Ford Bronco E-Bike Review
Scott Clough-Carroll, Bike Testing and Video Production By Scott Clough-Carroll, updated Oct 13, 2026 | Tested using BikeRide Methodology 1.1 First-Hand Test
Our verdict
The Ford Bronco E-Bike is a full-suspension, moto-style e-bike designed by n+ and sold by Ford. Its suspension was adequate for dirt paths, mild gravel and logging roads, but it won't go over all terrain the way Ford claims. The pedaling position is the worst we have dealt with in a while, and the throttle provides limp, unremarkable assistance: the slowest in our comparison group. Range was the one standout test result, at 31.35 miles. The three cheaper comparison bikes matched or beat the Bronco in most areas, so you're paying for the branding.
  • 31.35 miles of range at max assist
  • Comfortable over light gravel, logging roads, and easy dirt paths
  • Pirelli Scorpion tires grip well
  • Display is readable in bright sunlight
  • 2,000-lumen headlight with two beams is among the brightest we've measured
  • Lightweight for a moto-style e-bike
  • Unsuitable for the claimed terrain and riding style
  • Slowest acceleration in the comparison group
  • Cramped pedaling position and torque sensor make the 28 mph top speed hard to reach
  • Poor IPX4 water resistance rating
  • No fenders, kickstand, or app to tune motor settings
Claimed vs. measured
Ford's marketing promises trail-ready performance to match the SUV's off-road heritage ("approach the trail or adventure with ease", "confidently negotiate obstacles and land jumps"). We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
ClaimFord saysWe measuredVerdict
Top speed28 mph (Class 3)28.0 mph (GPS) on pedal assist✓ Verified
Weight68 lb72.4 lb as shipped✗ Misleading
Range (max claim)Up to 60 mi31.35 mi at max assist, mostly on the throttle✓ 52% of claim
Charge time3.5 h5 h, calculated from the 3A charger✗ Misleading
Rider height range5'7"–6'0", one sizeRealistic, but only for throttle riding≈ For throttle riding
Fits our tester (6'0", 33" inseam)6'0" is the top of the claimed rangeYes, for throttle riding. Like all motorcycle e-bikes, pedaling is cramped≈ With caveats
Claimed height range accuracyA 5" span of rider height on 2.5" of effective seat adjustment(5" − 2") ÷ 2.5" = 1.2×, inside our 2.0× limit✓ Verified
Terrain"Heavy-duty" suspension for "any type of terrain"Not suitable for technical or aggressive terrain✗ Misleading
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology. Motor output (750W) and the 85 Nm torque figure are Ford's published numbers and are not dyno-tested. The 287 lb payload rating was not tested.
Comparison
This bikeFord Bronco E-Bike, the full-suspension moto-style e-bike we testedFord Bronco n+ Mercedes-AMG Petronas F1 Team Rallye Edition e-bike, side viewn+ Mercedes-AMG Petronas F1 Team Rallye Edition Revibikes Cougar moto-style fat-tire e-bike, side viewRevibikes Cougar MEELOD DK300 dual-motor moto-style fat-tire e-bike, side viewMEELOD DK300
BikeRide Score 71 70 74 75
Best price $4,000.00 $7,000.00 $1,350.00 $999.00
Motor750W rear hub750W rear hub750W rear hub (1,600W peak)Dual 750W hubs (2,400W peak)
Battery720 Wh, integrated720 Wh1,200 Wh1,920 Wh, dual
Range tested (max assist)31.35 mi32.41 mi38.08 mi33.25 mi
Gradual hill climb3:03 20 mph cap3:03 20 mph cap3:16 20 mph cap2:10 uncapped
Steep hill climb2:272:312:161:51 uncapped
0–20 mph (throttle)11.0 s11.0 s6.0 s7.0 s
Brake 20–0 mph19.5 ft20 ft14 ft16 ft
Measured weight72.4 lb69.4 lb88.0 lb126.0 lb
Payload287 lbNot published350 lb440 lb
Top speed28 mph (GPS-verified)28 mph38 mph35 mph
Torque (claimed)85 Nm85 Nm110 Nm2×80 Nm (160 total)
Charge time5.0 h5.0 h5.0 h8.9 h
Suspension120 mm air fork + coil shock80 mm air fork, hardtail60 mm inverted fork + coil shock100 mm coil fork + coil shock
Drivetrain9-sp Shimano CUESPinion 9-sp gearbox, beltSingle-speed7-sp Shimano Tourney
Tires27.5×2.6″ Pirelli Scorpion27.5×2.6″ Pirelli Scorpion20×4″ Inova20×4″ CST Scout
FrameAluminumAluminumAluminumSteel
Assist sensorTorqueTorqueCadenceCadence
Water ratingIPX4 (bike)IPX5 (motor)IPX6IPX4 (bike)
CertificationUL 2849 + UL 2271UL 2849 + UL 2271UL 2849 + UL 2271UL 2849
Who should buy the Bronco
We believe the Ford Bronco E-Bike may satisfy:
On the road, the Bronco is comfortable. It is the pedaling that lets it down.
