Aventon Ramblas ADV Review
Scott Clough-Carroll, Bike Testing and Video Production By Scott Clough-Carroll, updated Nov 6, 2026 | Tested using BikeRide Methodology 1.1 First-Hand Test
Our verdict
The Aventon Ramblas ADV is the second generation of the brand's hardtail e-MTB, with a 100 Nm mid-drive and 12-speed SRAM drivetrain. It posted solid results in all tests, and lasted 46.38 miles in a range test with medium assist, with the most climbing in our comparison group. On our steep hill, it was the fastest mid-drive we have timed. The basic coil fork and rattling cable count against the Ramblas ADV, but for newer riders on a budget who want to explore singletrack, it's a solid option.
  • Quickest mid-drive up our steep hill climb
  • 46.38 miles and 2,239 feet climbed with medium assist
  • Natural power delivery and wide 12-speed gearing
  • Stable and planted on green and blue trails
  • Tubeless-ready tires on pre-taped rims
  • Kickstand and removable headlight included
  • Basic coil fork with rebound adjustment only
  • XC tires give modest grip
  • Cable rattle inside the frame on rough terrain
  • The pedal can hit the charging cable
Claimed vs. measured
Aventon says the Ramblas ADV handles trails, serious climbs, and the daily commute. We checked the claims we can measure against our instruments. Here is the spec sheet next to what we measured:
ClaimAventon saysWe measuredVerdict
Weight54 lb55.0 lb, size L, 1.9% over≈ 2% over
Range (max claim)Up to 90 mi46.38 mi in Trail mode✓ 52% of claim
Charge time5 hours4.9 h by our calculation (19.67Ah ÷ 4A)✓ Verified
Fits our tester (6'0", 33" inseam)Size L fits 5'10"–6'2"A comfortable position on the size L✓ Yes
Claimed height range accuracyA 4" span of rider height (5'10"–6'2")11" of saddle-height adjustment: (4" − 2") ÷ 11" = 0.2×, inside our 2.0× limit✓ Verified
✓ = within tolerance · ≈ = close, with caveats · ✗ = fails our tolerance. Tolerances are defined in our test methodology.
Comparison
This bikeAventon Ramblas ADV, the e-MTB we testedAventon Ramblas ADV Velotric Summit 1 e-bike, side viewVelotric Summit 1 Aventon Aventure M fat-tire e-bike, side viewAventon Aventure M TENWAYS AGO X commuter e-bike, side viewTENWAYS AGO X
BikeRide Score 90 93 92 94
Best price $2,699.00 $1,239.00 $2,699.00 $1,849.00
Motor250W Aventon A100 mid-drive (750W peak)750W rear hub (1,300W peak)250W Aventon A100 mid-drive250W Bafang M410 mid-drive
Battery708 Wh706 Wh716 Wh504 Wh
Range tested (medium assist)46.38 mi Trail mode46.63 mi51.67 mi35.36 mi
Efficiency (medium assist)15.3 Wh/mi15.1 Wh/mi13.9 Wh/mi14.3 Wh/mi
Gradual hill climb3:193:033:053:20
Steep hill climb2:282:142:313:02
0–20 mph (pedal assist)6.0 s6.0 s7.0 s8.0 s
Brake 20–0 mph19.5 ft14.5 ft17 ft20 ft
Measured weight55.0 lb64.6 lb73.6 lb61.0 lb
Top speed20 mph as shipped, 28 mph in Class 320 mph as shipped, 12–28 mph adjustable20 mph as shipped, 28 mph in Class 320 mph
Torque (claimed)100 Nm90 Nm100 Nm80 Nm
Charge time4.9 h4.9 h5.0 h4.7 h
Suspension130 mm RockShox Psylo Silver R coil fork120 mm hydraulic fork with lockout80 mm fork with lockout, suspension seatpost110 mm fork with lockout
Drivetrain12-sp SRAM NX/SX Eagle, 10–50t8-sp Shimano Altus10-sp Shimano CUES, electronic shifter10-sp Shimano Deore
Tires29×2.4″ Maxxis Rekon, tubeless-ready27.5×2.6″ Kenda Honey Badger XC26×4″ Inova29×2.25″ CST
Frame6061 aluminum hardtail, M, L, and XLAluminum hardtail, Regular and LargeAluminumAluminum, step-over, three sizes
Assist sensorTorque, dual-sidedTorque or cadence (switched in the app)TorqueTorque
Water ratingIPX6 bike, IP67 motorIPX6 bike, IPX7 batteryIPX6 bike, IP67 motorIPX4
CertificationUL 2849 + UL 2271UL 2849 + UL 2271UL 2849 + UL 2271In progress when we tested it
Who should buy the Ramblas ADV
We believe the Aventon Ramblas ADV is a good choice for:
  • Newer trail riders on a budget. It felt stable and planted on flowy green and blue trails, and in Trail mode, steep climbs felt half as hard.
