Aventon Level 4 REC Review
Our verdict
The Aventon Level 4 REC is the hub-drive version of the brand's commuter, with a 750W motor, regenerative braking, and a throttle. It climbed our steep hill in 2:13, the fastest in our comparison group, and lasted 44.20 miles at maximum assist, the longest max-assist run in the group. The brakes needed 22 feet from 20 mph, the longest stop in the group, and the hub whines under load. For riders who want a powerful, well-equipped commuter and don't need a mid-drive's smoother assist, the Level 4 REC is easy to recommend.
- Fastest steep climb in our group: 2:13
- 6 seconds to 20 mph on pedal assist
- 44.20 miles of range at max assist
- Keyless battery removal from the app or display
- Fenders, rack, lights, signals, and brake light included
- Longest stop in our group: 22 feet
- Loud hub: 70.4 dB(A) unloaded, whines under load
- Heavy for a commuter at 69.3 lb
Claimed vs. measured
Aventon sells the Level 4 REC on power, range, and its smart features. We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
| Claim | Aventon says | We measured | Verdict |
| Weight | 68.5 lb | 69.3 lb as shipped, 1.2% over | ✓ Verified |
| Range (max claim) | Up to 75 mi | 44.20 mi at maximum assist | ✓ 59% of claim |
| Charge time | 5 hours | 5.0 h by our calculation (20Ah ÷ 4A) | ✓ Verified |
| Fits our tester (6'0", 33" inseam) | Size L fits 5'10"–6'4" | A comfortable, relaxed position on the size L | ✓ Yes |
| Claimed height range accuracy | A 6" span of rider height on 4.75" of seatpost travel | (6" − 2") ÷ 4.75" = 0.8×, inside our 2.0× limit | ✓ Verified |
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
| This bike |
Aventon Level 4 ADV |
Velotric Discover 2 |
Heybike Hybrid |
| BikeRide Score | 93 | 94 | 91 | 87 |
| Best price | $1,799.00 | $2,699.00 | $1,439.00 | $1,199.00 |
| Motor | 750W rear hub (1,440W peak in Boost) | 250W Ultro S mid-drive (750W peak) | 750W rear hub (1,100W peak) | 750W rear hub (1,200W peak) |
| Battery | 733 Wh | 800 Wh | 706 Wh | 864 Wh |
| Range tested (max assist) | 44.20 mi | No max-assist run | 30.34 mi | 32.45 mi |
| Gradual hill climb | 3:02 | 3:10 | 3:08 | 3:08 |
| Steep hill climb | 2:13 | 2:32 | 2:43 | 2:21 |
| 0–20 mph (pedal assist) | 6.0 s | 6.0 s | 7.0 s | 7.0 s |
| Brake 20–0 mph | 22 ft | 20.5 ft | 18 ft | 17.5 ft |
| Measured weight | 69.3 lb | 65.4 lb | 69.0 lb | 70.4 lb |
| Payload | 300 lb | 300 lb | 440 lb | 440 lb |
| Top speed | 28 mph | 28 mph | 28 mph | 27.1 mph (GPS-verified) |
| Torque (claimed) | 80 Nm (96 Nm in Boost) | 100 Nm | 75 Nm | 75 Nm |
| Charge time | 5.0 h | 5.5 h | 4.9 h | 6.0 h |
| Suspension | 80 mm coil fork + 50 mm suspension seatpost | 100 mm coil fork, preload + lockout, 50 mm suspension seatpost | 80 mm coil fork | 100 mm fork, preload + lockout |
| Drivetrain | 8-sp Shimano Altus | 10-sp Shimano CUES, electronic shifter with AutoShift | 8-sp Shimano Altus | 8-sp Shimano Altus |
| Tires | 27.5×2.2″ Kenda | 27.5×2.2″ Kenda | 27.5×2.4″ Kenda | 27.5×2.4″ Kenda |
| Frame | Aluminum, step-over or step-through, two sizes | Aluminum, step-over in three sizes or step-through in two | Aluminum, step-through | Aluminum, step-through, one size |
| Assist sensor | Torque + cadence, switchable in the app | Torque, dual-sided | Torque + cadence (via app) | Torque + cadence, switchable from the bar |
| Water rating | IPX5 bike, IPX6 components | IPX6 bike, IP67 motor | IPX6 | IPX5 bike, IPX6 electrical |
| Certification | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 |
Who should buy the Level 4 REC
We believe the Aventon Level 4 REC is a good choice for:
- Commuters with hills on the route. The 750W hub climbed our steep hill in 2:13 and the gradual one in 3:02, the fastest times in our comparison group.
