Riding’times GT73 Pro Review
Our verdict
The Riding'times GT73 Pro is a 120 lb, motorcycle-style electric bike with a 1,500W hub motor and two batteries. It cruises comfortably at around 25 mph on smooth dirt roads and fits adult riders well. But it topped out at 38 mph against a 50 mph headline, covered 36.25 miles of a claimed 85, stalled on short, steep off-road climbs, and bottomed out its suspension on hard hits. It falls well short of its marketing, and it's a hard sell, even at this price.
- Gradual power that is easy to control
- Fits adults, with a long, comfortable seat
- Agile and enjoyable at around 25 mph
- Sleek finish and fairly tidy wiring
- 38 mph on GPS, not the claimed 50
- Stalls on steep off-road climbs
- Suspension bottoms out on hard hits
- 36.25 miles of an 85-mile range claim
- Kickstand drops down over bumps
- Not a legal e-bike in most places
Claimed vs. measured
Riding'times sells the GT73 Pro on its speed, its power, and its range. Here is the product page next to what we measured:
| Claim | Riding'times says | We measured | Verdict |
| Top speed | 50 mph in the headline | 38 mph (GPS-verified) | ✗ 12 mph short |
| Weight | 123 lb | 120.4 lb with both batteries, 2.1% lighter | ✓ Verified |
| Range (throttle only) | 85 mi | 36.25 mi in STD mode, unlocked, mostly on the throttle | ≈ 43% of claim |
| Charge time | 5–6 h | 6.0 h at the fastest (18Ah ÷ 3A per battery, both chargers) | ✓ Verified |
| Seat height | 30.3", and 35.4" at the rear of the seat | 34"–36" from the ground, depending on where you sit | ✗ Misleading |
| Fits our tester (6'0", 33" inseam) | 5'5"–6'3" range | Fits well for throttle riding, with flat feet while sitting. Cramped for pedaling | ≈ With caveats |
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
The most similar bikes we have tested first-hand, compared side by side using our own measurements and test results where possible.
| This bike |
Yozma IN 10 Pro |
Eahora Juliet Pro II |
Revibikes Cougar |
| BikeRide Score | 70 | 83 | 76 | 74 |
| Best price | $1,756.55 | $1,614.05 | $1,999.99 | $1,350.00 |
| Motor | 1,500W rear hub (3,000W peak) | 2,500W mid-mounted (5,500W peak) | Two 2,200W hubs (2,600W peak each) | 750W rear hub (1,600W peak) |
| Battery | 2,160 Wh | 1,620 Wh | 4,200 Wh | 1,200 Wh |
| Range tested (max assist, unlocked) | 30.96 mi | 28.08 mi | 69.35 mi 28 mph cap | 27.67 mi |
| Efficiency (same runs) | 69.8 Wh/mi | 57.7 Wh/mi | 60.6 Wh/mi | 43.4 Wh/mi |
| Gradual hill climb, unlocked | 1:56 | 1:34 | 1:31 | 2:24 |
| Steep hill climb, unlocked | 1:43 | 1:13 | 1:12 | 1:52 |
| 0–20 mph (throttle) | 6.0 s | 3.5 s | 5.0 s | 6.0 s |
| Brake 20–0 mph | 17.5 ft | 15.5 ft | 16 ft | 14 ft |
| Measured weight | 120.4 lb | 143 lb (claimed) | 148.4 lb | 88.0 lb |
| 0–20 mph (pedal assist) | 15.0 s | No pedals | 7.0 s | 7.0 s |
| Top speed | 38 mph (GPS) | 47.9 mph (GPS) | 43 mph (GPS) | 38 mph |
| Torque (claimed) | 338 Nm | 220 Nm | 2 × 110 Nm (also listed as 2 × 95) | 110 Nm |
| Charge time (calculated) | 6.0 h two chargers | 5.4 h | 10.0 h | 5.0 h |
| Drivetrain | Single-speed, 32t / 16t | Chain drive, no pedals | 7-sp Shimano Tourney, 44t, 14–28t | Single-speed, 48t / 16t |
| Tires | 70/100-19 dirt-bike | 70/100-17 front, 90/100-14 rear | 20×4″ Blackcat | 20×4″ Inova |
| Brakes | Four-piston hydraulic, 203 mm rotors | Hydraulic, 220 mm front and 180 mm rear rotors | Four-piston hydraulic, 203 mm rotors | Two-piston hydraulic, 180 mm rotors |
| Assist sensor | Cadence | None, throttle only | Cadence | Cadence |
| Water rating | IPX4 | IPX6 | IPX6 | IPX6 |
| Certification | UL 2849 claimed. The report we were sent is for the GT73 | UL 2272 (claimed) | CE, no UL certification | UL 2849 + UL 2271 |
Who should buy the GT73 Pro
We believe the Riding'times GT73 Pro is a good choice for:
- Riders who want a throttle cruiser for smooth dirt roads. We enjoyed it most at around 25 mph on smooth logging roads, fire roads, and dry pavement.
