BikeRide helps you find the lowest prices and information on each bike from the widest possible range of sources. BikeRide is reader-supported, and sometimes we receive commissions for links you click on. Read Privacy Policy
We have read all expert and user reviews on the Himiway Rambler. In summary, this is what cyclists think. Published Jan 06, 2024 by Amanda Whittington.
13 reasons to buy
The Himiway Rambler is available in three builds at three price points (standard, Upgraded, and Premium).
An expert enjoys the "responsive" and "natural" assistance from the Rambler Premium's mid-drive motor.
The Shimano Altus 9-speed drivetrain (Upgraded, Premium) is above average at this price.
The step-through frame offers easy access for shorter and less flexible riders.
Testers report smooth and predictable power transfer across all pedal assist levels when using the Rambler Premium's mid-drive motor.
Experts enjoy the comfortable and stable ride.
The Rambler has a rear rack, fenders, and integrated lights with brake activation and auto-on/off.
The stated range of 55 miles is shown to be accurate in testing. A reviewer of the Premium build covers 42.6 miles and 1,430 feet at 14.8mph in PAS 3.
The Rambler has a relatively high payload capacity of 330lb. The rack is rated for 33lb.
Himiway provides a 3A charger, reducing charging times over standard 2A chargers.
This bike is available in three colors (Ocean Blue, Himi Grey, and Pearl White).
In brake tests, the Rambler Premium achieves "better results than most e-bikes" reviewed by one expert.
The battery level is shown as a percentage.
Throttle speed exceeds 20mph when unlocked, surpassing the the Class 2 speed limit.
Reviewers complain that the display is small (1.75"), hard to read, and lacks color and brightness.
According to experts, the hub drive (standard, Upgraded builds) offers weak hill-climbing performance.
The Rambler Premium's mid-drive motor doesn't include a shift sensor, so riders must remember to stop pedaling before shifting.
A tester receives the Rambler Premium with an under-inflated shock in the air suspension fork, requiring a shock pump to address.
One 6'0" reviewer cannot get full leg extension with the seatpost at its max height despite a stated height range of 5'2" to 6'4".
Once below 20% charge, the Rambler Premium's max power drops significantly, laments an expert tester.
An expert reports "notable" frame flex when riding on bumpy roads, raising doubts over the frame's durability.
The Himiway Rambler is a step-through electric city bike available in three builds. The base and Upgraded builds have hub motors; the Rambler Premium has a mid-drive. Reviewers complain about the display and report underwhelming climbing performance from the hub motor. However, the mid-drive performs well on hills. The Rambler earns praise for its comfort, stability, and riding range, while ample carrying capacity and commuter accessories add functionality. Overall, testers feel the Himiway Rambler, available at three price points, is a good choice for a range of commuters.
The Rambler Premium by Himiway is a commuter e-bike, and the most expensive of the three Rambler builds.
The step-through frame has a Bafang M600 mid-drive motor, Shimano Altus 9-speed gearing, 27.5″ x 2.4″ Innova tires, and commuter accessories like a rack, fenders, and lights.
In this review, we’ll put the Rambler Premium through our standardized testing to determine its strengths and weaknesses. Keep reading to find out how it performs!
What Is the Himiway Rambler?
The Rambler is one of Himiway’s four step-through commuters, alongside the A7, A3, and B3. As mentioned, it comes in three builds to suit different budgets and preferences.
The top-of-the-line Rambler Premium is the only one with a mid-drive motor. The standard Rambler and Rambler Upgraded have the same 500W, 62Nm hub motor. The base option has a 7-speed Tourney drivetrain and mechanical disk brakes; the other two have 9-speed gearing and hydraulic discs.
The Rambler looks the part and has a high-torque (120Nm) M600 mid-drive, but how do these components perform? Let’s dive into the pros and cons to learn more.
Responsive Mid-Drive Motor
The M600 Bafang mid-drive motor is a solid inclusion at this price, offering responsive assistance and a natural riding experience. With a torque sensor, the motor’s power output matches your effort when pedaling, making you feel like you have superhuman strength.
