Aventon Level 4 ADV Review
Scott Clough-Carroll, Bike Testing and Video Production By Scott Clough-Carroll, updated Oct 30, 2026 | Tested using BikeRide Methodology 1.1 First-Hand Test
Our verdict
The Aventon Level 4 ADV is the mid-drive version of the brand's commuter, with pedal assist and gears that shift for you. It posted solid results in all tests, and lasted 58.01 miles in a range test using Auto PAS mode, the longest result in our comparison group. The inaccurate listed weight, stiff coil fork, and missing brake light count against the Level 4 ADV. For commuters who want an affordable mid-drive with plenty of range, it's easy to recommend.
  • Second-longest medium-assist range of 14 commuters: 58.01 miles
  • 6 seconds to 20 mph on pedal assist
  • Natural, responsive mid-drive power delivery
  • Auto PAS and AutoShift work well together
  • Fenders, rack, lights, and turn signals included
  • Quietest motor we have measured: 48.0 dB(A)
  • 65.4 lb against a 61 lb claim
  • Basic coil fork, stiff and slow
  • Charge port sits low and exposed
  • No brake light
Claimed vs. measured
Aventon sells the Level 4 ADV on its mid-drive, its range, and its automatic shifting. We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
ClaimAventon saysWe measuredVerdict
Weight61 lb65.4 lb as shipped, 7.2% over✗ Misleading
Range (max claim)Up to 110 mi58.01 mi in Auto mode✓ 53% of claim
Charge time5 hours5.5 h by our calculation (22Ah ÷ 4A)✓ Verified
Fits our tester (6'0", 33" inseam)Size L fits 5'10"–6'4"A comfortable, slightly forward-leaning position on the size L✓ Yes
Claimed height range accuracyA 6" span of rider height on 7" of seatpost travel(6" − 2") ÷ 7" = 0.6×, inside our 2.0× limit✓ Verified
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
This bikeAventon Level 4 ADV, the commuter e-bike we testedAventon Level 4 ADV Aventon Level 4 REC commuter e-bike, side viewAventon Level 4 REC TENWAYS AGO X commuter e-bike, side viewTENWAYS AGO X Himiway Rambler commuter e-bike, side viewHimiway Rambler
BikeRide Score 94 93 94 89
Best price $2,699.00 $1,799.00 $1,849.00 $2,199.00
Motor250W Ultro S mid-drive (750W peak)750W rear hub (1,440W peak in Boost)250W Bafang M410 mid-drive500W Bafang M600 mid-drive
Battery800 Wh733 Wh504 Wh720 Wh
Range tested (medium assist)58.01 mi Auto modeNo medium-assist run35.36 mi42.62 mi
Efficiency (medium assist)13.8 Wh/miNo medium-assist run14.3 Wh/mi16.9 Wh/mi
Gradual hill climb3:103:023:203:09
Steep hill climb2:322:133:023:05
0–20 mph (pedal assist)6.0 s6.0 s8.0 s12.0 s
Brake 20–0 mph20.5 ft22 ft20 ft18.5 ft
Measured weight65.4 lb69.3 lb61.0 lb67.0 lb
Top speed20 mph as shipped, 28 mph in Class 328 mph20 mph25 mph
Torque (claimed)100 Nm80 Nm (96 Nm in Boost)80 Nm120 Nm
Charge time5.5 h5.0 h4.7 h5.0 h
Suspension100 mm coil fork, preload + lockout, 50 mm suspension seatpost80 mm coil fork + 50 mm suspension seatpost110 mm fork with lockoutSuspension fork
Drivetrain10-sp Shimano CUES, electronic shifter with AutoShift8-sp Shimano Altus10-sp Shimano Deore9-sp Shimano Altus
Tires27.5×2.2″ Kenda27.5×2.2″ Kenda29×2.25″ CST27.5×2.4″ Innova
FrameAluminum, step-over in three sizes or step-through in twoAluminum, step-over or step-through, two sizesAluminum, step-over, three sizesAluminum
Assist sensorTorque, dual-sidedTorque + cadence, switchable in the appTorqueTorque + cadence
Water ratingIPX6 bike, IP67 motorIPX5 bike, IPX6 componentsIPX4IPX4
CertificationUL 2849 + UL 2271UL 2849 + UL 2271In progress when we tested itIn progress when we tested it
Who should buy the Level 4 ADV
We believe the Aventon Level 4 ADV is a good choice for:
  • Commuters who want range to spare. Our Auto-mode run lasted 58.01 miles with 1,581 feet of climbing, the longest run in the comparison group.
