Lectric XP Trike2 Review
Our verdict
The Lectric XP Trike2 750 is the upgraded version of Lectric's folding e-trike, with a 750W motor, a torque sensor, and an 840 Wh battery. It posted strong results in our tests and lasted 38.69 miles on PAS 4 of 5, the longest result in our comparison group. Its brakes stopped it from its 17 mph top speed in 13 feet. The weight, single-speed gearing, and slow charging count against it, but for riders who want an e-trike for errands and leisure rides, it's the best we have tested.
- Longest-range trike we've tested: 38.69 miles
- 6 seconds to its 17 mph top speed
- Stops from top speed in 13 feet
- Switchable torque and cadence sensors
- Suspension fork and seatpost provide a smooth ride
- Parking brakes on both levers
- Heavy: 96.4 lb with the accessories
- Single speed: ghost pedaling near 10 mph
- 8.8-hour charge on the included 2A charger
- Folding fully means removing the front wheel
- The backrest has no fore-aft adjustment
Claimed vs. measured
Lectric sells the XP Trike2 750 on its range, torque sensor, and low step-through. We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
| Claim | Lectric says | We measured | Verdict |
| Weight | 88 lb (79 lb plus a 9 lb battery) | 96.4 lb as tested, with the accessory bundle fitted, 9.5% over | ≈ Not like-for-like |
| Range (max claim) | Up to 70 mi | 38.69 mi on PAS 4 of 5 | ✓ 55% of claim |
| Charge time | 7–9 hours | 8.8 h by our calculation (17.5Ah ÷ 2A) | ✓ Verified |
| Fits our tester (6'0", 33" inseam) | One size fits 4'10"–6'2" | A good fit, though the backrest pushed us forward on the seat | ✓ Yes |
| Claimed height range accuracy | A 16" span of rider height (4'10"–6'2") | 11.5" of seat adjustment: (16" − 2") ÷ 11.5" = 1.2×, inside our 2.0× limit | ✓ Verified |
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
| This bike |
Mooncool TK1 |
Addmotor Citytri E-310 |
Lectric XP4 |
| BikeRide Score | 91 | 69 | 67 | 94 |
| Best price | $1,799.00 | $1,549.00 | $999.00 | |
| Motor | 750W rear hub (1,310W peak) | 500W rear hub | 750W rear hub (1,440W peak) | 500W rear hub (1,092W peak) |
| Battery | 840 Wh | 696 Wh | 960 Wh | 500 Wh |
| Range tested (max assist) | 38.69 mi PAS 4 of 5 | 30.53 mi | 26.40 mi | 24.69 mi |
| Efficiency | 21.7 Wh/mi | 22.8 Wh/mi | 36.4 Wh/mi | 20.3 Wh/mi |
| Gradual hill climb | 3:29 17 mph top speed | 3:58 16 mph top speed | 3:20 20 mph cap | 3:02 20 mph cap |
| Steep hill climb | 2:38 17 mph top speed | 3:00 16 mph top speed | 2:35 20 mph cap | 2:28 20 mph cap |
| Acceleration (pedal assist) | 6.0 s to 17 mph | 10.0 s 16 mph top speed | 10.0 s to 20 mph | 8.0 s to 20 mph |
| Brake test | 13 ft from 17 mph | 11 ft from 16 mph | 15 ft from 20 mph | 19 ft from 20 mph |
| Measured weight | 96.4 lb with accessories | 97.0 lb | 94.0 lb | 69.0 lb |
| Top speed | About 17 mph in our testing | 16 mph | 20 mph | 28 mph |
| Torque (claimed) | 85 Nm | 55 Nm | 90 Nm | 55 Nm |
| Charge time | 8.8 h | 7.3 h | 10.0 h | 5.2 h |
| Suspension | 50 mm Cloud 50 fork + suspension seatpost (accessory) | Front suspension fork | Front suspension fork | 35 mm coil fork with lockout |
| Drivetrain | Single speed, 36t / 16t | Single speed, 36t / 18t | Single speed, 38t / 16t | 8-sp Shimano Altus |
| Tires | 20×2.5″ puncture-resistant, Slime | 20″ fat tires | 22×2.4″ front, 20×2.4″ rear | 20×3″ Lectric |
| Frame | Aluminum, folding, one size | Aluminum and steel | Aluminum, folding | Aluminum, folding, one size |
| Assist sensor | Torque, switchable to cadence | Cadence | Cadence | Torque |
| Water rating | IPX5 display and controller | IP65 | Not stated | IPX5 display and controller |
| Certification | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 | UL 2849 + UL 2271 |
Who should buy the XP Trike2
We believe the Lectric XP Trike2 750 is a good choice for:
- Riders with mobility issues. The standover of 13.8 inches makes it easy to mount, and the brakes lock as parking brakes, so the trike stays put while you climb on or load it.