The M600 is quiet during operation, generating less noise than a rear hub motor. The inclusion of a throttle in this mid-drive system is a nice touch, as most mid-drives don’t have one. Throttles are particularly useful when starting from a stopped position if you forget to shift to a lower gear.
9-Speed Drivetrain
The Rambler Premium has an above-average 9-speed Shimano Altus drivetrain, which shifts better than lower-end alternatives.
The 13-32t cassette and 46t chainring provide ample gearing range. This is important for mid-drive e-bikes that rely more on rider pedaling input than hub-drive systems. With more gearing, riders can find a comfortable cadence at different speeds, get better performance from the motor, and use the battery more efficiently.
Bright Light With Automatic On/Off
The Rambler Premium’s 500-lumen headlight is large and bright. It can be turned on with the control pad or programmed to turn on and off automatically based on ambient light. This is a great feature for a commuter e-bike. The bike also includes a taillight with a steady setting and a braking indicator. The battery powers both lights.
Frame Flex
The Rambler frame flexes noticeably while riding despite having a reinforcing tube above the bottom bracket. The flex is felt when riding the bike over bumps and while turning. This flex doesn’t inspire confidence and may lead to long-term issues.
Small Low-Contrast Display
The Rambler’s display is small and can be challenging to read. The wattmeter, range, and odometer are shown as tiny numbers at the bottom of the screen, making the display almost impossible to see in bright light or rain. This is disappointing, especially given that other Himiway models have larger, higher-contrast displays.
Exaggerated Sizing
Himiway lists a height range of 5’2″ to 6’4″ for the Rambler, but I find this an exaggeration. At just 6’0″, I use the bike at its max saddle height and still cannot get full leg extension. I’d need another inch or two for the appropriate fit.
What Does It Do Best?
The Rambler Premium is a Class 3 e-bike with a top speed set at 25mph. The Bafang M600 mid-drive motor is noteworthy at this price, performing well and providing natural-feeling, responsive power output.
The bike also has an above-average Altus drivetrain with a 9-speed 12-32t cassette and 46t chainring. This combination works well with the mid-drive motor and offers crisp shifting performance.
Overall, I enjoyed the bike’s performance and found it easy to control and ride. It’s also fully equipped for city riding with a rear rack, bright lights, and fenders.
Reasons to Look Elsewhere?
A few issues arose while testing the Rambler Premium. Firstly, frame flex is notable when riding over bumpy terrain. While this doesn’t impact ride quality, it casts doubts on the long-term durability of the frame, especially for heavier riders or those regularly carrying cargo. Another consideration is that the bike and battery aren’t currently UL-certified.
The Rambler is a bit small for me at 6′, despite being rated for up to 6’4″. The 15.5″ seat tube prevented me from getting the full leg extension required for pedal efficiency and comfort.
The final issue was the significant decrease in power output below 20% battery. The max output drops to just 250W, so climbing hills is much slower, and more rider input is needed to maintain even moderate speeds.
Conclusion
The Rambler Premium has solid features and attributes, and I feel many riders would enjoy it. However, it’s not without its drawbacks. Riders over 6’0″ may feel cramped, and the decrease in power output at lower battery levels is frustrating.
That said, the mid-drive motor is a big positive, and the bike performs well in most circumstances. So, if you’re looking for a solid mid-drive commuter with a comfortable step-through frame, the Rambler Premium is worth considering.