- Riders who want gradual power. The power ramps up gradually, not aggressively, and the throttle is easy to modulate, which we found better for less experienced riders.
- Adult-sized riders. At 6'0", Scott could sit on it flat-footed, and the long, well-padded seat was comfortable on long rides.
Who should NOT buy it
- Riders who want to climb steep trails. It ground to a halt on a short, steep off-road climb, bogged down in deep sand, and lost power when the motor got hot.
- Riders buying on the 50 mph headline. Unlocked, ours reached 38 mph on GPS, and two bikes in its comparison group beat it in every climbing and acceleration test.
- Riders who ride rough ground. The suspension bottomed out on hard hits, the fork guards damaged a brake hose clamp, and the kickstand dropped down over bumps. It is only suitable for smooth trails.
Before you buy: the claims and the bike
Riding'times markets the GT73 Pro as "next-level power". Four things on its product page did not hold up against our tests or its own manual:
- 50 mph in the headline, 38 mph on GPS. The spec table further down the page says 37 to 46 mph. Unlocked, ours reached 38 mph, while the display showed 41.
- 338 Nm that the hills didn't show. On both timed climbs, two bikes with lower published torque were much faster.
- 85 miles on the throttle, 36.25 in our test. The page also promises 25 to 27 more miles than the Yozma IN 10 Pro. We measured about 3 to 8 more.
- Smaller rotors, and a lower payload in the manual. The page lists 230 mm rotors and a 330 lb maximum load. We measured 203 mm rotors, and the manual says 100 kg, or 220 lb, so we wouldn't exceed 220.
Judge the GT73 Pro by the measurements on this page, not by the product page.
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, a verified weigh-in and a timed assembly. Every result is stored in our database and shown against similar bikes and against the 90 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
- Tester
- 6'0", 33" inseam
- Rider + gear
- 200 lb
- Weather
- 53°F cloudy and 63°F clear, on two test days
- Wind
- 3.4–4.5 mph
- Tires
- 40 psi
- Battery
- 100% within 24 h of test
- Speed limit
- Unlocked for every test. The only other setting is the 15 mph shipping limit
We tested the GT73 Pro in September and October of 2026. It has no 20 mph setting, so its climbs are compared with other bikes' unlocked runs, and its range runs are flagged.
Score breakdown — how the 70 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the GT73 Pro lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
6 tests · 3 ratings · factsAcceleration 0–20 mph
MeasuredUnlocked and in TURBO mode, the GT73 Pro reached 20 mph in 6 seconds on the throttle, which ties for third of five in this comparison group. On pedal assist it took 15 seconds, the slowest of the five.
Climbing Test 1: Gradual Hill
MeasuredThe GT73 Pro has only two speed settings, 15 mph or unlocked, so we could not run our usual 20 mph climbs. Unlocked and in TURBO, it climbed the gradual hill (0.99 miles at up to a 6% grade) in 1:56 at an average of 30.7 mph. That is third of five in this group, more than 20 seconds behind the two fastest.
Climbing Test 2: Steep Hill
MeasuredOn the steep hill, 0.65 miles with 226 feet of gain and a 12% maximum grade, the GT73 Pro took 1:43 at an average of 23 mph, again third of five. At the steepest point the display dropped to about 16 mph. Both faster bikes in the group have lower published torque than the GT73 Pro's 338 Nm.
