SCOTT Spark Review
Scott Clough-Carroll, Bike Testing and Video Production By Scott Clough-Carroll, updated Oct 28, 2026 | Tested using BikeRide Methodology 1.1 First-Hand Test
Our verdict
The Spark 970 is the 2024 entry-level build of SCOTT's 130/120 mm downcountry bike. In testing, we found it to be an efficient climber and capable on blue and black flow trails, jumps and small drops. Its TwinLoc remote switches the suspension between three modes from the bar. The two-piston brakes limit speed on steep descents, and the tires slip in the wet. Plan to upgrade the tires and brakes, but suspension upgrades are limited.
  • Efficient climber, quick to accelerate
  • Confident on blue and black flow trails
  • Three suspension modes, switchable from the bar
  • Stable and planted at speed
  • Hidden shock and internal cables look clean
  • Delivered tuned and mostly assembled
  • Two-piston brakes lack power on steep descents
  • Rotors take resin pads only
  • Tires lack grip in the wet and aren't tubeless-ready
  • TwinLoc and the NUDE shock limit suspension upgrades
Claimed vs. measured
SCOTT describes the Spark 970 as a "lightweight and ultra capable" short-travel trail bike. We checked the claims we could test on our size L. Here is the spec sheet next to what we found:
ClaimSCOTT saysWe measuredVerdict
WeightApprox. 14.95 kg (32.96 lb), with tubes34.2 lb (15.5 kg), size L, without pedals✗ Misleading
Adjustable head angle±0.6° with the Syncros Acros headsetWe rode both settings, 65.8° and 66.4°✓ Verified
Fits our tester (6'0", 33" inseam)Sizes S, M, L and XLSize L, with a comfortable seated position✓ Yes
Claimed height range accuracyA 4" span of rider height on 10" of saddle-height adjustment(4" − 2") ÷ 10" = 0.2×, inside our 2.0× limit✓ Verified
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Who should buy the Spark 970
We believe the SCOTT Spark 970 is a good choice for:
  • Riders who enjoy climbing as much as descending. The 76.4° seat angle puts you over the cranks, and Traction Control cuts rear travel to 80 mm for climbs and fast XC riding (climbing).
  • XC riders who want a bit more travel. The Spark was stable on blue and black flow trails, jumps and small drops (descending).
  • Riders who will keep it mostly stock. New tires and brakes are obvious upgrades, but the frame, geometry and TwinLoc are a strong base (the upgrade question).
On forest singletrack: light and responsive.
Who should NOT buy it
  • Riders who plan to upgrade the suspension. The TwinLoc dampers and the NUDE shock aren't sold aftermarket, so better suspension means giving up TwinLoc.
Before you buy: the upgrade question
Is the Spark 970 a good choice for riders who plan to upgrade? The answer is complicated, because it depends on which parts you plan to change.
  • Tires come first, and they're easy. The rims are tubeless-ready, the wire-bead tires are not. We'd like to try the Wicked Will SuperTrail in ADDIX SpeedGrip, set up tubeless at a lower pressure (tires).
  • Brakes are the next fix. The rotors take resin pads only, so metallic pads mean new rotors too. That should improve braking a lot without costing much (braking).
  • Suspension is the hard one. TwinLoc needs SCOTT's own dampers and the NUDE shock needs a bespoke air valve, and neither is sold aftermarket. That leaves another shock that loses TwinLoc and can't be adjusted in the frame.
If you plan to keep it stock or change only the tires and brakes, the 970 makes sense. If the suspension might limit you in the future, a higher-end Spark build may be the better choice.
Tests and Measurements
How we test
We assemble, check and ride every bike we review, and rate it 1–5 against written anchors, never a gut feeling. E-bikes also go through range tests to motor shutoff, two hill climbs, acceleration, braking, and a verified weigh-in, all stored in our database. The Spark has no motor, so those tests don't apply, and our database doesn't hold enough non-electric bikes for averages yet. This review rests on a weigh-in, a factory assembly audit, our trail notes and anchored ratings. Read the full BikeRide Methodology 1.1 →
Test conditions — this review
Tester
6'0", 33" inseam
Rider + gear
200 lb rider
Weather
41–48°F, variable clouds and rain
Wind
3.5 mph
Tires
29×2.4" with tubes, 24.5 psi front, 25.5 psi rear
We tested the Spark 970 in November 2025.
