View all prices
Show fewer prices
Type
5 Hours
75 Miles
26 mph
160 Nm
48V 23.4Ah
84.5 lb
We have read all expert and user reviews on the Vintage Electric Bikes Tracker Classic. In summary, this is what cyclists think. Published Aug 27, 2025 by Reda Ashour.
- A tester enjoys the quick, powerful acceleration and responsive pedal assist and throttle engagement.
- Climbing hills is easy thanks to the motor's strong low-end torque output, says an expert.
- The plush saddle, thick grips, 2.35” Schwalbe Fat Frank tires, and steel handlebars make for a comfortable ride, according to a reviewer.
- The standard saddle and seatpost combination allows seat height adjustment, unlike most other motorcycle-style e-bikes.
- The single-speed drivetrain and external cabling simplify maintenance.
- A tester appreciates the stopping power from the Promax Lucid hydraulic disc brakes.
- A reviewer admires the solid build quality, quiet ride, and sleek aesthetic.
- The Tracker Classic comes with color-matched fenders and a chainguard and lights.
- The 5A charger fills the battery in under five hours, but it's large and heavy.
10 reasons not to buy
- The Tracker Classic is recommended for heights from 5’2” to 6’4”, but shorter riders won't clear the 30.5" standover height.
- Handlebar height isn't adjustable, and the custom stem cannot be easily swapped.
- At 84.5lb, the Tracker Classic is heavy.
- The single-speed drivetrain is limiting when starting from a stop and climbing, and it prevents pedaling at high speeds.
- The battery isn't removable, so charging may be inconvenient.
- An expert says the motor’s magnetic drag is noticeable when pedaling unassisted or using regenerative braking.
- The dual crown fork creates a wider turning radius.
- A reviewer finds the externally routed cables messy in some areas.
- The product webpage is missing several important specifications.
- The frame doesn't have a bottle cage mount.
The Vintage Electric Bikes Tracker Classic is a motorcycle-style e-bike with a 750W motor and 1,123.2Wh battery. In the sole review, the Tracker Classic is praised for its stylish looks, powerful and quiet motor, comfort, strong brakes, and stable, smooth ride. The single-speed drivetrain limits pedaling, and the regenerative braking adds drag. Buyers may also be deterred by the single frame size with limited adjustability, high weight, and non-removable battery. The Tracker Classic is a polished product, but the lack of detailed specifications is disappointing at this high price point.Expert Reviews
81/100 based on 1 scored reviewVintage Electric Tracker Classic Review
Best Electric Bike
#40
Best Moped Bike
Bottom 20%
#654
Best of All Bikes
Vintage Electric Bikes Tracker Classic in comparison to averages
3 hours ago
14 hours ago