Off-road climbing and motor heat
Fact checkClimbing is where the GT73 Pro disappointed us, and on short, steep off-road climbs it struggled. On one that the Yozma IN 10 Pro handled, it ground to a halt after 10 feet, and it bogged down in deep sand that the Yozma rode through.
After a long, steep climb on the range test, the motor was hot to the touch and struggled to deliver torque until we picked up speed. Riding'times told us the controller reduces power when the motor heats up. We also noticed a slight loss of power over heavy bumps and washboard.
Top speed, speed settings, and speedometer
MeasuredOur bike arrived limited to 25 km/h, about 15 mph. Changing one setting in the display's advanced menu removes the cap. Unlocked, it reached 38 mph on GPS while the display showed 41. That is the bottom of the 37 to 46 mph in Riding'times' spec table and well short of its 50 mph headline. In STD mode the assist tapers out at 25 to 26 mph. The speedometer showed 21 to 22 mph at a GPS-verified 20 mph.
| Check | Reference | Result | Verdict |
| Top speed, unlocked | Claimed 50 mph (headline), 37–46 mph (spec table) | 38 mph (GPS) | ✗ Not met |
| Speedometer at a true 20 mph | 20.0 mph (GPS) | Display reads 21 to 22 mph | ≈ 8% high |
| Speedometer at top speed | 38 mph (GPS) | Display reads 41 mph | 3 mph high |
With a 1,500W nominal motor, the GT73 Pro is legally not an e-bike in most places, whatever speed limit you set. Check local rules before you ride it on roads, paths, or trails.
Assist engagement and throttle response
MeasuredPedal assist uses a cadence sensor and arrives after half a turn of the cranks (0.5 crank revolutions), against a 0.2-revolution average. The assist is weak and slow to respond, and ghost pedaling starts at around 18 mph. On the throttle the GT73 Pro is mild-mannered: the throttle is fairly responsive and easy to modulate, and power ramps up gradually, so it takes time to reach top speed.
Motor noise
MeasuredMeasured unloaded at 20 mph, the GT73 Pro registered 63.6 dB(A), making it the quietest of the four bikes in this group with a reading.
Range and Charging
5 tests · 2 ratings · factsRange Test 1: TURBO (max assist, unlocked)
MeasuredThe GT73 Pro can't be limited to 20 mph, so both range tests were ridden unlocked and mostly on the throttle. In TURBO it lasted 30.96 miles with 1,795 feet of climbing at an 18.7 mph average. That is farther than the unlocked runs of the Yozma IN 10 Pro and the Revibikes Cougar.
Range Test 2: STD (medium assist, unlocked)
MeasuredIn STD mode, which cuts out at about 25 to 26 mph on GPS, the GT73 Pro went 36.25 miles with 1,804 feet of climbing, at a 15.7 mph average. Both batteries drain together. Once the last bar turned red and the gauge flashed, the bike ran about 2.5 miles before it limited power, then slowed to around 9 mph over the next half mile and stopped.
Range vs. claimed
DerivedRiding'times claims 85 miles on the throttle alone and 155 miles with pedal assist. Our runs were mostly on the throttle, so we use the 85-mile figure. Our longer run, 36.25 miles in STD, is 43% of the claim, in our "close" band. Even in ideal conditions, 85 miles on the throttle alone appears unrealistic.
Efficiency
DerivedDividing battery capacity by measured range shows how far a bike stretches every watt-hour. In TURBO the GT73 Pro used 69.8 Wh per mile, and in STD 59.6 Wh/mi.
Charge time
CalculatedEach 60V 18Ah battery has its own 67.2V 3A charger, and both can charge at once, on or off the bike. By our calculation a full charge from empty takes at least 6.0 hours (18Ah ÷ 3A). Riding'times claims 5 to 6 hours.
Fact checkPower comes from two removable 60V 18Ah batteries, 2,160 Wh in total. They lock in place and slide out of the back of the frame one at a time, the rear one first. The bay is cramped, making it hard to get the batteries in. Each one weighs 11.8 lb on our scale.
The five-bar gauge drops a bar or two on hard climbs and then recovers. Riding'times lists the battery as UL 2849 compliant, but the test report it sent us is for the standard GT73, not the Pro, and it told us there is no separate report. We received no UL 2271 battery document. Riding'times says the IPX4 rating covers light rain and splashes only.