Who should NOT buy it
  • Anyone who wants true performance or off-road capability. Slowest acceleration in the group, middle-of-the-pack on climbs, and we wouldn't take it anywhere technical.
  • Riders who like to pedal. The low fixed seat and long reach gave us sore knees, and the torque sensor requires hard pedaling to get near 28 mph.
  • Riders outside 5'7"–6'0". One frame size and one seat, with 33 to 35.5 inches of effective seat height found by sliding along the saddle.
  • Rain-or-shine riders. The bike is rated IPX4: avoid heavy rain and deep puddles.
Before you buy: the badge and the bike underneath
The Bronco tested poorly and, though comfortable over light off-road terrain, failed to live up to Ford's claims. What we found while verifying the claims:
  • Ford's name is on the frame, but n+ builds the bike. n+ is a relatively new company in the e-bike space, so long-term warranty and customer support are unknowns, and the proprietary components may be hard to source in the future.
  • "Heavy-duty" and "any type of terrain" are misleading marketing. The suspension smooths bumpy pavement, dirt paths, and mild gravel well, and more comfortably than we expected from inexpensive hardware, but we wouldn't take the bike anywhere technical, and we wouldn't ride any of the trails where we ride our mountain bikes.
  • Plan for 72.4 lb, not 68. The bike ships without fenders, rack or kickstand, and our scale still read 4.4 lb over the claim.
  • Plan for a 5-hour charge, not 3.5. A 15Ah battery on a 3A charger needs 5 hours at the fastest, so the 3.5-hour claim is not possible with the included charger.
  • IPX4 for an adventure bike. The motor is rated IPX5 and the electronics IP66, but the bike as a whole is IPX4, so heavy rain and deep puddles are out.
The Ford Bronco E-Bike shipping box, sealed as an official licensed product
The first thing you notice: a Genuine Ford Product seal on the box. The bike inside is made by n+.
None of this makes the Bronco a bad bike on easy ground. It makes it a bike whose price buys the badge: three of the four bikes in our comparison group matched or beat it in most of our tests, and they sell for a fraction of the price.
Tests and Measurements
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, a verified weigh-in and a timed assembly. Every result is stored in our database and shown against similar bikes and against the 88 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
Test conditions — this review
Tester
6'0", 33" inseam
Rider + gear
200 lb
Weather
74–77°F, clear
Wind
≤ 4 mph
Tires
30 psi
Battery
100% within 12 h of test
Speed limit
Class 3 as shipped: 20 mph throttle, 28 mph pedal assist
The Bronco ships as a Class 3 e-bike with four power modes (Eco, Normal, Sport and Baja). We tested it as shipped, in the only frame size offered. Because of the pedaling position, we rode the range test mostly on the throttle. The medium-assist range test we add for most bikes was not run on this one.
Score breakdown — how the 71 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the Bronco lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
6 tests · 3 ratings
Acceleration 0–20 mph
Measured
We measured 11.0 seconds on throttle alone and 10.0 seconds on maximum pedal assist (Baja mode) with a full battery. That is the slowest result in our comparison group. The Mercedes-AMG Rallye Edition, built on the same n+ platform, matched the 11-second throttle run, while the Revibikes Cougar (6 seconds), the dual-motor MEELOD DK300 (7 seconds) and the Himiway C5 (8 seconds) were all well ahead. Throttle power is smooth but subdued: it brings the bike up to around 20 mph and then settles back to a cruising speed of around 19 mph.
On the throttle alone: 11 seconds to 20 mph, the slowest in our comparison group.
0–20 mph, throttle
Seconds · shorter is faster
Revibikes Cougar6.0 s
MEELOD DK3007.0 s
Himiway C58.0 s
Ford Bronco11.0 s
Mercedes-AMG Rallye Edition11.0 s
Ford BroncoComparison bikesAverage of similar bikes (9.6 s)
Throttle only: 11.0 sMax pedal assist: 10.0 sAverage of similar bikes: 9.6 sTies slowest in the group
Climbing Test 1: Gradual Hill
Measured
On the gradual hill (0.99 miles at up to a 6% grade) the Bronco finished in 3:03 at an average of 19.0 mph, level with the Mercedes-AMG and 13 seconds quicker than the Revibikes Cougar's capped run (3:16). Those three ran this hill with the 20 mph throttle cap in play, so the average compares capped runs with capped runs.