- Buyers who want range. Our PAS 4 run lasted 38.69 miles with 632 feet of climbing, the longest result in our comparison group.
- Riders with hills on their routes. The 750W motor took the trike up our steep hill at an average of 14.8 mph on throttle power alone.
Who should NOT buy it
- Anyone who has to lift or fold it often. At 96.4 lb, the XP Trike2 is too heavy for most owners to lift, and folding it fully means taking the front wheel off.
Before you buy: the accessory bundle
Our test trike had Lectric's accessory bundle: the Elite headlight, the seat with a backrest, a suspension seatpost, and front and rear baskets. None come as standard, and they shape three of our findings:
- The smooth ride. The ride comfort we describe comes with the suspension seatpost under the accessory seat, along with the Cloud 50 fork. The trike without the bundle has Lectric's saddle on an aluminum seatpost.
- The backrest. It slides up and down but has no fore-aft adjustment, and it pushed our tester toward the front of the seat, which may cause issues for bigger riders.
- The weight. The accessories add several pounds to the trike's weight, which makes it even harder to lift and fold.
Lectric offers each of these as an upgrade. If you add only one, we'd pick the suspension seatpost for the ride comfort it brought.
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, and a verified weigh-in. Every result is stored in our database and shown against similar bikes and against the 90 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
- Tester
- 6'0", 33" inseam
- Rider + gear
- 200 lb
- Tires
- 20×2.5"
- Speed limit
- None set. The trike tops out at about 17 mph
We tested the XP Trike2 in June 2026.
Score breakdown — how the 91 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the XP Trike2 lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
3 tests · 3 ratings · factsAcceleration 0–17 mph
MeasuredOur XP Trike2 topped out at about 17 mph, so we timed it to that speed. On maximum pedal assist it took 6 seconds, and 8 seconds on the throttle alone. The other bikes were timed to 16 or 20 mph, so the XP Trike2's run doesn't rank against theirs. For all that power, the trike was easy to control.
Climbing Test 1: Gradual Hill
MeasuredOn the gradual hill (0.99 miles at up to a 6% grade) the XP Trike2 finished in 3:29 at an average of 16.8 mph, just under its 17 mph top speed. The other bikes climbed with a 20 mph cap or a lower top speed.
Climbing Test 2: Steep Hill
MeasuredOn the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the XP Trike2 reached the top in 2:38 at an average of 14.8 mph, using only the throttle. The motor impressed us here.
Speed settings and e-bike class
Fact checkThe XP Trike2 750 is a Class 2 e-trike with a half-twist throttle, and ours topped out at about 17 mph. There are five assist levels, from Eco to Turbo. A Beginner setting, on by default, held Eco to 5 mph and the other levels to around 12 mph. With it switched off, the levels gave a good spread of power, from a light Eco up to the motor's full power in Turbo.
Assist engagement and cutoff
RatedA torque sensor manages the assist, but you can switch it to a cadence sensor, depending on how you like the assist to feel. With the torque sensor, power delivery was smooth.
Range and Charging
4 tests · 2 ratings · factsRange Test 1: PAS 4 of 5 (Sport+)
MeasuredOur range test normally runs at maximum assist, but we judged Turbo too powerful for a typical trike rider, so we rode PAS 4 of 5 (Sport+). The XP Trike2 lasted 38.69 miles with 632 feet of elevation gain, at a 15.6 mph average. That is the best result of the e-trikes we've tested.