- Riders who want range at full power. Our max-assist run lasted 44.20 miles with 1,473 feet of climbing, the longest such run in the group.
- Level 4 buyers who want a throttle and brake light. The REC has both in stock form, plus Boost mode and regenerative braking, none of which the ADV offers (throttle can be added separately).
Who should NOT buy it
Before you buy: REC or ADV?
We tested the mid-drive Level 4 ADV with the same protocol, so the differences below are measured on the same courses, not read from a spec sheet.
- The REC is quicker on climbs. It climbed the steep hill in 2:13 to the ADV's 2:32.
- The ADV is quieter. The ADV measured 48.0 dB(A) on our bench to the REC's 70.4, and it stays quiet under load, where the REC's hub whines and vibrates.
- The ADV stops faster and shifts for you. It needed 20.5 feet from 20 mph to the REC's 22, and its 10-speed CUES drivetrain shifts automatically.
- The REC has more in stock form. A throttle, a brake light, regenerative braking and coasting, and Boost mode.
- Both offer good range. The ADV lasted 58.01 miles in Auto mode, which delivers slightly more power than Sport (PAS 2/3). The REC lasted 44.20 miles at max assist.
If you want the smoothest assist and automatic shifting, the ADV is the better bike. If you want a throttle, a brake light, and the faster climbing, the REC does the job for less.
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, and a verified weigh-in. Every result is stored in our database and shown against similar bikes and against the 90 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
- Tester
- 6'0", 33" inseam
- Rider + gear
- 200 lb
- Tires
- 27.5×2.2", 30 psi
- Speed limit
- 20 mph for the range test and both climbs
We tested the Level 4 REC in May 2026.
Score breakdown — how the 93 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the REC lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
5 tests · 3 ratings · factsAcceleration 0–20 mph
MeasuredIn Turbo mode we measured 6 seconds to 20 mph on maximum pedal assist and 7 seconds on the throttle alone, and Boost mode knocked a second off both. The pedal-assist time is tied for fastest in the comparison group, and the throttle time is the quickest outright. The 750W hub-motor e-bikes we have tested average 8.1 s on assist and 9.6 s on the throttle.
Climbing Test 1: Gradual Hill
MeasuredOn the gradual hill (0.99 miles at up to a 6% grade) the REC finished in 3:02 at an average of 18.9 mph with the 20 mph limit. That is the fastest time in this comparison group, one second ahead of the Velotric Summit 1. The 750W hub-motor e-bikes we have tested average 3:09 on capped runs.
Climbing Test 2: Steep Hill
MeasuredOn the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the REC reached the top in 2:13 at an average of 17.6 mph. That is the fastest time in the group, one second ahead of the Summit 1 and 19 seconds ahead of the Level 4 ADV. The 750W hub-motor e-bikes we have tested average 2:28.
Speed settings and e-bike class
Fact checkThe REC ships as a Class 2 e-bike and can be programmed to Class 3 through the speed limit in the app, with pedal assist to 28 mph. The 750W motor pushed us to that limit quickly, with easy cruising in the mid 20s. Boost mode raises the motor to 96 Nm and 1,440W for 30 seconds at a time. Ride Tune in the app lets you customize the three pedal assist levels.
Class 3 e-bikes are limited to 28 mph on pedal assist and 20 mph on the throttle. Many trails and multi-use paths restrict Class 3 access, so check local rules before riding there.
Assist engagement and cutoff
MeasuredThe REC has both a torque sensor and a cadence sensor, and you choose between them in the app. From a standstill in torque mode the assist arrived with no measurable delay (0 crank revolutions). The e-bikes we have measured average 0.2 crank revolutions before assist arrives.
Motor noise
MeasuredMeasured indoors with the rear wheel spinning unloaded at 20 mph, the hub registered 70.4 dB(A), slightly above the 66.6 dB(A) average of the 17 e-bikes we have measured this way. Under heavy load on steep grades the hub whines and vibrates, where the Level 4 ADV's mid-drive stays quiet.
Range and Charging
4 tests · 2 ratings · factsRange Test 1: Max Assist (PAS 3/3, 20 mph limit)
MeasuredOn our standard loop at maximum assist (Turbo, PAS 3 of 3) with the 20 mph limit, the REC lasted 44.20 miles with 1,473 feet of elevation gain, at a 17.7 mph average. That is the longest max-assist result in this comparison group (the Level 4 ADV ran only in Auto mode) and 49% above the 29.7-mile average of the commuter e-bikes we have tested. We believe the regenerative modes contributed to the result.