Rider's view from the Bronco's one-piece bar on a straight gravel road
Gently uphill: the kind of ground where the Bronco is at its best.
Gradual hill climb, max assist
Minutes:seconds · shorter is faster · 0.99 mi · 79 ft gain · 6% max grade
MEELOD DK300 uncapped2:10
Himiway C5 uncapped2:37
Ford Bronco 20 mph cap3:03
Mercedes-AMG Rallye Edition 20 mph cap3:03
Revibikes Cougar 20 mph cap3:16
Ford BroncoComparison bikesAverage of similar bikes, 20 mph-capped runs (3:09)
Bronco: 3:03 · 19.0 mph avgAverage of similar bikes, capped runs: 3:09Level with the Mercedes-AMG on capped runs
Climbing Test 2: Steep Hill
Measured
On the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the Bronco reached the top in 2:27 at an average of 16 mph. That is a decent middle-of-the-pack time: beating the Mercedes-AMG by four seconds, with the Revibikes Cougar (2:16) and the dual-motor MEELOD DK300 (1:51) ahead. We had to pedal as hard as we could to hold that pace, and in the cramped seated position it was uncomfortable.
The Bronco finished the steep climb in 2:27 at a 16 mph average.
Steep hill climb, max assist
Minutes:seconds · shorter is faster · 0.65 mi · 226 ft gain · 12% max grade
MEELOD DK300 uncapped1:51
Revibikes Cougar2:16
Ford Bronco2:27
Himiway C52:27
Mercedes-AMG Rallye Edition2:31
Ford BroncoComparison bikesAverage of similar bikes (2:28)
Bronco: 2:27 · 16 mph avgAverage of similar bikes: 2:28Middle of the pack in the comparison group
Hill start on steep grade3/5Pedal assist responds quickly, but the modest torque means you need to be in the right gear to get started on a steep hill.
Top speed and speedometer accuracy
Measured
This claim held. On pedal assist the Bronco reached a GPS-verified 28.0 mph, and the throttle stops at 20 mph, as a Class 3 e-bike should. Holding 28 mph is another matter. The torque sensor wants a fair amount of rider input to give full power, but with the cramped pedaling position, we couldn't sustain the top speed for long. The display's speed readout matched our GPS throughout testing.
Holding speed on an empty road. Getting to 28 mph takes real effort on the pedals.
CheckReferenceResultVerdict
Top speed, pedal assistClaimed 28 mph28.0 mph (GPS)✓ Verified
Top speed, throttleClass 3 limit, 20 mphAbout 20 mph, settling to 19 mph✓ As specified
Speedometer at a true 20 mph20.0 mph (GPS)Display reads 20 mph✓ Accurate
Class 3 e-bikes are limited to 28 mph on pedal assist and 20 mph on the throttle. Many trails and multi-use paths restrict Class 3 access, so check local rules before riding there.
Motor noise
Measured
Measured indoors with the rear wheel spinning unloaded at 20 mph, the Bronco's unbranded hub motor registered 70.9 dB(A), about 3 dB above the 68.0 dB(A) average of the e-bikes we have measured this way.
The 750W rear hub motor, 203 mm rear rotor and Shimano CUES drivetrain of the Ford Bronco E-Bike
The unbranded 750W rear hub, rated at 85 Nm by Ford, between the Shimano CUES cassette and 203 mm rotor.
Bronco: 70.9 dB(A) @ 20 mph, unloadedAverage: 68.0 dB(A)
Assist engagement and cutoff
Measured
The torque sensor responds as soon as you press on the pedals: we counted no measurable delay (0 crank revolutions) before assist arrived. The catch is how much you have to give it. Full power only comes with a fair amount of input at the pedals, which is what makes 28 mph hard to reach and hold. On mountain bikes, a torque sensor is a benefit; on motorcycle-style e-bikes like the Bronco it works against you, and during the range test, we used the throttle to avoid knee discomfort.
Pedaling the Bronco: knees high, reach long. The torque sensor is a poor match for this bike.
Torque sensor: 0 crank rev before assistAverage: 0.4 crank revFull power needs hard pedaling
Motor engagement5/5Assist arrives immediately, but full power asks for a lot of rider input.
Assist cutoff behavior4/5A fairly smooth taper approaching the speed limit.
