We have read all expert and user reviews on the Pivot Trailcat. In summary, this is what cyclists think.
- Pivot offers the Trailcat as an SL (140mm front travel/120mm rear) and an LT (150mm/135mm), each in 14 builds spanning a range of price points up to top-tier.
- Reviewers applaud the pedaling efficiency, thanks to the bike's low weight and firm, supportive DW-link suspension.
- Testers savor the lively, nimble feel created by the stiff carbon frame and short chainstays.
- Experts relish how the responsive, precise handling and overall stability (despite the short chain stays) inspire confidence on descents.
- Testers praise the rear suspension platform’s traction and small-bump sensitivity over trail chatter.
- Reviewers easily maintain momentum, hitting small jumps and berms with speed.
- Testers say lifting the rear wheel over obstacles is effortless on the LT.
- The Trailcat comes as a 29er, with a geometry flip chip allowing it to set up mullet or with 27.5” wheels at both ends.
- Attention to detail and thoughtful features such as the semi-internal cable management, bottle mount, multiple tool mounts, and internal storage impress experts.
- Pivot offers registered owners a lifetime frame warranty and courtesy linkage-bearing replacements.
- Several reviewers find the slack seat-tube angle and long stem make the reach too long.
- One tester of the SL finds the overly firm rear end results in the "stapler effect" when descending over repeated steps or small drop-offs. This is mitigated by a smaller volume spacer in the rear shock.
- Experts complain that rider weight is shifted too far forward when standing on the SL, robbing the rear end of traction.
- Testers are disappointed by the short travel of the RockShox Reverb AXS droppers (Team XX Eagle Transmission builds.)
- The Trailcat's stiff chassis makes it sensitive to lateral hits, according to experts.
- Some experts feel the LT's rear end is too stiff, even after adjustments.
- Testers have to weight the LT's front wheel to keep it tracking over steep climbs.
Pivot's Trailcat is a 29er carbon trail bike offered as an SL (120mm rear suspension) and LT (135mm). The flip chip allows mullet and full 27.5 setups. The crisp steering, agile handling, pedaling efficiency, and acceleration win praise, as do the ability to maintain speed and handle descents. A few testers find the reach too long. Some say the ride lacks cushion, the rear end is too firm, and overall compliance could be better, but performance in all areas is generally applauded as excellent. Overall, the Trailcats are recommended as highly efficient trail machines for those who can afford them.Expert Reviews
83/100 based on 3 rated expert reviewsFirst Ride Review | The 2025 Pivot Trailcat Is Two New Trail Bikes-In-One
First Ride: 2025 Pivot Trailcat SL and LT
New 2025 Pivot Trailcat on Review – Double Trouble
Pivot Trailcat SL & LT 29
Not Your Average Feline: The Pivot Trail Cat Scratches Where Other Bikes Can’t Reach
Should You Buy the Pivot Cycles Trailcat SL or LT? (First Impressions)
First Ride: Pivot’s All-New Trailcat SL & Trailcat LT
Pivot Trailcat SL and Trailcat LT First-Ride Review: Meow
Pivot Trailcat LT Pro X0 First Ride Review
Pivot Trailcat LT & SL – Trailcat in a Double Pack
Pivot Trailcat Review Two New Trail Bikes Built for Speed [German]
Best Mountain Bikes
19 hours ago
20 hours ago
20 hours ago