Score breakdown — how the 88 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the findings and ratings listed under it, with rated items scored against their written 1–5 anchors. Nothing from outside this page goes in, and every finding and rating on this page sits under one of the five pillars:
88/100 = 90×30% + 80×25% + 90×20% + 90×15% + 90×10%, rounded. What feeds each pillar depends on the bike: a non-electric bike skips the motor, range and charging tests entirely, so Performance here rests on how the Spark climbed, descended and cornered. Facts and context (specs, geometry, riding position) inform the review. Full mapping in the methodology.
Trail Performance
1 verdict · 3 ratings · facts
Climbing
Verdict
We climbed everything from long, grinding doubletrack to punchy XC singletrack, and the Spark was an effective climber, quick to accelerate and easy to keep at speed. The 76.4° seat angle puts you forward over the cranks for good power transfer, and the seated position was comfortable. Traction Control or Lockout (TwinLoc) firms up the suspension for climbs. Climbs were almost as much fun as the descents.
Leaf-covered XC singletrack. The Spark is quick to accelerate and easy to keep at speed.
Scott riding the SCOTT Spark 970 standing on the pedals through a mossy forest, seen from the drive side
Standing on the pedals.
Descending
Rated
Given its 130/120 mm travel and budget suspension, the Spark surprised us on descents. Our tester normally rides a 170/150 mm enduro bike. The long wheelbase contributed to a stable, planted feel at speed, and the bike was easy to control through rough sections. It felt well matched to blue and black flow trails, handled jumps and small drops, and took us down descents we hadn't expected to ride. The limit came from the brakes.
The rider's view on a descent: stable and easy to control through rough sections.
Small drops and jumps were well within the Spark's range.
Descending confidence4/5Comfortable and stable on blue and black flow and jumps. Brakes hold it back on the steepest descents.
Stability at top speed5/5Long wheelbase helped keep it calm at speed.
Cornering and agility
Rated
The Spark carves stable arcs at high cornering speeds with reasonable traction in most conditions, and you can preload it and hold a line with confidence. It was just as easy to maneuver through technical low-speed sections, and the 760 mm bar gave plenty of leverage in turns. Large loose rocks and gravel threw it around, and on wet roots, the tires lacked bite.
Through a berm and past the camera. You can preload and hold lines with confidence.
Low view of Scott cornering the SCOTT Spark 970 on a pine-forest trail
Easy to maneuver at speed.
Cornering and agility5/5Stable arcs at speed and easy to maneuver in tight trees.
Head angle: two settings
Fact check
The adjustable Syncros Acros headset sets the head angle at 65.8° or 0.6° steeper, at 66.4°. Switching is easy: remove the handlebar and spacers and rotate the headset cups 180°. We rode both. The steeper setting quickened the steering but cost confidence on descents and in fast corners, so we preferred the stock 65.8°.
Scott's hands at the SCOTT Spark 970's head tube with the stem off and the headset spacers lifted
Bar and spacers off: rotate the Acros cups 180° to switch between 65.8° and 66.4°.
Stock:  65.8°Steep:  66.4°✓ Both ridden, stock preferred
Suspension and Setup
1 measurement · 3 ratings
TwinLoc remote
Rated
TwinLoc runs both ends of the suspension from the remote on the left of the bar, shared with the dropper post. It has three modes: Descend, Traction Control and Lockout. Traction Control cuts rear travel to 80 mm and firms the suspension, smoothing rocks and roots while keeping power transfer high, which makes it great for climbs and fast XC riding. We mostly switched between Descend and Traction Control and used Lockout now and then on smooth doubletrack climbs.
A hand on the SCOTT Spark 970's left grip, with the TwinLoc and dropper levers below the bar
TwinLoc and dropper levers sit under the left grip. We found them easy to use.
Flip the lever to switch modes on the move: Descend, Traction Control or Lockout.
Controls4/5Three suspension modes from the remote under the left grip, beside the dropper lever. Easy to use.
Setup and sag
Measured
SCOTT recommends 25% sag for general trail riding. At 200 lb, our tester tried 30% and 25% before settling between them at about 27.5%, which gave him full travel without bottoming the shock. Rebound stayed at four of five steps from slowest on the fork and three of six on the shock for all three sag settings.