Range and Charging
4 tests · 1 rating · 5 facts
Range Test 1: Max Assist (Baja mode, mostly on the throttle)
Measured
Ford claims up to 60 miles, depending on usage and conditions. On our standard loop, in the maximum assist mode and relying mostly on the throttle because of the pedaling position, the Bronco lasted 31.35 miles with 1,286 feet of elevation gain, at a 15.7 mph average. That was the one result that impressed us, though in this comparison group it is fourth of five: the Revibikes Cougar (38.08 mi), the MEELOD DK300 (33.25 mi, 1,920 Wh dual batteries) and the Mercedes-AMG (32.41 mi) went further, and only the Himiway C5 (28.70 mi) stopped sooner. The Bronco sits just over a mile short of the 32.7-mile average for motorcycle-style e-bikes. Only the maximum-assist range test was run on this bike.
Scott riding the Ford Bronco E-Bike along a forest path during the range test
Standard loop, max assist, ridden to motor shutoff: 31.35 mi in 1 h 59 min. Conditions logged above.
Range at maximum assist
Miles · longer is better
Revibikes Cougar38.08 mi
MEELOD DK30033.25 mi
Mercedes-AMG Rallye Edition32.41 mi
Ford Bronco31.35 mi
Himiway C528.70 mi
Ford BroncoComparison bikesAverage of similar bikes (32.7 mi)
Bronco: 31.35 mi · 1,286 ft climbed · 15.7 mph avgAverage of similar bikes: 32.7 mi−4% vs. similar bikes
Where the Bronco sits: range at max assist
Compared to the 7 motorcycle-style e-bikes we have tested
Ford Bronco
16.4 mi (shortest motorcycle-style result)Range, max assist41.0 mi (longest)
Range vs. claimed
Derived
Ford claims up to 60 miles. The Bronco's 31.35 miles in its maximum assist mode is 52% of the claim, inside our tolerance for a range claim. For context, the average motorcycle-style e-bike reaches 49% of its claimed range on this protocol, and the average e-bike 55%. We did not ride the lower power modes to empty, where the bike would go further.
Claimed: 60 miOur test: 31.35 mi (max assist)52% of claim vs. the 49% average for motorcycle-style e-bikes
Efficiency
Derived
Dividing battery capacity by measured range shows how far a bike stretches every watt-hour. At 23.0 Wh per mile the Bronco is far more efficient than the average motorcycle-style e-bike (33.6 Wh/mi), helped by its narrower tires and modest weight for this category. In this comparison group, only the Mercedes-AMG (22.2 Wh/mi) used less energy per mile: the Revibikes Cougar needed 31.5, the Himiway C5 33.4 and the dual-motor MEELOD DK300 57.7.
Energy used per mile, max assist
Wh/mi · lower is better · battery Wh ÷ measured range
MEELOD DK30057.7
Himiway C533.4
Revibikes Cougar31.5
Ford Bronco23.0
Mercedes-AMG Rallye Edition22.2
Ford BroncoComparison bikesAverage of similar bikes (33.6 Wh/mi)
Where the Bronco sits: efficiency
Ford Bronco
23 Wh/mi (most efficient motorcycle-style e-bike, the Bronco)Efficiency58 Wh/mi (least)
Charge time
Calculated
Ford claims a full charge in 3.5 hours. The math says otherwise: a 15Ah battery on the included 3A charger needs 5 hours at the very least (15Ah divided by 3A), so plan for that. Five hours is still quicker than the 6.3-hour average across our database.
The 3A charger that fills the 15Ah battery in five hours
The 54.6V 3A charger: five hours from empty by our calculation, not the 3.5 hours Ford claims.
Charge time: 5.0 h (calculated)Claimed: 3.5 hAverage: 6.3 hQuicker than average
Fact check
The 48V 15Ah pack (720 Wh) is integrated into the down tube and does not come out, so you charge on the bike. The Bronco and its battery are certified to the UL 2849 and UL 2271 safety standards, and throughout testing the display's battery readout was accurate.
The Ford badge and charge port on the down tube that holds the integrated 720 Wh battery
The down tube holds the 720 Wh battery for good. Charging happens here, on the bike.
✗ Battery not removable (integrated)Charges:  on the bike✓ UL 2849 (electrical system)✓ UL 2271 (battery)✗ IPX4 bike (motor IPX5, electronics IP66)
Charge-gauge accuracy5/5Speed and battery readouts were accurate throughout testing.
Braking and Safety
2 tests · 2 ratings
Brake test: 20 to 0 mph
Measured
Tektro Auriga+ levers, HD-E740 four-piston calipers and 203 mm rotors brought the Bronco from 20 mph to a complete stop in 19.5 feet. That isn't a bad result for safety, but it isn't a great one for hardware this size. The Mercedes-AMG needed 20 feet and the Himiway C5 19, while the Revibikes Cougar stopped in 14 feet and the MEELOD DK300 in 16, both on two-piston calipers and smaller rotors. The motorcycle-style e-bikes we have tested average 17.8 feet.
