
| Payload capacity | 440 lb (rack stamped 60 lb) |
Geometry details
As published by Heybike, one frame size. ✓ verified = we measured it on our test bike and it checked out (tolerance: within 3 mm). ✓ measured = Heybike doesn't publish this figure, so it's our own measurement.
| Measurement | One size (claimed 5'3"–6'2") | |
| Seat tube | 16.1" (409 mm) | ✓ verified |
| Reach | 17.6" (447 mm) | ✓ verified |
| Stack | 23.6" (599 mm) | ✓ measured |
| Standover height | 18.1" (460 mm) | ✓ verified |
| Virtual top tube | 24.4" (620 mm) | ✓ measured |
| Saddle height, min–max | 31.5"–38.8" (800–986 mm) | ✓ verified |
| Wheelbase | 48.1" (1,222 mm) | ✓ verified |
Video review
Watch Scott's full 8-minute review of the Heybike Hybrid, including footage from every test above, on BikeRide's YouTube channel.