Range vs. claimed
DerivedAventon claims up to 75 miles. We ran only the maximum-assist test on the REC, so its 44.20 miles is 59% of the claim, inside our tolerance, even without the medium-assist run where a bike does better.
Efficiency
DerivedDividing battery capacity by measured range shows how far a bike stretches every watt-hour. At 16.6 Wh per mile at max assist, the REC is the most efficient in this comparison group and well under the 21.7 Wh/mi average of the commuter e-bikes we have tested.
Charge time
CalculatedThe 36V 20Ah pack charges on the included 4A charger. By our calculation a full charge takes at least 5 hours (20Ah ÷ 4A), matching Aventon's 5-hour claim and quicker than the 6.3-hour average across our database. The charge port sits low on the frame behind a rubber cover.
Fact checkThe 36V 20Ah pack (733 Wh, LG cells) sits inside the down tube, and the label on ours reads 19.88Ah. It weighed 8.6 lb on our scale, against Aventon's 8.7 lb. There is no key: the pack unlocks from the app or the display's advanced menu. The battery is certified to UL 2271 and the electrical system to UL 2849. The bike is rated IPX5 and the components IPX6.
Regenerative braking and coasting
Fact checkThe REC is the first e-bike we have tested with regenerative braking, and it comes in two forms. Regen braking recovers battery charge when you pull the levers at speeds over 6 mph, and regen coasting recovers energy when you roll off the power above 6 mph. Both features are controlled in the app's advanced settings. Aventon claims they add up to 10 extra miles.
Braking and Safety
2 tests · 2 ratingsBrake test: 20 to 0 mph
MeasuredThe Tektro HD-E3520 two-piston hydraulic discs with 180 mm rotors stopped the REC from 20 mph in 22 feet, the longest distance in this comparison group and 2.1 feet above the 19.9-foot average of the commuter e-bikes we have tested. Of the tests all six bikes ran, it was the only one where the REC finished last. The brakes are fine for everyday riding, but we'd swap to a larger front rotor when the stock one wears out.
Lights, signals, and visibility
MeasuredThe REC comes with an integrated headlight and a taillight with a brake light and turn signals. On our center-beam measurement the headlight put out 380 lux at 15 feet, below the 579 lux average of the 17 e-bikes we have measured.
Ride Quality and Handling
1 descriptor · 8 ratingsRiding the Level 4 REC
Rolling the REC around before riding, you feel the weight. At 69.3 lb it is heavy for a commuter e-bike, and you notice it whenever the motor isn't helping. Once riding, we found the relaxed geometry comfortable, and under power this thing moves: 20 mph in 6 seconds and easy cruising in the mid 20s in Class 3 mode.
Stability at top speed
RatedOn our stability run we ride straight at top speed, shift our weight, and shake the bike to see whether a wobble starts. The no-hands check is done separately, at lower speed on level ground, to see that it tracks straight.
Comfort, suspension, and vibration
RatedSuspension comes from an 80 mm coil fork with preload adjustment and a lockout, plus a 50 mm suspension seatpost under the Aventon saddle.
Riding position
DescriptorWhere the REC sits on the spectrum from fully upright to fully aggressive. The 680 mm bar on its angle-adjustable stem gave us a relaxed position, a little forward of upright:
Fit and Sizing
2 measurements · 2 checks · 2 ratingsTrue to size?
VerdictAventon makes the REC in two sizes, and the size L step-over we tested is listed for riders from 5'10" to 6'4", a 6-inch span served by 4.75 inches of saddle-height adjustment (37" to 41.75" from the ground, measured on our test bike). By our rule of thumb that span is plausible. At 6'0" with a 33" inseam we found the relaxed position comfortable.
| Measurement | Aventon claims | We found |
| Rider height range, size L | 5'10"–6'4" | 6'0" fits comfortably; the ends of the range untested |
| Saddle height, ground to top of saddle | — | 37"–41.75" (940–1,060 mm), 4.75" of adjustment, measured on our test bike |
| Fits our tester (6'0", 33" inseam) | Inside the claimed range | Yes, comfortably |
| Claimed height range accuracy | 6" span on 4.75" of travel | (6 − 2) ÷ 4.75 = 0.8×, inside our 2.0× limit |
| Standover | 27.36" (695 mm) | As published |
| Our verdict | Size L fits 5'10"–6'4" | Plausible |
Cockpit adjustability
RatedThe 680 mm aluminum bar sits on a 90-degree angle-adjustable stem. With the saddle set for a 33" inseam, Scott found a relaxed, comfortable position.