The hidden NUDE shock is pumped up through a port under the frame.
SagFork / shockWhat we found
30%100 psi / 150 psiPlush over chatter and small hits. Bottomed the shock on hard impacts on black trails
25%, SCOTT's recommendation110 psi / 175 psiNo bottom-outs, but harsher over small bumps. Our pick for pure XC riding
About 27.5%, our setting106 psi / 165 psiFull travel without bottoming out easily
Rider: 200 lbOur sag: about 27.5%Fork / shock: 106 / 165 psi
Fork and shock
Rated
The 130 mm RockShox Judy Silver fork and the X-Fusion NUDE 5 shock adjust for air pressure and rebound, and TwinLoc handles compression. At 30% sag both were plush over chatter and small hits. At 25% the shock felt much firmer and trail chatter came through. The shock sits inside the frame at the base of the seat tube, protected from the muck thrown up by the rear tire.
The SCOTT Spark 970's RockShox Judy Silver fork crown with the TwinLoc cable running into its top cap
The 130 mm Judy Silver fork. The TwinLoc cable runs into it.
Suspension, fork3/5A decent basic XC fork, plush over chatter and small hits. Air pressure and rebound adjustments.
Suspension, rear shock3/5Decent performance. Perfect at 27.5% sag.
Ride Quality
1 descriptor · 4 ratings
Riding the Spark 970
Rated
The Spark feels light and responsive, and the seated position stayed comfortable whether we were climbing or powering along an XC trail. We rode it on wide doubletrack, tight XC singletrack and moderate to advanced flow and tech descents, much of it in the wet. It stays composed through rough downhill sections. Large loose rocks and gravel were the exception, where the bike got thrown around.
A damp boardwalk on our test trails.
Overall comfort and composure4/5Comfortable and composed, but big rocks can unsettle it.
Tires and traction
Rated
The 29×2.4" Schwalbe Wicked Will tires look great with their tan sidewalls, but this is the cheapest Performance version: ADDIX compound and a wire bead, so not tubeless-ready. At 24.5 psi front and 25.5 psi rear, grip was reasonable in most conditions, but they lacked grip on wet rocks and wood and often slipped on roots. On tubeless tires with a better compound, we don't normally have these problems on wet wood.
The SCOTT Spark 970's front wheel: Schwalbe Wicked Will tire with tan sidewalls, disc rotor and fork
Wicked Will Performance, 29×2.4": tan sidewalls, ADDIX compound and a wire bead.
Tires2/5Slippery on wet rocks, wood and roots, and not tubeless-ready. An early upgrade.
Saddle, grips, and pedals
Rated
The tan Syncros Tofino 2.5 saddle sits on a Syncros Duncan dropper post with 150 mm of travel on the L and XL frames, and the Syncros Performance XC grips lock on. Like the bar and stem, they are SCOTT's own Syncros brand.
The SCOTT Spark 970's tan Syncros Tofino 2.5 saddle on the Duncan dropper post
The Syncros Tofino 2.5 saddle on a 150 mm Duncan dropper (L and XL).
The SCOTT Spark 970's right grip: Syncros lock-on grip, brake lever and SRAM trigger shifter
Right side: Syncros Performance XC lock-on grip and the SRAM SX trigger shifter.
Saddle comfort2/5The Tofino saddle wasn't a great fit for our tester.
Grips and pedals4/5Lock-on grips stayed put and weren't slippery. No pedals included.
Riding position
Descriptor
Where the Spark sits on the spectrum from fully upright to fully aggressive. The 76.4° seat angle puts you forward over the cranks, and the Fraser bar's mini rise and back sweep bring the grips toward you.
Braking and Safety
1 rating
Rated
Shimano MT201 two-piston brakes with 180 mm SM-RT10 rotors are fine for XC riding, but the Spark 970 descends well enough to find their limits. On blue and black trails we know well, we entered corners faster than expected and struggled to brake hard on steep descents without locking the wheels, so we braked earlier and rode slower (upgrades).
The SCOTT Spark 970's Shimano MT201 front caliper on a 180 mm SM-RT10 rotor
Shimano MT201 two-piston caliper on a 180 mm rotor that takes resin pads only.
