If this lock is out of stock, take a look at our other highly rated bike locks.
We earn affiliate commission.
Learn more
We have read all expert and user reviews on the SkunkLock Chemical V2. In summary, this is what cyclists think.
13 reasons to buy
- The SKUNKLOCK contains a vile, vomit-inducing chemical compressed within its shackle. This will release directly toward a thief who attempts to cut it.
- Prominent warnings of a noxious chemical and scent act as a strong theft deterrent.
- Owners describe successfully thwarted attempts at cutting their SKUNKLOCK.
- The SKUNKLOCK is multiple-use. Replacement shackles are available after being cut by a thief.
- At 24 mm wide, most bolt cutters can’t fit around the SkunkLock’s shackle.
- Reviewers and owners say the SKUNKLOCK’s brawn acts as a theft deterrent.
- Testers say the SKUNKLOCK provides ample room to lock their bike’s frame & tire to stationary objects.
- The SKUNKLOCK’s shackle is double-bolted for extra security.
- Testers and owners say the SKUNKLOCK is easy to use & quick to open and close.
- The SKUNKLOCK comes with 3x keys and a code that allows owners to order replacements.
- The SKUNKLOCK’s disc cylinder uses false gates to resist drilling and picking attempts.
- Experts say the SKUNKLOCK is lighter than U-Locks of similar dimensions.
- Owners say SkunkLock replaces faulty parts swiftly.
- Users and testers note the 4 lb weight of this lock. No frame mount is supplied.
- The 24 mm-diameter shackle has 4 mm hardened steel walls.
- A few owners said their locks’ end-caps broke.
- Skunklock only supply the SKUNKLOCK with a 30-day limited warranty.
- An owner’s lock burst after traveling between areas of radically different air pressure and temperature. Another’s leaked after 5 months of use. SKUNKLOCK issued replacements.
Experts approve the SKUNKLOCK, saying it addresses conventional security concerns while accommodating an innovative extra element. Inside the SKUNKLOCK’s hollow shackle is a compressed noxious gas composed of “food-grade and non-lethal chemicals” found in Parmesan cheese, rancid butter, and apparently, vomit. Owners are happy with the extra weight, as a trade-off for its ‘smell-deterrence’ and beefiness. Some folk do express concern about the legal repercussions of using this lock.Expert Reviews
83/100 based on 2 rated expert reviewsSKUNKLOCK: The Bike Lock That Bites Back!
SKUNKLOCK Review – The Beginning of the End for Bike Thieves?
This Bike Lock Fights Back… But Is It Legal? (SKUNKLOCK)
Bike Lock That Releases Skunk Smell
Best Bike U-Locks
U-locks with the highest BikeRide Scores
Bike Lock Comparison
SkunkLock Chemical V2 in comparison to averages
Discuss which bike lock to choose in the forum
24 hours ago
2 days ago
2 days ago