  • Riders who like to climb. It was the fastest mid-drive we have timed on our steep hill, and it covered 46.38 miles with 2,239 feet of climbing in our range test.
  • Riders who want one bike for trails and town. A kickstand and a removable headlight come in the box, and the app can unlock Class 3 (Trail or commuter?).
Scott on the Ramblas ADV on forest singletrack.
Who should NOT buy it
  • Riders who want technical terrain or jumps. Tight, technical trails with drops and jumps quickly found the limits of the tires and the entry-level fork.
  • Buyers who want a throttle. Like most mid-drive e-MTBs, the Ramblas ADV doesn't have one.
Before you buy: Trail or commuter?
Aventon positions the Ramblas ADV as an entry-level electric mountain bike or a commuter, and points riders who want a true e-MTB to its full-suspension Current. Here is how it did as each:
  • On the trail, it suits green and blue. It was stable and planted on flowy trails, but drops, jumps, and tight technical sections quickly found its limits.
  • For commuting, the basics come included. A kickstand and a removable headlight are in the box, and taillights are built into the seat stays. Aventon also sells a rear rack and fender set.
  • Class 3 is an app setting away. It ships as a Class 1 e-bike with assist to 20 mph, and the Aventon app can switch it to Class 3, with assist to 28 mph, where local laws allow.
The Aventon Ramblas ADV parked on a dirt trail beside green bushes
The Ramblas ADV on a forest trail.
If your riding mixes pavement with green and blue singletrack, the Ramblas ADV covers both. If you want technical terrain or jumps, you will quickly reach its limits.
Tests and Measurements
How we test
Every e-bike we review goes through the same standardized tests, performed the same way, on the same documented courses: range tests to motor shutoff, two hill climbs, acceleration, braking, and a verified weigh-in. Every result is stored in our database and shown against similar bikes and against the 90 bikes we have tested. Where a number can't be measured yet, we rate it 1–5 against written anchors, never a gut feeling. Read the full BikeRide Methodology 1.1 →
Test conditions — this review
Tester
6'0", 33" inseam
Rider + gear
200 lb
Weather
60–65°F, clear to cloudy, 47–63% humidity
Wind
3.8–6.7 mph
Tires
29×2.4", tubeless at 25 psi front and 26 psi rear (set up during testing)
Battery
100% within 24 h of test
Speed limit
20 mph for the range test and both climbs, plus a gradual-hill run in Class 3 (28 mph)
We tested the Ramblas ADV in May 2026.
Score breakdown — how the 90 was built
The BikeRide Score is a weighted roll-up of five pillar scores. Our tester scores each pillar out of 100 from the measurements and ratings listed under it: measured results by where the Ramblas ADV lands among similar bikes in our database, rated items by their written 1–5 anchors. Nothing from outside this page goes in, and every test result and rating on this page sits under one of the five pillars:
Motor and Performance
5 tests · 3 ratings · facts
Acceleration 0–20 mph
Measured
On maximum pedal assist we measured 6 seconds to 20 mph. That ties the Summit 1 for fastest in this comparison group, and beats the 7.3 s average of the mid-drive e-bikes we have tested. The Ramblas ADV doesn't have a throttle.
Scott setting off on the Ramblas ADV.
0–20 mph, max pedal assist
Seconds · shorter is faster
Aventon Ramblas ADV6.0 s
Velotric Summit 16.0 s
Aventon Aventure M7.0 s
TENWAYS AGO X8.0 s
Himiway Rambler12.0 s
Aventon Ramblas ADVComparison bikesAverage of similar bikes (7.3 s)
Max pedal assist: 6.0 sAverage of similar bikes: 7.3 sTies fastest in the group
Climbing Test 1: Gradual Hill
Measured
On the gradual hill (0.99 miles at up to a 6% grade) the Ramblas ADV finished in 3:19 at an average of 17.2 mph with the 20 mph limit. That is fourth of five in this comparison group, and 6 seconds slower than the 3:13 average of the mid-drive e-bikes we tested on capped runs. In Class 3 mode, without the cap, it took 2:56 at 19.7 mph.