Range vs. claimed
DerivedLectric claims up to 70 miles. We ran one range test, on PAS 4 of 5, and its 38.69 miles is 55% of the claim, inside our tolerance.
Efficiency
DerivedDividing battery capacity by measured range shows how far a bike stretches every watt-hour. At 21.7 Wh per mile, the XP Trike2 is second in this comparison group.
Charge time
CalculatedThe 48V 17.5Ah pack charges on the included 2A charger, which is slow for a battery this size. By our calculation a full charge takes at least 8.8 hours (17.5Ah ÷ 2A), well over the 6.3-hour average across our database. Lectric sells a 5A charger separately.
Fact checkThe removable 48V 17.5Ah pack (840 Wh) locks into the frame with a key, and Lectric lists it at 9 lb. The battery is certified to UL 2271 and the trike to UL 2849. Lectric rates the display and the controller IPX5.
Braking and Safety
1 test · 2 ratings · factsBrake test: 17 to 0 mph
MeasuredThe Star Union two-piston hydraulic discs with 180 mm rotors stopped the XP Trike2 from its 17 mph top speed in 13 feet. The Mooncool TK1 stopped from its 16 mph top speed in 11 feet, and the Addmotor and the XP4 needed 15 and 19 feet from 20 mph, so the runs don't compare well, but the brakes are undoubtedly a highlight of this trike.
Lights, signals, and visibility
RatedThe XP Trike2 comes with front and rear lights, and the rear light has a brake light and turn signals. Our test trike carried Lectric's Elite headlight from the accessory bundle. The tires have reflective sidewalls.
Ride Quality and Handling
1 descriptor · 8 ratingsRiding the XP Trike2
At 96.4 lb this is a heavy machine, and you feel it whenever you move it around unpowered. Once moving, the XP Trike2 is a smooth ride: the fork and the suspension seatpost soaked up more than we expected, and the motor delivers its power smoothly in torque-sensing mode.
Stability at top speed
RatedTo judge the stability of a trike, we ride straight at top speed, shift our weight, and ride over bumps. This assessment is different for bicycles.
Comfort, suspension, and vibration
RatedSuspension comes from Lectric's Cloud 50 fork with 50 mm of travel and a suspension seatpost with 40 mm of travel. The upgraded seat's backrest slides up and down but has no fore-aft adjustment, and it pushed us toward the front of the seat more than we would have liked. Riders who want back support will like it, but we wanted more room. The seat and post are from the accessory bundle.
Riding position
DescriptorWhere the XP Trike2 sits on the spectrum from fully upright to fully aggressive. Lectric angles the stem at 9 degrees for an upright cruising position.
Fit and Sizing
2 measurements · 2 checks · 2 ratingsTrue to size?
VerdictLectric makes the XP Trike2 in one size for riders from 4'10" to 6'2", a 16-inch span served by 11.5 inches of seat-height adjustment (28.5" to 40" from the ground, measured on our test trike with the accessory seat). By our rule of thumb that span is plausible. At 6'0" with a 33" inseam the trike fit.
| Measurement | Lectric claims | We found |
| Rider height range | 4'10"–6'2" | 6'0" fits, the ends of the range untested |
| Seat height, ground to top of seat | 30"–42" | 28.5"–40" (724–1,016 mm), 11.5" of adjustment, measured with the accessory seat and seatpost fitted |
| Fits our tester (6'0", 33" inseam) | Inside the claimed range | A good fit, though the backrest pushed us forward |
| Claimed height range accuracy | 16" span of rider height | (16 − 2) ÷ 11.5 = 1.2× on the 11.5" we measured, inside our 2.0× limit |
| Standover | 13.8" (13.5" in Lectric's size guide) | 13.8" (351 mm), measured |
| Our verdict | One size fits 4'10"–6'2" | Plausible |
Cockpit adjustability
RatedThe BMX-style bar sits on a telescoping stem, and Lectric lists the bar height at 41.5" to 44.75" from the ground. The adjustable stem let us dial in our position somewhat. The color display sits in the middle, the control pad on the left grip, and the half-twist throttle on the right.
