Stinner Frameworks Refugio Select
77/100
23 lb
We have read all expert and user reviews on the Stinner Frameworks Refugio Select. In summary, this is what cyclists think. Updated Jul 18, 2026 by Jordan Grimes.
  • The Stinner Refugio Select is available as a complete bike or a frameset, in six sizes and two colors.
  • The frame is hand-welded, finished, and assembled in Santa Barbara, California.
  • At around 23lb (size 56), the Refugio Select is relatively light for a steel gravel bike.
  • The wide 10-52t MTB cassette is ideal for tackling steep climbs, particularly with cargo.
  • The Refugio Select accepts 1x or 2x mechanical drivetrains and has clearance for 50mm tires (45mm with fenders).
  • The frame has mounts for three bottle cages and fenders, three-pack mounts on the fork legs, and routing for a dynamo front light.
  • This bike ships with the tires set up tubeless, including the sealant.
  • Stinner provides a lifetime frame warranty for the original owner.
2 reasons not to buy
  • The tester says that the cheaper Surly Straggler is much more plush than the Stinner, even with a carbon fork and wider tires.
  • The Easton EA50 handlebar is harsh, according to the reviewer.
The Stinner Refugio Select is a hand-welded steel gravel bike available with SRAM Apex mechanical or as a frameset. There is only one expert test. In it, they praise the gearing and modern geometry that encourages exploring singletrack. The weight is also relatively low for steel. However, the thin aluminum handlebar is harsh, and the ride is overall less plush than expected. Overall, this bike, especially the frameset, seems worth considering for those who want US-made steel, but additional testing is required for a stronger conclusion.
80/100 based on 1 scored review
The Ride with Ben Delaney
‘Merican Metal: Surly Straggler vs Stinner Refugio Gravel Bikes Tested in New Mexico
Cruising around in town and then creeping up the steeps, that low low gear felt great. [But] the cockpit didn’t feel so great to me. A little bit on the stiff and skinny side.
Stinner Frameworks Refugio Select in comparison to averages
