Heybike Ranger S vs Lectric XP4
Heybike Ranger S
84/100
Lectric XP4
94/100
Specifications
Specifications
Heybike Ranger S
Lectric XP4
Men, Women
Men, Women
Type
Folding, Fat Tire, Comfort, Commuter, Electric
Electric, Folding, Fat Tire
2025
Heybike
Lectric
4 Hours
5.5, 9 Hours
55 Miles
50, 85 Miles
500 W, 750 W
80 Nm
55, 85 Nm
48V 14.4Ah
48V 10.4Ah, 48V 17.5Ah
Class 3, Class 2
Class 2, Class 3
Hub-Drive
Hub-Drive
20”
20”
8
External Derailleur
External Derailleur
72 lb
72, 74 lb
Front
Front, Seatpost
Disc: Hydraulic
Disc: Hydraulic
Aluminum
Aluminum
Heybike Ranger S
We have read all expert and user reviews on the Heybike Ranger S. In summary, this is what cyclists think.
15 reasons to buy
  • The Heybike Ranger S fits riders from 4'11" and 6'3″.
  • Experts relish the responsive and "smooth" throttle power.
  • Reviewers report that pedal assist kicks in "almost instantly" from a standstill or low speed.
  • In testing, this bike easily handles steep hills with pedal assist.
  • Owners and reviewers find the Ranger S to be a comfortable ride.
  • During a range test, one reviewer covers 42.1 miles and 800 feet of elevation on PAS 2.
  • Experts commend the stopping power of the hydraulic disc brakes.
  • Testers enjoy the traction and stability afforded by the hydraulic suspension fork and fat tires on roads and trails.
  • The Ranger S has a high payload capacity of 400lb. The rear rack can support 120lb.
  • Heybike includes a 4A charger, which is double the typical output at this price range.
  • Heybike's choice of mag wheels means no broken spokes.
  • The Ranger S is agile, according to testers.
  • Owners say the folding process is simple and easy.
  • This bike has "bright" lights, an auto-on headlight, integrated turn signals, fenders, and a horn.
  • The companion app allows owners to track rides, customize pedal assist levels and throttle power, and troubleshoot errors.
  • Reviewers criticize the inaccurate, rapidly fluctuating battery level indicator.
  • The Ranger S is heavy for a folding e-bike at 72lb.
  • Some testers struggle to reach the top speed due to ghost pedaling at around 18mph.
  • The Ranger S lacks a mechanism to hold the bike together while folded.
  • Reviewers find the walk mode speed (4.2mph) too fast for a walking pace.
  • Some buyers report the brake cable rubbing on the front tire, requiring adjustments.
The Heybike Ranger S is a fat-tire folding e-bike with a step-through frame and a choice of four colors. This bike receives praise for its responsive power, comfort, stability, and off-road performance. Experts also appreciate the reliable brakes, riding range, and rapid charging. The drawbacks are mostly minor, such as an inconsistent battery level indicator, ghost pedaling, and high weight. Despite these considerations, experts agree the Ranger S is a well-priced option in the folding fat-tire segment.
Lectric XP4
We have read all expert and user reviews on the Lectric XP4. In summary, this is what cyclists think.
13 reasons to buy
  • The XP4 is available as a step-through or step-over, and with a 500W motor (XP4) or 750W motor (XP4 750).
  • Reviewers compliment the handling, saying the bike feels maneuverable yet stable.
  • In testing, this bike's braking distances are shorter than almost all other comparable e-bikes.
  • This bike has a headlight, a taillight with turn signals and brake activation, fenders, and a 150lb-rated rear rack.
  • Reviewers praise the smooth, responsive pedal assist, which is tuned to provide more power with less effort, though one tester complains that the torque sensor feels more like a cadence sensor at higher speeds.
  • Experts enjoy the relaxed, upright riding position and short reach, and are impressed by the adjustability offered by the long seatpost and telescoping stem, but none checks the actual fit range.
  • In testing, the XP4 750 climbs hills faster than all comparable electric folders.
  • Testers say the TFT display is bright and easy to use. They appreciate the inclusion of a USB-C port for powering devices.
  • Experts find the modest suspension fork helps absorb small bumps.
  • The frame has mounts for two bottle cages, a tool, and a front basket. A Thule kid seat can be mounted using the LevelUp rear rack.
  • The XP4 is only 37" x 19" x 29" when folded. Testers find folding quick and easy, and appreciate the quick-release pedals.
  • Lectric includes tire slime to further enhance the puncture-resistant tires.
  • Buyers say Lectric customer support is responsive and helpful.
  • At a measured 72lb (500W) and 74lb (750W), the XP4 is hard to lift and cumbersome when folded.
  • Reviewers find the frame halves hit each other when the bike is folded, damaging the paint.
  • One tester says the base XP4's 500W motor struggles uphill.
  • A reviewer finds the thumb throttle hard to modulate at low speeds.
  • The bike's design complicates the process of removing the battery.
  • Two reviewers complain that the battery rattles inside the frame.
Lectric's XP4, the fourth generation of its fat-tire electric folder, now has a torque sensor, comfier geometry, and an upgraded drivetrain. It's available as a step-through or step-over, and with a 500W motor and 499.2Wh battery or 750W motor and 840Wh battery. Its smooth power, strong brakes, and features win praise. The 750W is one of the fastest up hills, but the 500W struggles. The battery rattles and is frustrating to remove, the poorly designed folding leads to paint damage, and the bike is heavy. However, reviewers are generally in awe of the value the XP4 provides over similar e-folders.
Heybike Ranger S
Lectric XP4
Heybike Ranger S
Comparison to averages
Lectric XP4