  • Riders who want natural-feeling assist. The quiet Ultro S mid-drive delivers smooth assist that matches your input.
  • Level 4 buyers who want the bike to do the thinking. AutoShift picks the gear and Auto mode picks the assist level. The REC has neither (ADV or REC?).
The ADV on a residential road: quick acceleration to 20 mph.
Who should NOT buy it
  • Riders who want a throttle or brake light as standard. The throttle is sold separately and there's no brake light. The REC has both.
  • Riders who expect a plush fork. The basic 100 mm coil fork is stiff and slow to respond.
Before you buy: ADV or REC?
We tested the hub-drive Level 4 REC with the same protocol, so the differences below are measured on the same courses, not read from a spec sheet.
  • The ADV is quieter. The ADV measured 48.0 dB(A) on our bench to the REC's 70.4, and it stays quiet under load, where the REC's hub whines and vibrates.
  • The REC is quicker on climbs. It climbed the steep hill in 2:13 to the ADV's 2:32 and the gradual one in 3:02 to 3:10.
  • The ADV stops faster and shifts for you. It needed 20.5 feet from 20 mph to the REC's 22, and its 10-speed CUES drivetrain shifts automatically.
  • The REC has more in stock form. A throttle, a brake light, regenerative braking and coasting, and Boost mode.
  • Both offer good range. The ADV lasted 58.01 miles in Auto mode, which delivers slightly more power than Sport (PAS 2/3). The REC lasted 44.20 at max assist.
The Aventon Level 4 REC and the black Level 4 ADV side by side in the BikeRide studio
The Level 4 REC and the black Level 4 ADV.
If you want the smoothest assist and automatic shifting, the ADV is the better bike. If you want a throttle, a brake light, and the faster climbing, the REC does the job for less.
Tests and Measurements
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, and a verified weigh-in. Every result is stored in our database and shown against similar bikes and against the 90 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
Test conditions — this review
Tester
6'0", 33" inseam
Rider + gear
200 lb
Tires
27.5×2.2", 30 psi
Speed limit
20 mph for the range test and both climbs
We tested the Level 4 ADV in the spring of 2026.
Score breakdown — how the 94 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the ADV lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
5 tests · 3 ratings · facts
Acceleration 0–20 mph
Measured
On maximum pedal assist we measured 6 seconds to 20 mph. That is tied for fastest in this comparison group and beats the 7.3 s average of the mid-drive e-bikes we have tested. The ADV doesn't have a throttle.
Scott on the ADV. From a standstill it reached 20 mph in 6 seconds on pedal assist.
0–20 mph, max pedal assist
Seconds · shorter is faster
Aventon Level 4 ADV6.0 s
Aventon Level 4 REC6.0 s
Aventon Level 37.0 s
TENWAYS AGO X8.0 s
Himiway Rambler12.0 s
Aventon Level 4 ADVComparison bikesAverage of similar bikes (7.3 s)
Max pedal assist: 6.0 sThrottle: none fitted, sold separatelyAverage of similar bikes: 7.3 sTies fastest in the group
Climbing Test 1: Gradual Hill
Measured
On the gradual hill (0.99 miles at up to a 6% grade) the ADV finished in 3:10 at an average of 18.1 mph with the 20 mph limit. That is fourth of five in this comparison group, 8 seconds behind the Level 4 REC, and 3 seconds inside the 3:13 average of the mid-drive e-bikes we tested on capped runs.
Scott riding the Aventon Level 4 ADV toward the camera along a paved path between hedges
Scott on the ADV on a paved path.
Gradual hill climb, max assist, 20 mph cap
Minutes:seconds · shorter is faster · 0.99 mi · 79 ft gain · 6% max grade
Aventon Level 4 REC3:02
Aventon Level 33:05
Himiway Rambler3:09
Aventon Level 4 ADV3:10
TENWAYS AGO X3:20
Aventon Level 4 ADVComparison bikesAverage of similar bikes, capped runs (3:13)
ADV, 20 mph cap: 3:10 · 18.1 mph avgAverage of similar bikes, capped runs: 3:13Fourth of five in the group
Climbing Test 2: Steep Hill
Measured
On the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the ADV reached the top in 2:32 at an average of 15.3 mph. That is second in the group, 19 seconds behind the Level 4 REC and 6 seconds ahead of the Level 3, and 17 seconds quicker than the 2:49 average of the mid-drive e-bikes we have tested. The motor gave plenty of power on climbs without ever feeling overly aggressive.