The full stop, seen from above: across the 20 mph mark at speed and at rest 19.5 feet later.
The Tektro four-piston caliper and 203 mm rotor behind the Zoom air fork of the Ford Bronco E-Bike
Serious hardware: a Tektro HD-E740 four-piston caliper with 203 mm rotors. The stopping distance was ordinary.
Braking distance, 20–0 mph
Feet · shorter is better
Mercedes-AMG Rallye Edition20 ft
Ford Bronco19.5 ft
Himiway C519 ft
MEELOD DK30016 ft
Revibikes Cougar14 ft
Ford BroncoComparison bikesAverage of similar bikes (17.8 ft)
Where the Bronco sits: braking distance
Ford Bronco
14 ft (best motorcycle-style result)Braking distance23 ft (longest)
Bronco: 19.5 ftAverage of similar bikes: 17.8 ftFourth of five in the comparison group
Brake feel and modulation4/5Consistent lever feel makes braking easy to control, and the four-piston hydraulics feel powerful, even if the 19.5 ft. stop is only average.
Lights, signals, and visibility
Measured
The cockpit houses a 2,000-lumen headlight with high and low beams. On our center-beam measurement it put out 1,541 lux at 15 feet on high beam and 220 lux on low, among the brightest we have measured. An integrated taillight with brake activation sits in the rear. Turn signals are included too, but they live on the MIPS smart helmet, not on the bike. The remote paired quickly, the signals fire instantly and they are bright. Mounting the remote was another story: the one-piece cockpit is tapered and thick, and the only spot the rubber band would fit was right beside the right brake lever.
The integrated headlight: 1,541 lux at 15 feet on high beam, 220 lux on low.
The turn signals live on the helmet.
Headlight: 1,541 lux @ 15 ft, high beamLow beam: 220 luxAverage: 873 luxBrake light: YesTurn signals: On the helmet
Reflectives and side visibility2/5Minimal reflective elements.
Ride Quality and Handling
1 descriptor · 9 ratings
Riding the Bronco
Under power, the Bronco E-Bike feels sluggish. Throttle power is smooth but subdued, and pedaling is where this bike struggles most. Like most motorcycle-style e-bikes it has a fixed seat that sits low, the reach is long, and our knees were so cramped that during the range test we stopped pedaling and used only the throttle.
The suspension performed better than expected. On logging roads, gravel and easy dirt paths, the Bronco was comfortable and smooth, more so than the relatively inexpensive components suggested. It is still a far cry from the heavy-duty, go-over-anything suspension Ford describes. Given the weight, the sluggish power delivery, and the pedaling position, we wouldn't take it anywhere technical. What the Bronco does well is smooth out bumpy pavement and light off-road terrain. The Pirelli Scorpion tires grip well and look the part, though without fenders they throw up a lot of trail debris.
Dirt at an easy pace is fine. This is as technical as we would take it.
Overall comfort and composure3/5Comfortable and smooth on gravel, logging roads and easy dirt. Sluggish under power.
Cornering and agility2/5It's a lot of bike to move around when things get tight and technical, and the sluggish throttle doesn't help with clearing obstacles off-road.
Descending confidence3/5On light terrain, the suspension performs reasonably well and the bike is stable, but it quickly reaches its limits.
Riding unpowered3/5You feel every bit of the 72 pounds when pedaling without assistance.
Stability at top speed
Rated
On our stability run we ride the bike straight at speed, take our hands off the bars to check for shimmy, shift our weight, corner, and deliberately shake the bike to see whether we can start a wobble or a wander.
Stability at top speed3/5It felt stable, with no shimmy or extreme wobble, but something about the ride feels "off".
Comfort, suspension, and vibration
Rated
Suspension comes from a Zoom air fork with 120 mm of travel and a lockout, and a coil shock with rebound adjustment and a 50 mm stroke. Together they kept the Bronco comfortable over logging roads and gentle gravel and dirt paths. The fixed moto-style seat sits low, and you adjust your riding position by sliding along it.
The coil shock: 50 mm of stroke with rebound adjustment.
The coil rear shock and motocross-style linkage behind the Bronco lettering
Inexpensive hardware that worked better than expected on gravel and easy dirt.
Front end of the Ford Bronco E-Bike with its 120 mm Zoom air fork and Pirelli Scorpion tire
The Zoom air fork has 120 mm of travel and a lockout, behind a 27.5×2.6" Pirelli Scorpion.
Saddle comfort2/5It lacks padding and width, and it caused pressure points on longer rides.