Brake feel and modulation3/5Fine for XC. We struggled to brake hard on steep descents without locking up.
Fit and Sizing
1 measurement · 2 checks · 2 ratings
True to size?
Verdict
We tested the size L. At 6'0" with a 33" inseam, we found the seated position comfortable on climbs and along XC trails, and the 470 mm reach kept the bike stable at speed. SCOTT's size chart puts the L at roughly 5'10" to 6'2", a 4-inch span served by 10 inches of saddle-height adjustment (23.5" to 33.5" from the bottom bracket, measured on our test bike). By our rule of thumb that span is plausible.
Our tester Scott, 6'0" with a 33" inseam, standing with the SCOTT Spark 970 on a forest trail
Scott is 6'0" with a 33" inseam. We tested the size L.
MeasurementSCOTT saysWe found
Size testedS, M, L, XLL
Saddle height, bottom bracket to top of saddle—23.5"–33.5" (597–851 mm), 10" of adjustment, measured on our test bike
Fits our tester (6'0", 33" inseam)—Yes, with a comfortable seated position
Claimed height range accuracyAbout 5'10"–6'2", a 4" span(4" − 2") ÷ 10" = 0.2×, inside our 2.0× limit
True to size5/5Saddle travel easily covers SCOTT's size L range of roughly 5'10" to 6'2".
Cockpit and adjustability
Rated
The 760 mm Syncros Fraser 2.0 bar has a mini rise and 8° of back sweep. We liked the shape more on climbs than on descents, but once we got used to it, the width gave plenty of leverage in turns without getting in the way between tight trees. The Syncros DC 3.0 stem is integrated with the headset and routes the cables into the frame.
The SCOTT Spark 970's 760 mm Syncros Fraser handlebar and integrated stem from the front
The 760 mm Fraser 2.0 bar has a mini rise and 8° of back sweep.
The SCOTT Spark 970's Syncros integrated stem and headset cover, with the cables entering below the stem
The Syncros DC 3.0 stem: the cables run under it, through the headset and into the frame.
Cockpit adjustability3/5Standard 760 mm bar on an integrated stem. Cables run inside.
Build and Components
1 measurement · 4 ratings · facts
Weight and component weights
Measured
SCOTT lists the Spark 970 at approximately 14.95 kg (32.96 lb) with tubes. Our size L weighed 34.2 lb (15.5 kg) without pedals, 1.2 lb (4%) over the claim. We also weighed the main components, below. The wheels and the SRAM SX drivetrain are the obvious places to save weight, at a price.
ComponentWeight
Whole bike, size L, without pedals34.2 lb (15.5 kg)
Frame, fork, shock, brakes and cockpit17.04 lb (7,730 g)
Front wheel, complete4.96 lb (2,250 g)
Rear wheel, complete6.62 lb (3,003 g)
Drivetrain: crankset, cassette, derailleur, chain4.63 lb (2,101 g): 791 / 720 / 340 / 250 g
Rim and hub, front / rear787 g / 865 g
Tire, tube, rotor (each)753 g, 158 g, 211 g
Measured: 34.2 lb without pedalsSCOTT: approx. 32.96 lb with tubes
Rated
The Spark Alloy SL 6011 aluminum frame has single-pivot rear suspension with 120 mm of travel. SCOTT hides the X-Fusion NUDE 5 shock inside the frame at the base of the seat tube, and every cable runs internally, so the frame cuts clean lines. With the blue paint and the tan sidewalls and saddle against black parts, it is a great-looking bike. There are bottle bosses on the seat tube and three-pack bosses on the down tube.
The SCOTT Spark 970 from the drive side on a leaf-covered forest trail
The aluminum frame in blue, with tan sidewalls and saddle. A great-looking bike.
The SCOTT Spark 970 from the non-drive side in the BikeRide studio
No shock in sight: it hides inside the frame at the base of the seat tube.
Frame welds and finish5/5Great welds, a clean, modern frame and a slick blue paint job.
Cable and wire integration5/5Fully internal, routed through the headset. Hidden shock.
Rattles and squeaks4/5Very quiet overall, apart from a minor cable rattle inside the frame.