Braking and Safety
2 tests · 2 ratingsBrake test: 20 to 0 mph
MeasuredThe unbranded hydraulic brakes have four-piston calipers, 203 mm rotors front and rear, and a motor cutoff. From 20 mph the GT73 Pro stopped in an average of 17.5 feet over five stops, the longest in this comparison group. A faster bike needs more powerful brakes, and from above 30 mph these felt underpowered for a bike this heavy. The front brake also squealed.
Lights and visibility
MeasuredThe headlight measured 561 lux at 15 feet, third of the four bikes in this group with a reading. The rear light doubles as a brake light, and there are turn signals and a horn, which is quite loud. All of them worked throughout testing.
Ride Quality and Handling
1 descriptor · 9 ratingsRiding the GT73 Pro
In STD mode, with a 200 lb rider, the assist cut out at around 25 to 26 mph, and at those speeds the bike is easy to maneuver and enjoyable to ride. In TURBO we cruised between 30 and 35 mph on flat roads. The tires grip well off-road, but on pavement they feel like they lack grip, and the bike gets squirrelly as you lean. On wet pavement, they are slick.
Without power the GT73 Pro is pretty much unrideable: even pedaling on level ground is extremely hard work, so if the batteries run out you are better off pushing.
Stability at top speed
RatedOn our stability run we ride straight at top speed, shift our weight, and shake the bike to see whether a wobble starts. The GT73 Pro felt fairly stable at top speed and on descents, and better off-road than on pavement.
Comfort, suspension, and vibration
RatedThe GT73 Pro has an inverted fork with a compression adjuster on the right leg, and a rear shock with no adjustment. The suspension is firm at the start of its travel, so small bumps and washboard come straight through. In the middle of its travel it feels plush on moderate hits, and on dirt roads we could hold a high speed by avoiding the hard ones. On rougher paths the ride quality was poor, and the whole bike shook.
On hard hits, especially at speed, we bottomed out both the fork and the rear shock. At full compression the guards on the lower fork legs hit the front fender and a brake hose clamp, which damaged our test bike. The compression adjuster cap also came off during testing. The seat is long, well padded, and comfortable.
Riding position
DescriptorWhere the GT73 Pro sits on the spectrum from fully upright to fully aggressive. At 6'0", Scott found it upright and relaxed:
Fit and Sizing
1 check · 2 ratingsTrue to size?
VerdictRiding'times makes the GT73 Pro in one size, for riders from 5'5" to 6'3". At 6'0", Scott fits it well for throttle riding: he can stand over the frame and sit on it flat-footed. The fixed seat sits 34 to 36 inches from the ground, depending on where you sit. Pedaling is cramped. Riders at the low end of the range may find it hard to handle, since it is tall, long, and heavy.
| Measurement | Riding'times claims | We found |
| Rider height range, one size | 5'5"–6'3" | Fits our 6'0" tester well on the throttle |
| Seat height, ground to top of seat | 30.3" (rear seat height 35.4") | 34"–36", depending on where you sit |
| Pedaling position | Not stated | Cramped: knee bent past 45° at the top of the stroke |
| Our verdict | One size fits 5'5"–6'3" | Sized for adults. Riders at the low end may find it hard to handle |
Cockpit adjustability
RatedThe GT73 Pro has a 730 mm riser handlebar on a standard stem. The bar's angle can be adjusted at the clamp.
Build and Components
1 test · 5 ratings · factsWeight, verified
MeasuredRiding'times lists the GT73 Pro at 123 lb. Our scale read 120.4 lb with both batteries fitted, 2.1% lighter. That is one of the heaviest bikes we have weighed, and well over the average of the motorcycle-style e-bikes. It is too heavy and bulky for most people to lift, so look elsewhere if you need to carry a bike up stairs.
RatedThe GT73 Pro has a welded steel frame. The welds are sloppy in places, but overall they aren't too bad. The black and bronze finish looks good from a distance, and the wiring is fairly clean for a budget bike, tucked behind the number plate and up under the seat. The kickstand's spring is too weak to hold it up, so it drops down over bigger bumps, which is pretty dangerous.