Grips and pedals3/5Comfortable, grippy, well-textured lock-on grips that never felt slippery. The aluminum platform pedals have metal pins for traction, but are basic.
Suspension, fork3/5Performed fine on gravel, dirt, and bumpy pavement, but it's missing rebound adjustment.
Suspension, rear shock4/5Performed well.
Riding position
Descriptor
Where the Bronco sits on the spectrum from fully upright to fully aggressive. The low fixed seat and long reach stretch the rider forward:
Fit and Sizing
2 measurements · 2 checks · 2 ratings
True to size?
Verdict
Ford's US product page says the bike fits riders from 5'7" to 6'0", in one frame size, which begs the question of why there aren't more sizes. At 6'0" with a 33" inseam, we sit at the top of that range. We measured the effective seat height at 33 to 35.5 inches, found by sliding along the saddle, and the standover at 33 inches.
MeasurementFord claimsWe found
Rider height range5'7"–6'0"Cramped for pedaling at 6'0", the top of the range
Seat heightFixed seat33"–35.5" effective, by sliding along the saddle
Fits our tester (6'0", 33" inseam)Inside the claimed rangeYes on the throttle, no for pedaling
Claimed height range accuracy5" span on 2.5" of effective adjustment(5 − 2) ÷ 2.5 = 1.2×, inside our 2.0× limit
StandoverNot published33" (838 mm)
Our verdictOne size fits 5'7"–6'0"Tight at the top end
Graphic marking the 33 to 35.5 inch effective seat height of the fixed moto-style saddle
The only seat adjustment is where you sit: 33 inches at the front of the saddle, 35.5 inches at the back.
Our 6-foot tester seated on the Bronco with both feet down
At 6'0", the top of the claimed range: feet down easily, knees cramped when pedaling.
True to size3/5One size for 5'7"–6'0". Cramped for us at 6'0" when pedaling.
Cockpit adjustability
Rated
The one-piece aluminum bar and stem is fixed, the seat is fixed, and the only adjustment left is where you sit on the saddle. The integrated cockpit looks clean, with the display and headlight built in, but there is nothing to tune to your body. You adapt to it.
The one-piece cockpit of the Ford Bronco E-Bike with its integrated 3.5-inch display and headlight housing
One piece, no adjustment: the bar, stem, display and headlight are a single unit.
Cockpit adjustability1/5One-piece bar and stem and a fixed seat. Nothing to adjust but where you sit.
Build and Components
1 test · 6 ratings · facts
Weight, verified
Measured
Ford claims 68 lb. Our scale read 72.4 lb as shipped, with no fenders, rack or kickstand to account for the difference. That is 4.4 lb over the claim, yet the second-lightest bike in this comparison group behind only the Mercedes-AMG (69.4 lb), and well under the 90.6 lb average of the motorcycle-style e-bikes we have tested, several of which are fat-tire machines.
At 72.4 lb the Bronco is not light, but it's light for this category.
Measured weight, as shipped
Pounds · lighter is better
MEELOD DK300126 lb
Revibikes Cougar88 lb
Himiway C581.8 lb
Ford Bronco72.4 lb
Mercedes-AMG Rallye Edition69.4 lb
Ford BroncoComparison bikesAverage of similar bikes (90.6 lb)
Where the Bronco sits: measured weight
Compared to the 6 motorcycle-style e-bikes we have weighed
Ford Bronco
72.4 lb (lightest, the Bronco)Measured weight126 lb (heaviest)
Measured: 72.4 lb · as shippedClaimed: 68 lb6% over the claim
Rated
The 6061 aluminum motorcycle-style frame carries a one-piece bar and stem and an integrated battery and lights, so almost no wiring is on show. Our bike arrived well packaged and without damage.
The 6061 aluminum frame of the Ford Bronco E-Bike from the drive side
Clean lines: the battery lives in the down tube and the cables disappear into the one-piece cockpit.
Frame welds and finish4/5Very nice welds and a good finish.
Cable and wire integration5/5Integrated battery, lights and cockpit keep the wiring out of sight.
Rattles and squeaks5/5Quiet throughout testing, with no rattles or squeaks.
Drivetrain and shifting
Rated
The drivetrain is a Shimano CUES U4000 9-speed with an 11–36t cassette and a 40t chainring. Because of the riding position, we pedaled far less than usual, so the gearing saw less work than on most bikes we test.
Shimano CUES U4000, 9 speeds, 11–36t: the mechanical side of the Bronco is standard fare.
Shifting performance4/5The Shimano CUES 9-speed drivetrain shifted well and offered plenty of gearing range.
