Cannondale Jekyll
87/100
35.5 lb
We have read all expert and user reviews on the Cannondale Jekyll. In summary, this is what cyclists think. Updated Mar 24, 2026 by Reda Ashour.
14 reasons to buy
  • Testers praise the Jekyll's mix of playful handling with composure on steep descents.
  • Several experts highlight the Jekyll's "beautifully balanced" geometry and weight distribution.
  • The size-specific geometry ensures consistent handling across all sizes.
  • Experts say the low center of gravity aids in cornering and stability.
  • Testers appreciate the minimal pedal bob while ascending seated.
  • Experts say the ride is predictable, calm, and confidence-inspiring.
  • Reviewers find the Jekyll excels when ridden fast, and it carries speed well.
  • The suspension effectively takes the edge off large hits and small chatter.
  • Reviewers feel the suspension provides good traction while also remaining active.
  • The SRAM Code RSC brakes with 220mm/200mm rotors offer excellent stopping power in testing.
  • Testers find it easy to pop the Jekyll off the ground.
  • Experts are pleased with the fairly quiet high-pivot suspension design.
  • Reviewers say the idler pulley and guide eliminate pedal kickback.
  • In collaboration with Cannondale, Cascade Components offers a rear linkage to mullet the Jekyll.
10 reasons not to buy
  • The Jekyll 1's 35.5lb can feel sluggish in tight turns, on flats, and while climbing, according to testers.
  • An expert finds the high pivot’s lengthening wheelbase causes the rear wheel to hang up in slow, technical drops.
  • Testers criticize the WTB KOM Trail i30 rims for losing spoke tension, denting easily, and leaking air.
  • Experts feel the Maxxis EXO+ tire casing isn't tough enough for serious enduro riding.
  • The shock integration into the frame’s “Gravity Cavity” makes it hard to access and allows debris to rattle inside.
  • Testers find the FOX Float Factory X2 shock finicky to set up.
  • The 3mm-offset Asymmetric Integration proprietary rear wheel limits wheel swaps.
  • Reviewers are disappointed in the dropper seatpost’s short travel (S: 125mm, M-XL: 150mm) and “spongy” remote.
  • Reviewers say the internal cable routing is clunky and rattly.
  • The idler system requires extra maintenance and consistent cleaning.
The Jekyll is Cannondale’s carbon enduro mountain bike with 170mm front and 165mm rear travel, currently available in one mid-level build. Testers are impressed with how comfortable it is in most situations, but most of all on gnarly descents where the active suspension delivers abundant traction, and the handling balances agility and sure-footedness. The brakes and suspension are also praised, but Cannondale misses the mark with disappointing wheels and tires and a cheap dropper post. Reviewers are divided on the Jekyll’s overall value, but its stellar performance on enduro trails is commended.
82/100 based on 5 rated expert reviews
Cannondale Jekyll 1 Review
Considering the price, it’d be great to see some better wheels, which could elevate its performance even further. Otherwise, the Jekyll feels well-balanced, incredibly capable and very composed.
The Loam Wolf
Cannondale Jekyll Carbon 1 29 Mountain Bike Review
While we do really like the Jekyll overall, it’s not a perfect bike… That said, Cannondale has done a great job making the Jekyll a very worthy adversary to any gnarly trail it encounters.
Flow Mountain Bike
Cannondale Jekyll Review | A Striking Enduro Bike That Takes a Balanced Approach to the High Pivot Hype
However, the important aspects, the chassis, suspension and geometry, are absolutely dialed. We like that Cannondale has taken a measured approach to the high pivot hype, with the Jekyll hitting a sweet spot between square-edge compliance and cornering agility.
2022 Cannondale Jekyll
The Cannondale Jekyll is a nicely executed take on a modern enduro bike, with well-balanced geometry, intuitive handling, and very good stability at speed, without feeling totally out of place or unwieldy in tighter spots.
Review – Cannondale Jekyll 1
Overall, the Jekyll is nimble, but still very planted and begs to go faster.
Freehub Magazine
Cannondale Jekyll 1 Bike Review
Top quality mountain bikes are abundant in today’s marketplace, though few blend sleek design and rock-solid fundamental performance as naturally as the Jekyll. For riders seeking steeper than steep trails and sonic boom speeds, the Jekyll is an undeniable option.
The Root Line
Cannondale Jekyll 2022 Review
All in all, it’s an excellent bike with just the wheels that really let it down. I would definitely recommend this bike, if you don’t mind the faffing around setting it up.
BIKE Magazine
Tested: Cannondale Jekyll Part 1.5
… The current model is such a capable, well-rounded ride that I’d advise riders not to overlook it, especially given the excellent price that it can be acquired for right now.
2023 Cannondale Jekyll 1 Long Term Review
The frame felt stiff, the suspension worked well and the bike was fast, predictable and extremely capable. Pricing is competitive and Cannondale did not skimp on the all important suspension and brake components. The wheels are not great…
ENDURO Mountainbike Magazine
Exclusive First Ride Review of the 2022 Cannondale Jekyll 1 – The Next Chapter for One of the Most Successful Race Bikes?
Though the standard build isn’t quite race ready, the bike’s handling is agile and playful, yet confidence inspiring on fast and steep terrain, which should make it a hot contender at the races.
365mountainbike
Cannondale Jekyll 1 2022 Test: Pushed Enduro MTB [Italian Video]
Compared to other competitors, it is perhaps the most predictable and rideable right from the start, despite the geometry being clearly geared towards downhill. It’s a shame about the weight and pedaling, which aren’t excellent on this bike…
MTB-News.de
Cannondale Jekyll Review [German]
With the new Jekyll, Cannondale is launching an absolute race enduro bike that impresses with its smooth ride and very predictable, balanced handling, especially at high speeds.
Gravity Mountainbike Magazine
Test Cannondale Jekyll – High-Pivot Enduro Machine + Enduro Race Track Action [German]
The bike is super playful, but still stable on the trails.
100/100 based on 1 ratings
Cannondale Jekyll in comparison to averages