Build and Components
1 test · 6 ratings · factsWeight, verified
MeasuredLectric lists the XP Trike2 750 at 88 lb, 79 lb plus the 9 lb battery. Our scale read 96.4 lb with the accessory bundle fitted (Elite headlight, accessory seat, suspension seatpost, and both baskets), 9.5% over the claim. That makes it the second-heaviest in this comparison group and 0.6 lb above the 95.8 lb average of the e-trikes we have weighed. Lectric rates the payload at 415 lb.
Folding and portability
Fact checkThe frame and the stem both fold, but with the front wheel on, the trike only partly folds. Folding it fully means removing the front wheel, which makes full folding impractical for everyday use. Lectric lists the folded size at 36.5" × 30" × 26" with the front wheel off.
RatedThe XP Trike2 is built on a folding aluminum frame in one size, with a low step-through. Everything on our test trike worked and felt solid. Lectric routes most of the cables externally, with one entering the frame at the down tube.
Drivetrain and gearing
RatedThe drivetrain is a single speed with a 36t chainring and a 16t freewheel, and the motor drives both rear wheels through a differential axle. It is low-maintenance, but ghost pedaling starts around 10 mph. That matters less on a trike than on a bike, as many riders will cruise happily at that speed.
Tires and accessories
RatedThe 20×2.5" tires are puncture-resistant, with reflective sidewalls and Slime sealant installed. Full fenders and the lights come as standard, and there is no kickstand: the parking brakes hold the trike. Our test trike also came with Lectric's accessory bundle: the Elite headlight, the accessory seat, the suspension seatpost, and front and rear baskets.
Display, Controls, and App
2 ratings · factsDisplay and controls
RatedThe XP Trike2 has the same 3.5-inch color display we liked on the Lectric XP4. It is removable, has a USB-C charging port, and you can read it in sunlight. The settings menu holds the Beginner preset and the switch between torque and cadence sensing.
1 test · 6 ratings · factsAssembly and setup
RatedThe XP Trike2 arrived in one large box that we struggled to move alone. Setup was easy: unfold the trike, install the front wheel, and attach the fenders, the seat, and the front rack. Lectric advertises tool-free assembly of the essentials. The fenders and the rack needed tools, which come in the box. Our factory audit found no issues.
Support response, tested
MeasuredEvery brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Lectric the first useful answer arrived after 36 hours, about twice the 18.1-hour average across the brands we have tested.
RatedThe mechanical side is simple: a single-speed drivetrain, Star Union hydraulic brakes, and 20×2.5" tires. The Stealth M24 motor, the Cloud 50 fork, and the display are Lectric's own. Lectric covers the trike with a one-year warranty.
Component level for the price
RatedA 750W motor with a torque sensor that switches to cadence, an 840 Wh UL-certified battery, hydraulic brakes with parking locks, a suspension fork, and a color display: for this price, the XP Trike2 750 packs a lot in.
Value for money
RatedWeighing everything we measured against the price at the time of publication: the longest range in our comparison group, a 13-foot stop from 17 mph, 6 seconds to its top speed, and an easy climb of our steep hill on the throttle alone. Against that, 96.4 lb, a single speed, and a slow charge. The XP Trike2 750 offers strong value.
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 90 e-bikes we have tested.
| Test | Lectric XP Trike2This bike | Average of similar bikesSimilar | BikeRide averageAll bikes |
| Motor and performance | |||
| 0–17 mph, max pedal assistno comparable runs | 6.0 s | — | — |
| 0–17 mph, throttleno comparable runs | 8.0 s | — | — |
| Gradual hill climb, 17 mph top speedno comparable runs | 3:29 | — | — |
| Steep hill climb, throttle onlyno comparable runs | 2:38 | — | — |
| Range and charging | |||
| Range (PAS 4 of 5)vs. 2 other e-trikes | 38.69 mi | 31.9 mi | 30.2 mi |
| Range vs claimedvs. 2 other e-trikes | 55% | 45% | 55% |
| Efficiencyvs. 2 other e-trikes | 21.7 Wh/mi | 27.0 Wh/mi | 25.2 Wh/mi |
| Charge time 0→100%vs. 2 other e-trikes | 8.8 h | 8.7 h | 6.3 h |
| Braking and safety | |||
| Brake test, 17–0 mphno comparable runs | 13 ft | — | — |
| Build and ownership | |||
| Measured weight, with accessoriesvs. 2 other e-trikes | 96.4 lb | 95.8 lb | 74.6 lb |
| Support response, tested (weekday hours)vs. 31 other brands | 36 h | 18.1 h | 18.1 h |
Similar bikes are the e-trikes we have tested, and support is averaged per brand. The XP Trike2 tops out at 17 mph, so its acceleration, climbs, and brake test match no other runs and carry no averages. Its range run used PAS 4 of 5, set against the other bikes' max-assist runs. Charge time is calculated from charger output and battery capacity.