Scott on the ADV along a park path.
Steep hill climb, max assist
Minutes:seconds · shorter is faster · 0.65 mi · 226 ft gain · 12% max grade
Aventon Level 4 REC2:13
Aventon Level 4 ADV2:32
Aventon Level 32:38
TENWAYS AGO X3:02
Himiway Rambler3:05
Aventon Level 4 ADVComparison bikesAverage of similar bikes (2:49)
ADV: 2:32 · 15.3 mph avgSecond in the comparison groupAverage of similar bikes: 2:49
Hill start on steep grade5/5The powerful motor gets it moving on the 12% climb with minimal effort.
Speed settings and e-bike class
Fact check
The ADV ships as a Class 1 e-bike with pedal assist to 20 mph, and the app can set it to Class 2, or to Class 3 with assist to 28 mph. We rode it in Class 3 mode for a while and it handled the speed well, cruising in the mid 20s.
Scott leaning the Aventon Level 4 ADV through a corner on a paved path between lawns
Leaning the ADV through a corner on a park path.
✓ Class 1 as shipped, Class 2 or 3 in the appTop speed:  28 mph claimed, not GPS-verifiedThrottle:  sold separatelyAssist levels:  Eco, Sport, Turbo, and Auto
Class 3 e-bikes are limited to 28 mph on pedal assist and 20 mph on the throttle. Many trails and multi-use paths restrict Class 3 access, so check local rules before riding there.
Auto mode and AutoShift
Fact check
Auto mode reads your pedal input, cadence, and speed and picks Eco, Sport, or Turbo for you, while AutoShift watches cadence, speed, and motor output and picks the gear. The two worked well together, and we left them on for the entire range test, rarely wanting manual control, a real benefit in busy traffic. In Auto mode the bike averaged speeds a touch above Sport (PAS 2/3).
AutoShift in the display's settings, where it can be switched off.
✓ Auto mode picks Eco, Sport, or Turbo✓ AutoShift picks the gearUsed for the  entire 58.01-mile range test✓ Shift points tunable in the app
Assist engagement and cutoff
Measured
A torque sensor manages the assist. From a standstill, power arrived with no measurable delay (0 crank revolutions), and the power output felt matched to our input, natural and responsive. The e-bikes we have measured average 0.2 crank revolutions before assist arrives.
Scott on the ADV. From a standstill the assist arrived with no measurable delay.
Engagement delay: 0 crank revAverage: 0.2 crank revSensor: dual-sided torque
Motor engagement5/5Crisp and responsive, with no measurable delay from a standstill.
Assist cutoff behavior5/5Smooth and consistent taper at the speed limit.
Motor noise
Measured
Measured indoors with the rear wheel spinning unloaded at 20 mph, the ADV registered 48.0 dB(A), the quietest of the 17 e-bikes we have measured this way and well under their 66.6 dB(A) average. Most of the noise came from the chain and wheel. The motor itself is very quiet, even under load, whereas the Level 4 REC's hub whines.
The Aventon Level 4 ADV's Ultro S mid-drive motor and 48t chainring from the drive side
The Ultro S mid-drive: 250W nominal, 750W peak, 100 Nm, and 48.0 dB(A) at 20 mph unloaded.
ADV: 48.0 dB(A) @ 20 mph, unloadedAverage: 66.6 dB(A)Quietest we have measured
Range and Charging
4 tests · 2 ratings · facts
Range Test 1: Auto mode (Auto PAS and AutoShift, 20 mph limit)
Measured
On our standard loop in Auto mode, with the bike choosing the assist level and the gear, the ADV lasted 58.01 miles with 1,581 feet of elevation gain, at a 14.8 mph average. Auto mode delivered speeds slightly above Sport, the middle of the three levels, so we compare this run with medium-assist runs: it is the longest result in this comparison group and 39% above the 41.8-mile average of the commuter e-bikes we have tested.
The Aventon Level 4 ADV's A280 display in Auto mode at 0 mph, with its odometer and range estimate
Auto mode on the A280 display: the mode for our 58.01-mile range run.