Drivetrain and shifting
Rated
The 12-speed drivetrain is SRAM SX Eagle: a crankset with a 32t ring, the trigger shifter, the chain and an 11–50t cassette, with an NX Eagle derailleur. The range is plenty for climbing, and it worked reliably on our trails. A full-length rubber guard protects the chainstay.
The SCOTT Spark 970's SRAM SX 11–50t cassette and NX Eagle derailleur
SRAM SX-PG1210 cassette, 11–50t, with an NX Eagle derailleur.
The SCOTT Spark 970's SRAM SX Eagle crankset with a 32t chainring and the rubber chainstay guard
SX Eagle crankset with a 32t ring. A rubber guard covers the whole chainstay.
Shifting performance4/5Plenty of gearing for climbs. Reliable shifting on the trails.
Wheels
Fact check
Formula CL-811 and CL-3248 hubs are laced to Syncros X-30SE aluminum rims with 32 spokes each. The 30 mm internal width pairs nicely with the 2.4" tires, and the rims are tubeless-ready even though the tires are not. On our scale the rims and hubs weighed 787 g front and 865 g rear, 1,652 g for the pair.
✓ Tubeless-ready rims✗ Tires not tubeless-readyAxles:  15×110 and 12×148 mm
✓ Factory assembly audit: 0 issues on our unitMax system weight:  282 lb (128 kg), SCOTT's figureFrame:  aluminum, sizes S–XL
1 audit · 7 ratings
Unboxing, assembly, and factory audit
Rated
Unboxing was easy. The box opens at one end and the bike slides out on its cardboard tray, with minimal plastic in the packaging. It arrives mostly assembled, with a note on the down tube initialed by the SCOTT technician who built it. We aligned and tightened the stem, fitted the wheels and checked bolt torques. A tool kit, a shock pump and assembly documents come in the box, and SCOTT has an assembly video on YouTube.
Our factory assembly audit found nothing to fix: the wheels ran true, the brakes didn't rub, shifting was indexed, cables were routed correctly, fasteners were at the right torque and grease was where it belonged.
The SCOTT Spark 970 in its open box in the BikeRide studio, on its cardboard tray
Minimal plastic: the bike ships mostly assembled on a cardboard tray.
Open one end and slide the tray out. No need to lift the bike out of the box.
A tag on the SCOTT Spark 970's down tube, initialed by the technician who built the bike
A note on the down tube, initialed by the SCOTT technician who built our bike.
Factory assembly audit: 0 issuesAssembly time: not timed
Assembly difficulty5/5Mostly assembled: stem, wheels and a torque check.
Manual and documentation5/5Assembly documents in the box, and a SCOTT video on YouTube.
Included accessories5/5An impressive tool kit. Shock pump in the box.
Maintenance and parts
Rated
The drivetrain and brakes are SRAM and Shimano parts. The suspension is where it gets hard: TwinLoc needs special dampers and control units in the fork and shock, and the NUDE shock's air valve is a custom design for this frame. These parts aren't sold aftermarket, and it appears SCOTT won't sell upgraded versions separately.
Maintenance burden3/5Typical upkeep for a full-suspension bike. The hidden shock stays cleaner but is harder to service.
Serviceability and parts2/5Common drivetrain and brakes, but the TwinLoc dampers, NUDE shock and Syncros headset are SCOTT-only.
Component level for the price
Rated
For an entry-level build, the Spark 970 puts its money into the frame, the geometry and TwinLoc. The SX drivetrain is the usual choice at this level and does the job. The parts that hold the bike back are the MT201 brakes with resin-only rotors and the cheapest, wire-bead version of the Wicked Will tire.
Component level for the price4/5Capable frame and TwinLoc remote-adjustable suspension. Budget brakes and tires.
Value for money
Rated
Weighing everything we found against the price at the time of publication: a capable frame with excellent geometry, TwinLoc, and climbing and descending well beyond its entry-level label, but brakes and tires that need upgrading and suspension that is hard to upgrade. If tires and brakes are the only upgrades you plan, it offers great value.
Value verdict4/5Great value if you don't plan to upgrade the suspension.
Data
Full test results
Every measurement from this review in one table.