Specs
Electric Bike Class: Class 3 Warranty: 2-year limited UL Certification No – UL 2849 application in progress IPX Rating IPX-4 Battery Weight: 8.8lb Total Weight: Claimed: 61 lb – Actual: 67 lb Motor Brand: Bafang M600 Motor Type: Mid-Drive Motor Nominal Output: 500W Max Torque: 120Nm Battery: 48V – 15Ah (720Wh) Range Claimed: 55 miles Range Tested PAS 5: 31.28 mi – 1,549 feet – 15mph *NEW – Range Tested PAS 3: 42.62 mi – 1,430 feet – 14.8mph Speed: 25mph max Throttle: Thumb-style Pedal Assist: 5 levels Charger: 54.6V – 3A Charge Time: 6 hours Display: Bafang DPC-240 LCD display 1.75″ Frame: 6061 Aluminum Fork: Trama Air spring 80mm travel Brake Levers: Tektro HD-E350 hydraulic Brake Calipers: Tektro HD-E350 hydraulic 2-piston Brake Rotors: 180mm Chain: KMC E9-S EPT 122L Crankset: 170mm aluminum – 46t Derailleur: Altus 9-speed Shifter: Altus 9-speed trigger style Cassette: KDF一D958 13-32t Rims: MD-239 – 27.5” Hubs: FH908QR Tires: Innova IA-1283 – 27.5” x 2.4” Fenders: Included, aluminum Lights: 48V 500-lumen headlight – 48V LED taillight with braking indicator Grips: Faux leather ergonomic slip-on Saddle: Selle Royal Pedals: Aluminum platform Handlebar: Swept-back – aluminum – 700mm – 22.2 * 31.8 Kickstand: Single-sided Weight Capacity: 330lb
Frame and Geometry
The Himiway Rambler has a sleek step-through frame that’s easy to mount, even when loaded with cargo.
The frame flexes considerably during use despite the additional tubing reinforcing the lower section. This side-to-side flex is especially noticeable on bumpy terrain, raising doubts over the frame’s strength.
The Rambler Premium comes with a short-travel 80mm air suspension fork, a nice upgrade over the more common hydraulic coil suspension found at this price. The fork’s pressure wasn’t correctly tuned out of the box, sitting at 70 PSI, causing it to bottom out from small impacts. A shock pump is required to increase the air pressure. I adjusted the fork to 105 PSI, which improved its performance.
The Rambler’s one-size frame has a stated height range of 5’2″ to 6’4″, but this is exaggerated. As mentioned, at 6′, I can’t get full leg extension, so the bike certainly wouldn’t be comfortable for taller riders. A realistic height range would be 5’2″ to 5’10”, though some users up to 6′ tall may enjoy riding it.
Seat Tube: 15.5 “(394 mm) Reach: 17″ (432 mm) Stack: 19.2” (488 mm) Stand Over Height: 18.1″ (460 mm) Virtual Top Tube Length: 22.2″ (564 mm) Min Saddle Height: 33″ (838 mm) Max Saddle Height: 38.5″ (978 mm) Wheelbase: 46.4″ (1178 mm) Claimed Height Range: 5’2” – 6’4” Measured Height Range 5’2” – 5’10”
Display and Control
The Rambler uses a 1.75″ black-and-white Bafang display controlled by a three-button pad on the left side. The display has a USB port for charging devices on the go. A key is not required for operation, and the bike doesn’t feature a lock to prevent it from being turned on. The lights are integrated with the bike’s electronics and have an automatic on/off setting.
Battery level is displayed as both a bar and a percentage. Pushing the power button cycles through the different metrics, including max speed, average speed, odometer, trip info, current power output (in watts), and a range estimate. These metrics are nice to have, but the small display is hard to read while riding.
The up and down buttons control the assist levels and allow you to access a walk mode by pressing down until you go past 0 and see a walk icon on the display.
Motor
The Rambler Premium has a 500W Bafang mid-drive motor that provides 120Nm of torque at max output. The motor has three sensors (one torque and two speed), resulting in an intuitive and natural riding experience.
As a mid-drive, it didn’t perform as well in our 0-20mph test as the hub-drive bikes we more frequently test.
When stopping with a mid-drive, it’s necessary to shift to a low gear. Then, to get started again, the rider moves up through the gearing, gradually increasing speed. It’s advisable not to shift the drivetrain while under load to avoid damage, slowing the initial acceleration further. However, when moving, the Rambler Premium accelerates quickly.