Tires and accessories
Rated
The 27.5"×2.6" Pirelli Scorpion Enduro M Hardwall tires grip well and look the part, though without fenders they throw up a lot of trail debris. The accessory list is short for the price: no fenders, no rack, no kickstand. What you do get is the MIPS smart helmet with its turn-signal remote, the 2,000-lumen headlight and the brake-activated taillight.
The 27.5 by 2.6 inch Pirelli Scorpion Enduro M Hardwall tire and 203 mm front rotor of the Ford Bronco E-Bike
Pirelli Scorpion Enduro M Hardwall, 27.5×2.6": good grip, but no fenders.
Tires4/5Pirelli Scorpions grip well and look the part. They throw debris without fenders.
Included accessories3/5MIPS smart helmet with turn-signal remote, headlight and taillight. No fenders, rack or kickstand.
✓ Arrived well packaged, mostly assembledFactory assembly audit:  0 issues on our unit✓ UL 2849 + UL 2271✗ IPX4, not for heavy rainNo fenders, rack or kickstand
Display, Controls, and App
2 ratings · facts
Display and controls
Rated
A 3.5-inch full-color screen is built into the one-piece cockpit, with graphics styled after Ford's infotainment system. Throughout testing its speed and battery readouts were accurate, and we could read it in bright sunlight. The power modes are stepped through on the bar. The turn-signal remote for the helmet is the odd one out, with nowhere to mount it on the thick, tapered bar but beside the right brake lever.
The integrated display boots with a Ford logo and reads accurately in bright sun.
The helmet's turn-signal remote, banded on beside the right brake lever, the only place it would fit.
Display readability5/5Accurate speed and battery readouts, readable in bright sunlight.
Controls4/5Intuitive and easy to use, but the turn-signal remote only fits beside the right brake lever.
Companion app
Fact check
There is no app. The four power modes, Eco, Normal, Sport and Baja, are selected on the bike, and the helmet's turn signals are driven by the handlebar remote.
✗ No companion appPower modes:  Eco, Normal, Sport, BajaCompanion app not rated
Assembly and setup
Rated
The Bronco arrived well packaged and, like the Mercedes-AMG from the same manufacturer, mostly assembled. Setup was easy: all we had to install was the handlebar and stem, the front wheel and the front light. The assembly time was not recorded on this bike.
The Ford Bronco E-Bike arriving mostly assembled in its shipping box
As it arrives: mostly assembled and well packaged, with the handlebar, front wheel and light left to fit.
Handlebar and stem, front wheel, light. Little else stands between the box and the first ride.
Assembly: handlebar, stem, front wheel, lightArrived: well packaged, mostly assembledAssembly time: not recorded
Assembly difficulty5/5Setup was easy: handlebar, stem, front wheel and light.
Manual and documentation4/5Good documentation. The provided manual walked through every assembly step without issue.
Support response, tested
Measured
Every brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For the Bronco the first useful answer arrived after 51 hours, against a 17.7-hour average across the brands we have tested.
First useful reply: 51 hAverage across brands: 17.7 h
Rated
The mechanical side is standard: a 9-speed Shimano CUES drivetrain, chain, Tektro brake pads, tubes and 27.5" tires are available everywhere. The electrical side and cockpit are proprietary to n+, a relatively new company in the e-bike space, so long-term warranty handling, customer support and parts supply are unknowns, and the proprietary components may be hard to source in the future.
Maintenance burden2/5Full suspension means a fork, a rear shock and pivot points to look after.
Serviceability and parts2/5Standard mechanicals, but the proprietary components may be hard to source in the future.
Component level for the price
Rated
At the Bronco's price, the spec sheet is a thin one.
Component level for the price2/5Budget components that don't match the hefty price tag.
Value for money
Rated
Weighing everything we measured against the price at the time of publication: a comfortable ride, 31 miles of range, bright integrated lights and a MIPS helmet on one side, and on the other the slowest acceleration in the group and budget suspension components. What you are paying for is the Ford Bronco branding. If you are a Bronco owner with plenty of cash who wants a brand-matched bike for the campground and easy trails, you may be satisfied. If you want true performance or off-road capability, this isn't the bike.
Scott riding the Ford Bronco E-Bike away down a rooty forest trail
Easy trails and campground duty are where the Bronco makes sense, if the badge is worth the price to you.
Value verdict2/5What you are paying for is really just the Ford Bronco branding.
Warranty:  2 yearsSold:  Direct, Ford BikesMade by:  n+Spare e-components:  proprietary, from n+
Data
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 88 e-bikes we have tested.