TestSCOTT Spark 970This bike
Build and weight
Weight as testedsize L, without pedals34.2 lb (15.5 kg)
Wheels, completefront / rear4.96 lb / 6.62 lb (2,250 g / 3,003 g)
Rims and hubsfront / rear787 g / 865 g
Drivetraincrankset, cassette, derailleur, chain4.63 lb (2,101 g)
Factory assembly audit0 issues
Fit and sizing
Saddle heightbottom bracket to top of saddle23.5"–33.5" (10" of adjustment)
Setup used on our trails
Sag, 200 lb riderfork / shock pressureAbout 27.5% · 106 / 165 psi
Reboundsteps from slowestFork 4 of 5 · shock 3 of 6
Tire pressurefront / rear, with tubes24.5 / 25.5 psi
Component weights are from our size L test bike. The setup rows record how we rode it.
Compare it with every bike we've tested
Measured weight and 22 ratings in one sortable table.
Bike Test Results
Detailed specs
As published by SCOTT for the Spark 970 in blue that we tested, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
Frame and suspension
FrameSpark Alloy SL 6011 aluminum, single-pivot rear suspension, internal cable routing
SizesS, M, L, XL (tested: L)
ForkRockShox Judy Silver TK Solo Air, 130 mm, 15×110 mm axle, 42 mm offset
Rear shockX-Fusion NUDE 5 RLX Trunnion, 165×45 mm, inside the frame
Rear travel120 mm, 80 mm in Traction Control
RemoteSCOTT TwinLoc 2: Descend, Traction Control and Lockout, plus the dropper lever
HeadsetSyncros Acros Angle Adjust, ±0.6° (65.8° or 66.4° head angle)
SeatpostSyncros Duncan Dropper, 31.6 mm, 150 mm travel on L and XL
SaddleSyncros Tofino 2.5 Regular
Bottle mountsBottle bosses on the seat tube, three-pack bosses on the down tube
Max system weight282 lb (128 kg) for bike, rider and gear (SCOTT's figure)
Components
DrivetrainSRAM SX Eagle 12-speed: SX trigger shifter, SX chain, NX Eagle derailleur
Crankset / cassetteSRAM SX Eagle DUB, 32t / SX-PG1210, 11–50t
Bottom bracketSRAM DUB PF92
BrakesShimano MT201 two-piston hydraulic, resin pads
RotorsShimano SM-RT10 CL, 180 mm front and rear, resin pads only
HubsFormula CL-811, 15×110 mm / CL-3248, 12×148 mm
RimsSyncros X-30SE, 32 holes, 30 mm internal width, tubeless-ready
TiresSchwalbe Wicked Will 29×2.4" Performance, ADDIX, wire bead
TubesMaxxis Ultra Thin
HandlebarSyncros Fraser 2.0, 760 mm, mini rise, 8° back sweep
StemSyncros DC 3.0, integrated, 60 mm on size L
GripsSyncros Performance XC lock-on
Geometry details
Size L, as published by SCOTT, for the stock 65.8° setting of the headset.
MeasurementSize L (tested)
Head tube angle65.8° (66.4° in the steep setting)
Seat tube angle76.4°
Reach18.5" (470 mm)
Stack24.3" (617.7 mm)
Wheelbase47.4" (1,205 mm)
Effective top tube24.1" (613 mm)
Seat tube19.3" (490 mm)
Standover height30.6" (778 mm)
Bottom bracket height13.1" (331.5 mm)
Trail4.2" (107 mm)
Stem length2.4" (60 mm)
More
Video review
Watch Scott's full 16-minute review of the SCOTT Spark 970, including footage from the trails above, on BikeRide's YouTube channel.
Lead E-Bike Tester · 90+ bikes tested
Scott assembles, measures and rides every bike we review, and puts each e-bike through the same standardized range, climbing, acceleration and brake tests. He rides year-round in the Pacific Northwest, normally on an enduro bike with 170 mm of travel up front and 150 mm at the rear. See all of Scott's reviews.
This bike was supplied by SCOTT for testing. Manufacturers never see our reviews before publication and cannot pay for a score. We earn a commission on purchases made through links on this page. It never affects results.
Reviewed using BikeRide Methodology 1.1 (October 2026): logged conditions and 1–5 ratings anchored to written rubrics. Read the methodology
