How to Straighten a Bent Disc Brake Rotor
Learn how to easily straighten a bent disc brake rotor.
In this tutorial we will learn how to straighten a bent disc brake rotor.
What You’ll Need
For this job you will need a zip tie and wire cutters, and a disc truing tool or an adjustable wrench for straightening the disc.
Makeshift Gauge
The first step is to fasten a zip tie around the frame or fork, and cut the end about 1 cm away so that it lines up close to the disc. Position the cut end of the zip tie close to the disc so you can use it as a makeshift gauge and easily tell where and by how much the disc is bent.
Straightening
Using your truing tool or adjustable wrench carefully bend the disc a little bit at a time. Be careful not to bend it too much either way. Rotate the disc to check for true and then repeat as needed until the disc is as straight as possible. You likely won’t be able to get the disc perfectly straight, but using this method it should still be ridable. If the disc is too bent it’ll need replacing.
Related Links
Recommended Tools
- Park Tool DT-2C Rotor Truing Fork
- Tektro Hydraulic Bleed Kit
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
Categories
Latest post 4 hours agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreFront derailer not moving
Latest post 1 day agoHi, I been upgrading my old bike with new brake and shift cables. I got my brakes working and now trying to get my shift cables working. I was able to install new shift cable, I made sure to hold the cable tight and tighten the Bolt to keep in place. But it doesn't move the derailer at all when shifting. I have a feeling it's a simple fix that I'm missing something. I thought it might be the new ...
Read moreRear v-brake repair
Latest post 3 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 2 months agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Latest post 3 months agoCan anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Latest post 4 months agoHello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Latest post 4 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 50) Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Latest post 5 months agoMy wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read moreTrek domane tyre
Read more