Range at medium assist
Miles · longer is better · the ADV in Auto mode
Aventon Level 4 ADV Auto mode58.01 mi
Aventon Level 353.26 mi
Himiway Rambler42.62 mi
TENWAYS AGO X35.36 mi
Aventon Level 4 ADVComparison bikesAverage of similar bikes (41.8 mi)
ADV, Auto mode: 58.01 mi · 1,581 ft climbed · 14.8 mph avgAverage of similar bikes at medium assist: 41.8 mi+39% vs. similar bikesLongest in the group
Where the ADV sits: range
Compared to the 14 commuter e-bikes we have tested at medium assist
ADV
23 mi (shortest commuter result)Range, medium assist59 mi (longest)
Range vs. claimed
Derived
Aventon claims up to 110 miles, for a 165 lb rider in Eco mode on flat pavement. Our only range run, 58.01 miles in Auto mode, is 53% of the claim, inside our tolerance.
Claimed: 110 miOur test: 58.01 mi (Auto mode)53% of claim vs. the 60% average for commuter e-bikes
Efficiency
Derived
Dividing battery capacity by measured range shows how far a bike stretches every watt-hour. At 13.8 Wh per mile, the ADV is well under the 16.6 Wh/mi average of the commuter e-bikes we have tested at medium assist.
Energy used per mile
Wh/mi · lower is better · battery Wh ÷ medium-assist range
Himiway Rambler16.9
TENWAYS AGO X14.3
Aventon Level 4 ADV13.8
Aventon Level 313.8
Aventon Level 4 ADVComparison bikesAverage of similar bikes (16.6 Wh/mi)
Where the ADV sits: efficiency
ADV
11 Wh/mi (most efficient commuter e-bike)Efficiency, medium assist24 Wh/mi (least)
Charge time
Calculated
The 36V battery charges on the included 4A charger. Aventon lists it at 20Ah, but the label on ours reads 22Ah, so by our calculation a full charge takes at least 5.5 hours (22Ah ÷ 4A), quicker than the 6.3-hour average across our database. The charge port sits low on the battery, where it is exposed, which is not ideal on a commuter built for the rain.
Plugging in: the port sits low on the down tube.
Charge time: 5.5 h (calculated)Claimed: 5 hAverage: 6.3 h
Fact check
The 36V pack (800 Wh, Samsung cells) sits inside the down tube and, on the step-over frame, comes out through the bottom. Aventon lists it at 8.7 lb, and ours weighed 9.2 lb on our scale. The battery is certified to UL 2271 and the electrical system to UL 2849. The bike is rated IPX6 and the motor IP67.
The battery lives in the down tube and comes out through the bottom.
✓ Removable battery, out through the bottom of the down tubeBattery weight:  9.2 lb measured (8.7 lb claimed)✓ UL 2849 electrical system, UL 2271 battery✓ IPX6 bike, IP67 motor
Charge-gauge accuracy4/5The range estimate was slightly optimistic: about 62 miles shown, 58.01 ridden.
Battery removal and locking4/5Locks securely. Unlocking through the display menu is easy, but slower than a key.
Braking and Safety
2 tests · 2 ratings
Brake test: 20 to 0 mph
Measured
The Tektro HD-M3120 two-piston hydraulic discs with 180 mm rotors stopped the ADV from 20 mph in 20.5 feet, 0.6 feet above the 19.9-foot average of the commuter e-bikes we have tested and fourth of five in this comparison group, ahead of the Level 4 REC's 22 feet. The brakes are adequate for everyday riding without standing out.
The full stop, seen from above: at rest 20.5 feet from the 20 mph mark.
Braking distance, 20–0 mph
Feet · shorter is better
Aventon Level 4 REC22 ft
Aventon Level 4 ADV20.5 ft
TENWAYS AGO X20 ft
Himiway Rambler18.5 ft
Aventon Level 318 ft
Aventon Level 4 ADVComparison bikesAverage of similar bikes (19.9 ft)
Where the ADV sits: braking distance
Compared to the 23 commuter e-bikes we have tested
ADV
16.5 ft (best commuter result)Braking distance25.5 ft (longest)
ADV: 20.5 ftAverage of similar bikes: 19.9 ftFourth of five in the comparison group
The Aventon Level 4 ADV's front Tektro HD-M3120 hydraulic caliper and 180 mm rotor
Tektro HD-M3120 two-piston calipers on 180 mm rotors: 20.5 feet from 20 mph.
