We earn affiliate commission.
Learn more
4, 6, 7 Hours
65 Miles
25, 20 mph
55 Nm
48V 14Ah
64.0 lb
We have read all expert and user reviews on the Lectric XP 2.0 Long-Range. In summary, this is what cyclists think.
15 reasons to buy
- The Long-Range offers up to 65mi of range - 45% more than the original XP 2.0.
- A 500W motor belts out a reported 850W of power at its peak.
- The Long-Range is available in both step-through and high-step frame options.
- Like the O.G. XP 2.0, the Long-Range folds down to measure 37” x 18” x 28”.
- The Long-Range Step-Thru is highly accessible to riders of all abilities.
- To fine-tune rider height, the Long-Range’s handlebars are vertically adjustable.
- Testers say the XP 2.0 Long-Range smashes its way up steep hills.
- The bike’s Class 2, 20mph default setting can be overridden to reach 25mph.
- A 40mm-travel suspension fork soaks up moderate off-road judder.
- 3” wide tires help to absorb surface jounce.
- Front and rear integrated lights come included.
- A big 52t chainring insures against spinning-out, when pedaling at higher speeds.
- The bike is fitted with an unspecified model of 7-speed Shimano drivetrain.
- The display’s screen features big characters and is visible in sunlight.
- Color-matched fenders are packed-in.
- The included 2-amp charger takes 7 hours to fully charge the Long-Range.
- An expert says the bike’s rear light isn’t so great.
- High-step and step-through model batteries can not be interchanged.
- Step-through color options are limited to black or white. In high-step? Only black.
- This chunky treadly weighs in at 64lb. Lift at your peril.
The Lectric XP 2.0 Long-Range is an updated version of the Lectric XP 2.0. In place of the original 48V 9.6Ah / 460Wh battery, this beast rocks 48V 14Ah at 672Wh, to offer buyers a reported maximum range of 65 miles. Compared to the cost of the standard XP 2.0, expert testers saw the additional price as minimal. It’s available in both step-through and high-step models. With a base-model 2-amp charger, that beefy battery will take seven hours to fully recharge. The 64lb heft will take a strong back to lift. This battery upgrade addresses one of the main gripes coming from XP 2.0 owners.Expert Reviews
92/100 based on 1 rated expert reviewLectric XP 2.0 Long-Range Review: Quash Your Range Anxiety
Introduction to the Lectric XP™ Step-Thru 2.0 Black Long-Range E-Bike
Lectric E-Bikes Launches New 45% Larger Battery for Popular Low-Cost Lectric XP 2.0 and 1.0 E-Bikes
Electric Bikes for Hunting?
Lectric XP 2.0 Long-Range in comparison to averages