TestFord BroncoThis bikeAverage of similar bikesSimilarBikeRide averageAll bikes
Motor and performance
0–20 mph, throttlevs. 33 other 750W hub-motor e-bikes11.0 s9.6 s10.7 s
0–20 mph, max pedal assistvs. 34 other 750W hub-motor e-bikes10.0 s8.1 s8.4 s
Gradual hill climb, 20 mph-capped runsvs. 21 other 750W hub-motor e-bikes3:033:093:18
Steep hill climbvs. 31 other 750W hub-motor e-bikes2:272:282:36
Speedometer deviationvs. 6 other e-bikes0%+5%+5%
Motor noise @ 20 mph, unloadedvs. 6 other e-bikes70.9 dB(A)68.0 dB(A)68.0 dB(A)
Assist engagement delayvs. 6 other e-bikes0 crank rev0.4 crank rev0.4 crank rev
Range and charging
Range (max assist)vs. 6 other motorcycle-style e-bikes31.35 mi32.7 mi30.5 mi
Range vs claimedvs. 6 other motorcycle-style e-bikes52%49%55%
Efficiencyvs. 6 other motorcycle-style e-bikes23.0 Wh/mi33.6 Wh/mi25.2 Wh/mi
Charge time 0→100%vs. all e-bikes tested5.0 h6.3 h6.3 h
Braking and safety
Brake test, 20–0 mphvs. 6 other motorcycle-style e-bikes19.5 ft17.8 ft19.3 ft
Headlight @ 15 ft, high beamvs. 6 other e-bikes1,541 lux873 lux873 lux
Build and ownership
Measured weightvs. 5 other motorcycle-style e-bikes72.4 lb90.6 lb74.4 lb
Support response, tested (weekday hours)vs. 29 other brands51 h17.7 h17.7 h
Similar bikes: for the acceleration and hill-climb tests, e-bikes with a 750W nominal hub motor; for range, efficiency, braking and weight, motorcycle-style e-bikes; for the other rows, every e-bike we have tested; the support test is averaged per brand, since every brand is tested once. The gradual-hill row compares runs made with the 20 mph throttle cap in play, as the Bronco's was. Charge times are calculated from charger output and battery capacity. Not measured on this bike: medium-assist range, battery weight (integrated pack) and assembly time.
Detailed specs
As published by Ford for the Bronco E-Bike, with our component notes. Values we verified or debunked in testing are covered in Claimed vs. measured.
E-bike system
Electric bike classClass 3 (28 mph pedal assist, 20 mph throttle)
MotorUnbranded 750W rear hub
Max torque85 Nm (claimed)
Battery48V 15Ah (720 Wh), integrated
Range claimedUp to 60 miles
ThrottleYes, to 20 mph
Pedal assist4 modes: Eco, Normal, Sport, Baja
SensorTorque
Charger54.6V 3A
Charge time5 hours, calculated (3.5 hours claimed)
Display3.5" full-color, integrated in the cockpit
CertificationUL 2849 (electrical system), UL 2271 (battery)
Water/dust ratingIPX4 bike (motor IPX5, electronics IP66)
Warranty2 years
Components
Frame6061 aluminum, full suspension, one size
ForkZoom air, 120 mm travel, lockout
Rear shockCoil, 50 mm stroke, rebound adjustment
BrakesTektro Auriga+ levers, HD-E740 4-piston hydraulic, 203 mm rotors
DrivetrainShimano CUES U4000 9-speed
Chainring / cassette40t / 11–36t
Rims / tires27.5" 36H alloy / 27.5" × 2.6" Pirelli Scorpion Enduro M Hardwall
HandlebarOne-piece 6061 aluminum bar and stem
GripsLock-on
SaddleMotocross-style, fixed height
PedalsAluminum platform
LightsIntegrated 2,000-lumen headlight (high/low beam), integrated taillight with brake light
FendersNot included
KickstandNot included
Payload capacity287 lb (claimed, not tested)
IncludedMIPS smart helmet with turn-signal remote
Geometry details
Ford publishes no geometry chart for the Bronco, so these are our own measurements of the one frame size (claimed to fit 5'7"–6'0"). ✓ measured = measured on our test bike.
MeasurementOne size (claimed 5'7"–6'0")
Reach20.08" (510 mm)✓ measured
Stack21.65" (550 mm)✓ measured
Standover height33" (838 mm)✓ measured
Seat height, min–max (fixed seat, effective)33"–35.5" (838–902 mm)✓ measured
Wheelbase49.5" (1,257 mm)✓ measured
More
Video review
Watch Scott's full 10-minute review of the Ford Bronco E-Bike, including footage from every test above, on BikeRide's YouTube channel.
Lead E-Bike Tester · 80+ bikes tested
This bike was supplied by n+ for testing. Manufacturers never see our reviews before publication and cannot pay for a score. We earn a commission on purchases made through links on this page. It never affects results.