Build and Components
1 test · 6 ratings · factsWeight, verified
MeasuredAventon lists the REC at 68.5 lb. Our scale read 69.3 lb as shipped, 1.2% over the claim. That is third-heaviest in this comparison group and 3.4 lb above the 65.9 lb average of the commuter e-bikes we have weighed. Aventon rates the payload at 300 lb.
RatedThe 6061 aluminum frame comes as a step-over or a step-through, each in two sizes, with the battery inside the down tube and the cables routed internally. We tested the size L step-over. The fenders, rack, and lights are fitted at the factory.
Drivetrain and shifting
RatedShifting is handled by an 8-speed Shimano Altus derailleur and trigger shifter, with a 48t chainring and a 12–32t cassette. It is the lower-end drivetrain of the two Level 4s: the ADV gets a 10-speed CUES with automatic shifting. Stopping comes from Tektro HD-E3520 two-piston hydraulic discs with 180 mm rotors.
Tires and accessories
RatedThe 27.5×2.2" Kenda Kwick Seven-5 Sport tires sit on double-wall aluminum rims. Included are full-coverage fenders, a rear rack, a kickstand, and the integrated lights with turn signals and a brake light. Everything a commuter needs is in the box.
Display, Controls, and App
3 ratings · factsDisplay and controls
RatedThe Aventon A280 display is mounted centrally, and it is bright and easy to read in direct sunlight. Its advanced menu unlocks the battery, and the rear-wheel lock is activated from the display. The control pad and the thumb throttle sit together on the left grip, with the trigger shifter on the right.
Companion app
RatedThe Aventon app paired quickly. Ride Tune gives full control of each assist level, the speed limit, and the choice of torque or cadence sensing, and the advanced settings hold the regen modes and the keyless battery unlock. The smart features, 4G and GPS tracking, geofencing, unusual-activity detection, and a remote phone lock, are free for the first year and need a subscription after that.
1 test · 6 ratings · factsAssembly and setup
RatedThe REC arrived almost ready to ride: we attached the bars, fitted the front wheel, installed the pedals, and charged the battery. Aventon includes the instruction manual and the tools. Our factory audit found no issues: the wheels were true and everything was set up correctly.
Support response, tested
MeasuredEvery brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Aventon the first useful answer arrived after half an hour, far quicker than the 18.1-hour average across the brands we have tested.
RatedThe mechanical side is standard: a Shimano Altus 8-speed drivetrain, Tektro hydraulic brakes, and 27.5" tires in a common size. The motor, battery, display, and the regen electronics are Aventon's own. Aventon covers the bike with a two-year limited warranty and a lifetime frame warranty.
Component level for the price
RatedA 750W hub, a 733 Wh UL-certified battery with keyless removal, regenerative braking, hydraulic discs, an 8-speed Altus, an easy-to-read display with 4G and GPS, and a full set of commuter accessories: for this price, the REC packs a lot in.
Value for money
RatedWeighing everything we measured against the price at the time of publication: the fastest climbs and the quickest throttle run in our comparison group, 44.20 miles of range at max assist, regenerative braking, and every commuter accessory in the box. Against that, a 22-foot stop and 69.3 lb to lift. The Level 4 REC made a strong case for its value.
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 90 e-bikes we have tested.