Brake feel and modulation3/5Acceptable. 20.5-foot stop from 20 mph.
Lights, signals, and visibility
Measured
The ADV comes with an integrated headlight and a taillight with turn signals, but no brake light, a disappointing omission on a commuter. On our center-beam measurement the headlight put out 460 lux at 15 feet, below the 579 lux average of the 17 e-bikes we have measured.
The taillight: turn signals built in, but no brake light.
The Aventon Level 4 ADV's integrated headlight lit, seen from the front with the handlebar above it
The integrated headlight: 460 lux at 15 feet.
Headlight: 460 lux @ 15 ftAverage: 579 luxBrake light: NoTurn signals: Yes
Reflectives and side visibility5/5Reflective sidewalls on both tires and a reflector in each wheel.
Ride Quality and Handling
1 descriptor · 8 ratings
Riding the Level 4 ADV
The first thing you notice is how natural the power delivery feels: the Ultro S matches its output to your input, and with the wide range of the 10-speed CUES we could hold a steady cadence and get the most out of the mid-drive. The slightly forward-leaning but straight-backed position kept us comfortable through almost four hours on the range test.
Rider's view on a residential road.
Overall comfort and composure5/5Comfortable through almost four hours on the range test.
Cornering and agility4/5Quick and predictable in corners, and stable through them.
Descending confidence5/5Very stable on fast paved descents, with minimal fork dive.
Riding unpowered3/5Possible without assistance, but the electronic shifter needs power, so a flat battery means you're stuck in one gear.
Stability at top speed
Rated
On our stability run we ride straight at top speed, shift our weight, and shake the bike to see whether a wobble starts. The no-hands check is done separately, at lower speed on level ground, to see that it tracks straight.
Stability at top speed5/5Stable while cruising in the mid 20s in Class 3 mode, and it tracks straight.
Comfort, suspension, and vibration
Rated
Suspension comes from a basic 100 mm coil fork with preload adjustment and a lockout, plus a 50 mm suspension seatpost under the Aventon saddle. The seatpost takes the sting out of rough pavement. The fork is stiff and slow to respond, and we hoped for better on a bike at this level.
The Aventon Level 4 ADV's 100 mm coil fork crown and preload dial from the front
The 100 mm coil fork: preload adjustment and a lockout, but stiff and slow.
The Aventon Level 4 ADV's saddle on its suspension seatpost, seen from the side above the rear rack
The 50 mm suspension seatpost under the Aventon saddle.
Saddle comfort4/5Comfortable overall, helped by the suspension seatpost.
Grips and pedals4/5Ergonomic lock-on grips stay put, and the large composite pedals grip well.
Suspension, fork2/5A basic 100 mm coil fork with preload adjustment and a lockout: stiff and slow to respond.
Riding position
Descriptor
Where the ADV sits on the spectrum from fully upright to fully aggressive. The 680 mm bar with a 30 mm rise gave us a slightly forward-leaning but straight-backed position:
Fit and Sizing
2 measurements · 2 checks · 2 ratings
True to size?
Verdict
Aventon makes the step-over ADV in three sizes, and the size L we tested is listed for riders from 5'10" to 6'4", a 6-inch span served by 7 inches of saddle-height adjustment (35" to 42" from the ground, measured on our test bike). By our rule of thumb that span is likely. At 6'0" with a 33" inseam we found the bike fit well.
Scott on the size L Aventon Level 4 ADV on a gravel path, seen from the drive side
Scott, 6'0", on the size L. The saddle adjusts between 35 and 42 inches from the ground.
MeasurementAventon claimsWe found
Rider height range, size L5'10"–6'4"6'0" fits well; the ends of the range untested
Saddle height, ground to top of saddle—35"–42" (889–1,067 mm), 7" of adjustment, measured on our test bike
Fits our tester (6'0", 33" inseam)Inside the claimed rangeYes, comfortably
Claimed height range accuracy6" span on 7" of travel(6 − 2) ÷ 7 = 0.6×, inside our 2.0× limit
Standover29.3" (743 mm)As published
Our verdictSize L fits 5'10"–6'4"Plausible
True to size5/5Seatpost travel easily covers Aventon's 5'10" to 6'4" range for the size L.