An annoying characteristic of the controller’s programming is the large reduction in power when the battery falls below 20% charge. This means that if you have a hill late in your ride, it will require a lot more rider input to maintain speed.
I also found that despite the motor’s high torque rating, it is a slower climber than most bikes we’ve tested. It completed the small and medium hill climbs at below-average speeds.
The final thing to be aware of with a mid-drive is to stop pedaling to shift gears. Doing so will reduce wear on the drivetrain and lower the chance of the chain dropping. Higher-end mid-drives usually have a shift sensor to cut motor power while shifting.
Battery and Charger
The 48V 15Ah (720Wh) internal battery combines well with the power-conscious mid-drive motor, providing solid range. This battery is not currently UL-certified, but Himiway has told us that the UL 2849 certification is in progress.
The bike comes with a 3A charger, providing a faster charge (around six hours) than the more typical 2A chargers seen at this price. The charge port is on the opposite side of the keyhole at the top of the down tube.
In our PAS 5 test on a hilly course, we covered 31.3 miles and 1,549 feet of elevation, averaging 15mph. This range is well above the commuter average.
For this and future reviews, we’ve added a PAS 3 range test to reflect a more typical real-world range. The Rambler Premium achieved great results here, covering 42.6 miles and 1,430 feet of elevation at 14.8mph.
Drivetrain
The Rambler has a 9-speed Shimano Altus drivetrain with a 46t chainring and 13-32t cassette. This gearing is adequate for pedaling at speeds up to 25mph speed limit and on moderate inclines. As mentioned, maintaining a steady, high cadence is key to getting the most from mid-drive motors.
Unfortunately, this bike doesn’t have a shift sensor to cut power to the motor when you shift. Given that, riders must be careful to stop pedaling before they shift.
The Rambler Premium has two-piston Tektro HD-E350 hydraulic brakes with 180mm rotors, a powerful set of brakes that offer reliable performance. These are a big upgrade over the mechanical discs on the base Rambler build.
The brakes were quiet throughout testing, unlike many cheaper brake setups. This brakeset has a motor inhibitor to aid with stopping, and the levers are reach-adjustable.
The average braking distance when stopping from 20mph is 18.5 feet, a better result than most e-bikes we’ve tested.
Wheels, Tires
The Rambler rolls on a set of 27.5″ x 2.4″ tires from Innova, an urban tire with a light tread pattern and a reflective halo on the sidewall. These tires don’t have puncture protection.
During testing, the tires performed well on pavement and hard-packed gravel, but they don’t offer much traction on looser surfaces.
The Rambler Premium has a bright headlight, rear light, aluminum fenders, and a rack. It also has mounting points on the headtube for a front rack.
The included rack is well-designed and has a weight capacity of 33lb. The taillight is attached to it and has a braking indicator. Both lights can be operated using the control pad or set to turn on and off automatically.
The aluminum fenders offer good coverage and do not move or make noise while riding. Finally, the Rambler has a typical single-sided kickstand, which is stable.
Touchpoints
The Rambler Premium has ergonomic faux leather grips. These are slip-on grips that can move on the bars. I would prefer a lock-on version, but they were comfortable throughout testing.
The saddle is by Selle Royal. It has a wider base than sport-style saddles and is comfortable and well-suited to the bike’s commuter designation. I found it comfortable even on the 42-mile range test.
Himiway chose standard aluminum platform pedals for this bike. These offer fine traction for most shoe types, and the small metal pegs are better than the plastic pedals on similar bikes.
We enjoyed its comfort level, its motor power and responsiveness, and its leisurely feel; the Rambler Premium proved to be a capable commuter and just a fun e-bike to ride in general.
This is a commuter-friendly bike. It’s not exhilarating, but it has decent range, decent power, it can bring us up some decent hills, it’s easy to get on; all around a decent bike if you do like this bike and the price.
If you are on the hunt for an enhanced pedaling experience without the hefty price tag often associated with mid-drive bikes, then the Rambler is certainly worth taking a look at.