Drivetrain
DescriptorThe drivetrain is single-speed, with a 32-tooth chainring and a 16-tooth cog. Pedaling is clearly not a priority on this bike.
Tires and accessories
RatedThe 19-inch rims carry unbranded 70/100-19 dirt-bike tires, which we ran at 40 psi. You get front and rear fenders, a lower rear fender over the shock, lights with a brake light and turn signals, a horn, and a single-sided kickstand.
Display, Controls, and App
2 ratings · factsDisplay and controls
RatedThe LED display shows speed, battery level, trip and total mileage, and the riding mode, and we found it easy to read in the sun. It arrived set to km/h, and the units can be switched. Park mode kicks in after about 30 seconds without input, which annoyingly happens at traffic lights, and you have to squeeze both brakes to release it. The manual mentions cruise control, but we couldn't find a way to engage it.
2 tests · 6 ratings · factsAssembly and setup
MeasuredThe GT73 Pro arrived well packaged, with a toolkit, pedals, decals, a manual, and a charger for each battery. The rear shock fitted at the factory is only for shipping, so you have to swap it for the one in the box. The handlebar, pedals, front fender, and front wheel also need fitting. Assembly took us 68 minutes, and we found no issues during or immediately after.
Support response, tested
MeasuredEvery brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Riding'times the first useful answer arrived after 10.5 hours.
RatedThe brakes and tires are unbranded, and the brakes, fork, and shock look like basic, standard parts. Riding'times sells a Bluetooth module for tuning the Fardriver controller, which could improve performance. We tested the bike in its stock settings only.
Component level for the price
RatedThe GT73 Pro comes with two batteries and two chargers, four-piston hydraulic brakes with 203 mm rotors, and an inverted fork with a compression adjuster. The rear shock isn't adjustable, and the brakes and tires are unbranded.
Value for money
RatedWe weighed everything we measured against the price at the time of publication. The GT73 Pro cruises well on smoother terrain, with smooth power, a comfortable seat, and a good adult fit. Against that, it falls well short of its marketing claims, and the suspension, build quality, and stopping power disappointed us. All of that showed up in a short test, so we wouldn't have high hopes for the long term. Even at this price, it is a hard sell.
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 90 e-bikes we have tested.
| Test | Riding'times GT73 ProThis bike | Average of similar bikesSimilar | BikeRide averageAll bikes |
| Motor and performance | |||
| 0–20 mph, throttle onlyvs. 10 other hub-motor e-bikes over 750W | 6.0 s | 7.6 s | 10.7 s |
| 0–20 mph, max pedal assistvs. 10 other hub-motor e-bikes over 750W | 15.0 s | 7.9 s | 8.4 s |
| Gradual hill climb, unlockedvs. 10 other hub-motor e-bikes over 750W | 1:56 | 2:07 | 2:22 |
| Steep hill climb, unlockedvs. 4 other hub-motor e-bikes over 750W | 1:43 | 1:39 | 1:42 |
| Speedometer deviationvs. 7 other e-bikes | +8% | +5% | +5% |
| Motor noise @ 20 mph, unloadedvs. 16 other e-bikes | 63.6 dB(A) | 66.6 dB(A) | 66.6 dB(A) |
| Assist engagement delayvs. 17 other e-bikes | 0.5 crank rev | 0.2 crank rev | 0.2 crank rev |
| Range and charging | |||
| Range (TURBO, unlocked)vs. 8 other motorcycle-style e-bikes | 30.96 mi | 31.6 mi | 30.4 mi |
| Range (STD, unlocked)no like-for-like average | 36.25 mi | — | — |
| Range vs claimedvs. 8 other motorcycle-style e-bikes | 43% | 47% | 54% |
| Efficiency (TURBO, unlocked)vs. 8 other motorcycle-style e-bikes | 69.8 Wh/mi | 38.6 Wh/mi | 26.5 Wh/mi |
| Charge time 0→100%vs. all e-bikes tested | 6.0 h | 6.2 h | 6.2 h |
| Braking and safety | |||
| Brake test, 20–0 mphvs. 8 other motorcycle-style e-bikes | 17.5 ft | 17.8 ft | 19.3 ft |
| Headlight @ 15 ftvs. 16 other e-bikes | 561 lux | 579 lux | 579 lux |
| Build and ownership | |||
| Measured weightvs. 8 other motorcycle-style e-bikes | 120.4 lb | 94.4 lb | 74.7 lb |
| Battery weight, eachvs. 4 other motorcycle-style e-bikes | 11.8 lb | 11.0 lb | 11.7 lb |
| Assembly timevs. 6 other e-bikes | 68 min | 52 min | 52 min |
| Support response, tested (weekday hours)vs. 31 other brands | 10.5 h | 18.1 h | 18.1 h |
Similar bikes are the hub-motor e-bikes over 750W (both motors counted) for acceleration and the climbs, the motorcycle-style e-bikes for range, range vs claimed (the 85-mile throttle claim), efficiency, braking, weight and battery weight, and all e-bikes for the other rows. Support is averaged per brand. Every GT73 Pro run was unlocked, while most range runs in the averages were at 20 mph. Charge time is calculated (18Ah ÷ 3A).