| Test | Aventon Level 4 RECThis bike | Average of similar bikesSimilar | BikeRide averageAll bikes |
| Motor and performance | |||
| 0–20 mph, throttlevs. 33 other 750W hub-motor e-bikes | 7.0 s | 9.6 s | 10.7 s |
| 0–20 mph, max pedal assistvs. 34 other 750W hub-motor e-bikes | 6.0 s | 8.1 s | 8.4 s |
| Gradual hill climb, 20 mph capvs. 21 other 750W hub-motor e-bikes | 3:02 | 3:09 | 3:18 |
| Steep hill climbvs. 31 other 750W hub-motor e-bikes | 2:13 | 2:28 | 2:36 |
| Motor noise @ 20 mph, unloadedvs. 16 other e-bikes | 70.4 dB(A) | 66.6 dB(A) | 66.6 dB(A) |
| Assist engagement delayvs. 15 other e-bikes | 0 crank rev | 0.2 crank rev | 0.2 crank rev |
| Range and charging | |||
| Range (max assist)vs. 22 other commuter e-bikes | 44.20 mi | 29.7 mi | 30.2 mi |
| Range vs claimedvs. 21 other commuter e-bikes | 59% | 60% | 55% |
| Efficiencyvs. 22 other commuter e-bikes | 16.6 Wh/mi | 21.7 Wh/mi | 25.2 Wh/mi |
| Charge time 0→100%vs. all e-bikes tested | 5.0 h | 6.3 h | 6.3 h |
| Braking and safety | |||
| Brake test, 20–0 mphvs. 22 other commuter e-bikes | 22 ft | 19.9 ft | 19.3 ft |
| Headlight @ 15 ftvs. 16 other e-bikes | 380 lux | 579 lux | 579 lux |
| Build and ownership | |||
| Measured weightvs. 19 other commuter e-bikes | 69.3 lb | 65.9 lb | 74.6 lb |
| Battery weightvs. 13 other e-bikes | 8.6 lb | 11.7 lb | 11.7 lb |
| Support response, tested (weekday hours)vs. 31 other brands | 0.5 h | 18.1 h | 18.1 h |
Similar bikes: for acceleration and the hill climbs, e-bikes with a 750W nominal rear hub motor; for range, efficiency, braking, and weight, commuter e-bikes; for the other rows, all e-bikes; support is averaged per brand. The gradual-hill row compares capped runs only. Charge time is calculated from charger output and battery capacity. Not run on the REC: medium-assist range, GPS top speed, speedometer accuracy, and a timed assembly.
Detailed specs
As published by Aventon for the Level 4 REC step-over we tested, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
| Electric bike class | Class 2 as shipped, programmable to Class 3 (see Speed settings) |
| Motor | Aventon 750W rear hub (1,188W peak, 1,440W in Boost mode) |
| Max torque | 80 Nm, 96 Nm in Boost mode (claimed) |
| Battery | 36V 20Ah (733 Wh), LG cells, removable, keyless |
| Range claimed | Up to 75 miles |
| Top speed | 28 mph (claimed, not GPS-verified) |
| Throttle | Thumb throttle, left |
| Pedal assist | 3 levels (Eco, Sport, Turbo), tunable in the app (Ride Tune) |
| Sensor | Torque or cadence, switchable in the app |
| Charger | 42V 4A |
| Charge time | 5 hours claimed, 5.0 hours calculated |
| Display | Aventon A280 |
| Certification | UL 2849 (electrical system) and UL 2271 (battery) |
| Water/dust rating | IPX5 bike, IPX6 components |
| Warranty | 2 years limited, lifetime frame warranty |
| Smart features | 4G and GPS tracking, geofencing, rear-wheel lock, activity alerts, remote lock; subscription after the first year |
| Frame | 6061 aluminum, step-over (tested) or step-through, sizes S/M and L |
| Fork | 80 mm coil suspension, preload adjustment and lockout |
| Brakes | Tektro HD-E3520 two-piston hydraulic, 180 mm rotors, plus regenerative braking |
| Drivetrain | Shimano Altus 8-speed, trigger shifter |
| Chainring / cassette | 48t / 12–32t |
| Rims / tires | 27.5" double-wall aluminum / 27.5" × 2.2" Kenda Kwick Seven-5 Sport |
| Handlebar | 680 mm aluminum, 31.8 mm, on a 60 mm angle-adjustable stem |
| Grips | Aventon lock-on |
| Saddle | Aventon, on a 50 mm suspension seatpost |
| Pedals | Composite platform |
| Lights | Integrated headlight, taillight with brake light and turn signals |
| Fenders | Full-coverage, included |
| Kickstand | Included |
| Payload capacity | 300 lb |
Geometry details
As published by Aventon for the size L. ✓ measured = Aventon doesn't publish this figure, so it's our own measurement.
| Measurement | Size L (tested, claimed 5'10"–6'4") | |
| Seat tube | 19.7" (500 mm) | As published |
| Reach | 17.7" (450 mm) | As published |
| Stack | 24.3" (618 mm) | As published |
| Standover height | 27.36" (695 mm) | As published |
| Virtual top tube | 25.0" (635 mm) | As published |
| Head tube angle | 70° | As published |
| Seat tube angle | 74° | As published |
| Chainstay | 18.9" (480 mm) | As published |
| Wheelbase | 46.5" (1,180.7 mm) | As published |
| Saddle height, min–max | 37"–41.75" (940–1,060 mm) | ✓ measured |
Video review
Watch Scott's full 9-minute review of the Aventon Level 4 REC, including footage from every test above, on BikeRide's YouTube channel.