Cockpit adjustability
Rated
The 680 mm bar has a 30 mm rise and carries the A280 display in the middle, the control pad on the left grip, and the electronic shifter on the right. With the saddle set for a 33" inseam, we had a slightly forward-leaning, comfortable position.
The Aventon Level 4 ADV's whole cockpit from the rider's side: both grips, the display in the middle, the control pad and the shifter
The cockpit: 680 mm bar, central display, control pad on the left, electronic shifter on the right.
Cockpit adjustability5/5An angle-adjustable stem makes the cockpit easy to fine-tune.
Build and Components
1 test · 6 ratings · facts
Weight, verified
Measured
Aventon lists the ADV at 61 lb. Our scale read 65.4 lb as shipped, 7.2% over the claim. That is still second-lightest in this comparison group and 0.5 lb under the 65.9 lb average of the commuter e-bikes we have weighed. Aventon rates the payload at 300 lb.
Measured weight, as shipped
Pounds · lighter is better
Aventon Level 373.6 lb
Aventon Level 4 REC69.3 lb
Himiway Rambler67.0 lb
Aventon Level 4 ADV65.4 lb
TENWAYS AGO X61.0 lb
Aventon Level 4 ADVComparison bikesAverage of similar bikes (65.9 lb)
Where the ADV sits: measured weight
Compared to the 20 commuter e-bikes we have weighed
ADV
54.5 lb (lightest commuter e-bike)Measured weight88.6 lb (heaviest)
Measured: 65.4 lb · accessories fittedClaimed: 61 lb7% over the claimSecond-lightest in the group
Rated
The 6061 aluminum frame comes as a step-over in three sizes or a step-through in two, with the battery inside the down tube and the cables routed internally. We tested the size L step-over. The fenders, rack, and lights are fitted at the factory, and the whole bike felt solid and well put together.
The Aventon Level 4 ADV from the non-drive side in the BikeRide studio
The size L step-over from the non-drive side. A step-through version is also sold.
The Aventon Level 4 ADV's kickstand on the chainstay, from the non-drive side
The kickstand on the chainstay.
Frame welds and finish5/5Clean welds, good paint and well-aligned parts. Solid build quality.
Cable and wire integration5/5Mostly internal routing. Very tidy.
Rattles and squeaks5/5Quiet. No rattles, creaks, or squeaks in testing.
Drivetrain and shifting
Rated
Shifting is handled by a 10-speed Shimano CUES derailleur with an electronic shifter and AutoShift, plus a 48t chainring and an 11–39t cassette. AutoShift was quick and clean on flats and rolling terrain. On steep climbs it was slower than we would like and sometimes a gear away from our preferred cadence, so there we shifted manually. Stopping comes from Tektro HD-M3120 two-piston hydraulic discs with 180 mm rotors.
The CUES derailleur shifting.
The Aventon Level 4 ADV's 48t chainring behind its guard, with the crank and a composite platform pedal
The 48t chainring behind its guard, and a platform pedal.
Shifting performance4/5Quick and clean. In AutoShift mode, slightly slower than we would like on steep climbs.
Tires and accessories
Rated
The 27.5×2.2" Kenda K1052 tires sit on double-wall aluminum rims with 36 spokes. Included are full-coverage fenders, a rear rack rated for 59 lb, a kickstand, and the integrated lights with turn signals. There is no brake light.
The Aventon Level 4 ADV's rear rack and rear fender from the non-drive side
The rear rack, rated for 59 lb, and the rear fender.
The Aventon Level 4 ADV from behind in the studio with the taillight lit
From behind: the taillight lit, with turn signals but no brake light.
Tires3/5Acceptable for the terrain.
Included accessories4/5Full fenders, a 59 lb rear rack, and integrated lights with turn signals, but no brake light.
✓ UL 2849 electrical system, UL 2271 battery✓ IPX6 bike, IP67 motorFrame:  step-over in three sizes or step-through in two
Display, Controls, and App
3 ratings · facts
Display and controls
Rated
The Aventon A280 display is mounted centrally, and it is bright, clear, and easy to read in direct sunlight. The control pad sits on the left grip and the electronic shifter on the right, and the display's settings hold AutoShift and the rear-wheel lock. During the range test the display's estimate ran a little optimistic, showing around 62 miles for most of a ride that ended at 58.01.