Detailed specs
As published by Riding'times, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
| Electric bike class | Outside the e-bike classes (1,500W nominal). Ships limited to about 15 mph, unlocked in the display menu |
| Motor | Rear hub, 3,000W peak. 1,500W nominal, confirmed to us in writing |
| Max torque | 338 Nm at the wheel (claimed) |
| Battery | Two removable 60V 18Ah batteries (2,160 Wh) |
| Range claimed | 85 miles throttle only, 155 miles with pedal assist |
| Top speed | 50 mph in the headline, 37–46 mph in the spec table (38 mph measured) |
| Throttle | Full-twist |
| Pedal assist | ECO, STD, and TURBO modes |
| Sensor | Cadence |
| Charger | Two 67.2V 3A chargers |
| Charge time | 5–6 hours (6.0 hours calculated) |
| Display | LED display with speed, battery level, trip and total mileage, and riding mode |
| Controller | 60V 40A Fardriver |
| Water/dust rating | IPX4 |
| Warranty | 2 years on the website, battery 2-year prorated. The manual says 12 months, with 6 months on the battery, motor, and controller |
| Frame | Steel, one size |
| Fork | Inverted aluminum fork with compression adjustment |
| Rear shock | Non-adjustable, marked 1,200 lb |
| Brakes | Unbranded hydraulic, four-piston calipers, 203 mm rotors front and rear, motor cutoff |
| Drivetrain | Single-speed, 32t chainring, 16t cog |
| Rims / tires | 19" 7074 aluminum alloy / 70/100-19 off-road dirt-bike tires |
| Handlebar | 730 mm riser bar |
| Grips | Rubber |
| Saddle | Long, padded moto-style seat |
| Pedals | Alloy platform |
| Lights | Front and rear LED lights, brake light, turn signals, horn |
| Fenders | Front and rear, plus a lower rear fender over the shock |
| Kickstand | Single-sided |
| Payload capacity | 330 lb on the website, 220 lb (100 kg) in the manual |
Geometry details
Measured on our test bike, one frame size. ✓ measured = Riding'times doesn't publish this figure, so it's our own measurement. ✗ = Riding'times' published figure is more than 3 mm from what we measured.
| Measurement | One size (claimed 5'5"–6'3") | |
| Reach | 12.2" (310 mm) | ✓ measured |
| Stack | 23.2" (589 mm) | ✓ measured |
| Standover height | 35.0" (889 mm), at the top of the seat | ✓ measured |
| Wheelbase | 50.5" (1,283 mm) | ✗ Riding'times: 50.0" (1,270 mm) |
| Total length | 75.5" (1,918 mm) | ✗ Riding'times: 74.8" (1,900 mm) |
| Seat height from the ground | 34.0"–36.0" (864–914 mm) | ✗ Riding'times: 30.3" (770 mm), 35.4" (899 mm) at the rear |
| Seat height from the bottom bracket | 21.5"–23.5" (546–597 mm) | ✓ measured |
Video review
Watch Scott's full 18-minute review of the Riding'times GT73 Pro, including footage from our tests, on BikeRide's YouTube channel.