Detailed specs
As published by Lectric for the XP Trike2 750 we tested, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
| Electric bike class | Class 2, with a throttle (Lectric lists Class 1 or 2) |
| Motor | Lectric Stealth M24 750W rear hub (1,310W peak), driving both rear wheels through a differential axle |
| Max torque | 85 Nm (claimed) |
| Battery | 48V 17.5Ah (840 Wh), removable, keyed lock, 9 lb (claimed) |
| Range claimed | Up to 70 miles |
| Throttle | Half-twist, right grip |
| Pedal assist | 5 levels: Eco, Tour, Sport, Sport+, Turbo, plus a Beginner preset |
| Sensor | Torque, switchable to cadence in the settings |
| Charger | 2A (5A charger sold separately) |
| Charge time | 7–9 hours claimed, 8.8 hours calculated |
| Display | 3.5" color TFT, removable, USB-C port |
| Certification | UL 2849 (electrical system) and UL 2271 (battery) |
| Water/dust rating | IPX5 display and controller |
| Warranty | 1 year |
| Frame | Folding aluminum step-through, one size |
| Fork | Cloud 50 suspension, 50 mm travel, preload adjustment and lockout, thru-axle |
| Brakes | Star Union two-piston hydraulic, 180 mm rotors, parking brakes on both levers |
| Drivetrain | Single speed, KMC Z8 chain |
| Chainring / freewheel | 36t / 16t |
| Rims / tires | 20" alloy / 20" × 2.5" puncture-resistant, reflective sidewalls, Slime installed |
| Handlebar | BMX-style, telescoping stem |
| Grips | Ergonomic lock-on rubber |
| Seat | Lectric saddle as standard. Ours: the accessory seat with a backrest and a suspension seatpost with 40 mm of travel (accessory bundle) |
| Pedals | Aluminum platform |
| Lights | 90-lumen headlight, rear light with brake light and turn signals. Ours: the Elite headlight (accessory bundle) |
| Fenders | Full front and rear, included |
| Kickstand | None. The parking brakes hold the trike |
| Payload capacity | 415 lb (max 330 lb rider, 30 lb front basket, 75 lb rear rack) |
| Folded size | 36.5" × 30" × 26" with the front wheel off (claimed) |
Geometry details
Measured on our test trike, one frame size. ✓ measured = Lectric doesn't publish this figure, so it's our own measurement. ✓ Lectric = Lectric's published figure is within 3 mm of what we measured. ✗ = it is more than 3 mm from what we measured.
| Measurement | One size (claimed 4'10"–6'2") | |
| Seat tube | 15.5" (394 mm) | ✓ measured |
| Reach | 12.6" (320 mm) | ✓ measured |
| Stack | 26.0" (660 mm) | ✓ measured |
| Standover height | 13.8" (351 mm) | ✓ Lectric: 13.8" (13.5" in its size guide) |
| Effective top tube | 18.9" (480 mm) | ✓ Lectric: 19" |
| Seat height, min–max | 28.5"–40" (724–1,016 mm), accessory seat and seatpost | Lectric: 30"–42", stock saddle and seatpost |
| Wheelbase | 44.5" (1,130 mm) | ✓ Lectric: 44.5" |
Video review
Watch Scott's full 9-minute review of the Lectric XP Trike2 750, including footage from every test above, on BikeRide's YouTube channel.