Toggling Auto mode on the display.
The Aventon Level 4 ADV's left grip with the control pad, and the display beyond it, seen from the saddle
Left side: the control pad, with the display beyond it.
✓ Readable in direct sunlight✓ Display-activated rear-wheel lockRange estimate:  about 62 mi shown, 58.01 ridden
Display readability5/5Bright, clear, and easy to read in direct sunlight.
Controls5/5Well laid out and intuitive.
Companion app
Rated
The Aventon app paired quickly. Ride Tune gives full control of each assist level, the speed limits, and the Auto mode and AutoShift settings, and a throttle can be added, sold separately. Aventon's ACU smart features (GPS tracking, geofencing, the rear-wheel lock, and a remote phone lock) are free for the first year and need a subscription after that.
Ride Tune in the app: assist levels, speed limits, Auto mode, and AutoShift.
✓ Ride Tune: per-level assist and speed limits✓ Auto mode and AutoShift settings✓ 4G and GPS tracking, geofencingSmart features:  subscription after the first year
Companion app5/5Quick to pair. Ride Tune controls each assist level, the speed limits, Auto mode, and AutoShift.
Assembly and setup
Rated
The ADV arrived almost ready to ride: we attached the bars, front wheel, and pedals, and charged the battery. Aventon includes the instruction manual and the tools. Our factory audit found no issues.
The manual comes in the box.
The Aventon Level 4 ADV standing in its open shipping box in the BikeRide studio
Out of the box.
Assembly difficulty5/5Quick and easy.
Manual and documentation5/5A detailed, easy-to-follow manual with everything needed for setup.
Support response, tested
Measured
Every brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Aventon the first useful answer arrived after half an hour, far quicker than the 18.1-hour average across the brands we have tested.
First useful reply: 0.5 hAverage across brands: 18.1 h
Rated
The mechanical side is standard: a Shimano CUES 10-speed drivetrain, Tektro hydraulic brakes, and 27.5" tires in a common size. The Ultro S motor, the battery, and the display are Aventon's own. Aventon covers the bike with a two-year warranty and the frame for life.
Maintenance burden3/5Typical upkeep for a hardtail with a coil fork.
Serviceability and parts2/5Standard brakes and tires, but the electronics, display, and control pad are Aventon-only.
Component level for the price
Rated
A mid-drive with 100 Nm, an 800 Wh UL-certified battery, a 10-speed CUES with electronic AutoShift, hydraulic discs, a bright display with 4G and GPS, and a full set of commuter accessories. The basic coil fork is the one component that falls short of the rest.
Component level for the price4/5A mid-drive motor and electronic automatic shifting for a good price.
Value for money
Rated
Weighing everything we measured against the price at the time of publication: the longest range in our comparison group, the quietest motor we have measured, 6 seconds to 20 mph, automatic shifting and assist that work well, and every commuter accessory but a brake light. Against that, a basic fork and a higher weight than claimed. The Level 4 ADV made a strong case for its value.
Scott riding the Aventon Level 4 ADV toward the camera along a gravel trail through woods
Scott on the ADV on a gravel trail.
Value verdict5/5A well-rounded mid-drive commuter at a competitive price.
Warranty:  2 years, lifetime frame warranty with registrationSmart features:  free for the first year, then a subscription
Data
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 90 e-bikes we have tested.
TestAventon Level 4 ADVThis bikeAverage of similar bikesSimilarBikeRide averageAll bikes
Motor and performance
0–20 mph, max pedal assistvs. 7 other mid-drive e-bikes6.0 s7.3 s8.4 s
Gradual hill climb, 20 mph capvs. 5 other mid-drive e-bikes3:103:133:18
Steep hill climbvs. 5 other mid-drive e-bikes2:322:492:36
Motor noise @ 20 mph, unloadedvs. 16 other e-bikes48.0 dB(A)66.6 dB(A)66.6 dB(A)
Assist engagement delayvs. 15 other e-bikes0 crank rev0.2 crank rev0.2 crank rev
Range and charging
Range (medium assist, the ADV in Auto mode)vs. 13 other commuter e-bikes58.01 mi41.8 mi39.2 mi
Range vs claimedvs. 21 other commuter e-bikes53%60%55%
Efficiency (medium assist)vs. 13 other commuter e-bikes13.8 Wh/mi16.6 Wh/mi19.2 Wh/mi
Charge time 0→100%vs. all e-bikes tested5.5 h6.3 h6.3 h
Braking and safety
Brake test, 20–0 mphvs. 22 other commuter e-bikes20.5 ft19.9 ft19.3 ft
Headlight @ 15 ftvs. 16 other e-bikes460 lux579 lux579 lux
Build and ownership
Measured weightvs. 19 other commuter e-bikes65.4 lb65.9 lb74.6 lb
Battery weightvs. 13 other e-bikes9.2 lb11.7 lb11.7 lb
Support response, tested (weekday hours)vs. 31 other brands0.5 h18.1 h18.1 h
Similar bikes: mid-drive e-bikes for acceleration and the climbs; commuter e-bikes for range, efficiency, braking, and weight; all e-bikes for the other rows; support is averaged per brand. Range and efficiency compare our Auto-mode run with medium-assist runs. Charge time is calculated from charger output and battery capacity. Not run on the ADV: a maximum-assist range test, GPS top speed, speedometer accuracy, and a timed assembly.
Compare it with every bike we've tested
Range, hill climbs, braking and 31 ratings in one sortable table.
Bike Test Results
Detailed specs
As published by Aventon for the Level 4 ADV step-over we tested, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
E-bike system
Electric bike classClass 1 as shipped, Class 2 or 3 in the app (see Speed settings)
MotorAventon Ultro S mid-drive, 250W nominal, 750W peak
Max torque100 Nm (claimed)
Battery36V 20Ah (800 Wh) as listed, Samsung cells, removable, the label on ours reads 22Ah
Range claimedUp to 110 miles (Eco mode, 165 lb rider, flat pavement)
Top speed20 mph as shipped, 28 mph in Class 3 (claimed, not GPS-verified)
ThrottleNone fitted, sold separately
Pedal assistEco, Sport, Turbo, and Auto, tunable in the app (Ride Tune)
SensorDual-sided torque sensor
Charger42V 4A
Charge time5 hours claimed, 5.5 hours calculated
DisplayAventon A280
CertificationUL 2849 (electrical system) and UL 2271 (battery)
Water/dust ratingIPX6 bike, IP67 motor
Warranty2 years, lifetime frame warranty with registration
Smart features4G and GPS tracking, geofencing, display-activated rear-wheel lock, remote phone lock, activity alerts; subscription after the first year
Components
Frame6061 aluminum, step-over (tested) in M, L, and XL or step-through in two sizes
Fork100 mm coil suspension, preload adjustment and lockout, 15×100 mm thru-axle
BrakesTektro HD-M3120 two-piston hydraulic, 180 mm rotors
DrivetrainShimano CUES 10-speed, electronic shifter with AutoShift
Chainring / cassette48t / 11–39t
Rims / tires27.5" double-wall aluminum, 36 spokes / 27.5" × 2.2" Kenda K1052
Handlebar680 mm, 31.8 mm, 30 mm rise
GripsAventon lock-on
SaddleAventon, on a 50 mm suspension seatpost
PedalsComposite platform
LightsIntegrated headlight and taillight with turn signals, no brake light
FendersFull-coverage, included
Rear rack / kickstandRack rated for 59 lb and a kickstand, included
Payload capacity300 lb
Geometry details
As published by Aventon for the size L. ✓ measured = Aventon doesn't publish this figure, so it's our own measurement. ✗ = Aventon's published figure is more than 3 mm from what we measured.
MeasurementSize L (tested, claimed 5'10"–6'4")
Seat tube19.0" (483 mm)✗ Aventon: 450 mm
Reach17.5" (445 mm)As published
Stack25.7" (652 mm)As published
Standover height29.3" (743 mm)As published
Virtual top tube24.9" (632 mm)As published
Head tube angle69°As published
Seat tube angle74°As published
Chainstay18.9" (480 mm)As published
Wheelbase47.0" (1,195 mm)As published
Saddle height, min–max35"–42" (889–1,067 mm)✓ measured
More
Video review
Watch Scott's full 9-minute review of the Aventon Level 4 ADV, including footage from every test above, on BikeRide's YouTube channel.
Lead E-Bike Tester · 90+ bikes tested
This bike was supplied by Aventon for testing. Manufacturers never see our reviews before publication and cannot pay for a score. We earn a commission on purchases made through links on this page. It never affects results.