Gradual hill climb, max assist, 20 mph cap
Minutes:seconds · shorter is faster · 0.99 mi · 79 ft gain · 6% max grade
Velotric Summit 13:03
Aventon Aventure M3:05
Himiway Rambler3:09
Aventon Ramblas ADV3:19
TENWAYS AGO X3:20
Aventon Ramblas ADVComparison bikesAverage of similar bikes, capped runs (3:13)
Ramblas ADV, 20 mph cap: 3:19 · 17.2 mph avgAverage of similar bikes, capped runs: 3:13Fourth of five in the group
Climbing Test 2: Steep Hill
Measured
On the steep climb, 0.65 miles with 226 feet of gain and a 12% maximum grade, the Ramblas ADV reached the top in 2:28 at an average of 15.8 mph. That is the fastest of the mid-drive e-bikes we have timed there, 21 seconds quicker than their 2:49 average.
The steep hill from the handlebar, with our test data overlaid.
Steep hill climb, max assist
Minutes:seconds · shorter is faster · 0.65 mi · 226 ft gain · 12% max grade
Velotric Summit 12:14
Aventon Ramblas ADV2:28
Aventon Aventure M2:31
TENWAYS AGO X3:02
Himiway Rambler3:05
Aventon Ramblas ADVComparison bikesAverage of similar bikes (2:49)
Ramblas ADV: 2:28 · 15.8 mph avgFastest mid-drive we have timedSecond in the comparison groupAverage of similar bikes: 2:49
Hill start on steep grade5/5Gets going on the steep grade with ease.
Assist modes and Auto mode
Fact check
There are three assist levels, Eco, Trail, and Turbo, plus an Auto mode, all customizable in the app. Trail mode, PAS 2 of 3, was our sweet spot for most riding. Eco still gave a real workout, and Turbo was too fast off the line for most trails, though welcome on steep, non-technical climbs. Auto mode switches between the three and did a decent job, but often gave more power than needed, costing range.
Switching assist modes on the display.
✓ Class 1 as shipped, Class 3 in the appTop speed:  20 mph as shipped, 28 mph in Class 3 (claimed)Assist levels:  Eco, Trail, Turbo, and AutoThrottle:  none
Class 3 e-bikes are limited to 28 mph on pedal assist. Many trails and multi-use paths restrict Class 3 access, so check local rules before riding there.
Assist engagement and cutoff
Measured
A torque sensor manages the assist. From a standstill, power arrived with no notable delay (0 crank revolutions), and on steep grades the power delivery felt natural and refined. The e-bikes we have measured average 0.2 crank revolutions before assist arrives.
Engagement delay: 0 crank revAverage: 0.2 crank revSensor: dual-sided torque
Motor engagement5/5No measurable delay from a standstill, with natural-feeling power.
Assist cutoff behavior5/5A smooth taper at both the 20 and 28 mph limits.
Motor noise
Measured
Measured indoors with the rear wheel spinning unloaded at 20 mph, the Ramblas ADV registered 57.0 dB(A), the second-quietest of the 17 e-bikes we have measured this way and well under their 66.6 dB(A) average. Most of the reading came from the drivetrain. The A100 mid-drive itself is very quiet.
The Aventon Ramblas ADV's A100 mid-drive motor and chainring, close up in the studio
The A100 mid-drive: 250W nominal, 750W peak, and 100 Nm.
Ramblas ADV: 57.0 dB(A) @ 20 mph, unloadedAverage: 66.6 dB(A)Second-quietest we have measured
Range and Charging
4 tests · 2 ratings · facts
Range Test 1: Trail mode (PAS 2 of 3, 20 mph limit)
Measured
On a loop of pavement, gravel, dirt paths, and trail laps in Trail mode, the Ramblas ADV lasted 46.38 miles with 2,239 feet of elevation gain, at an 11.3 mph average. Trail mode is the middle of three levels, so we compare this run with medium-assist runs. It is third of five in this group, around the 46.7-mile average of the mid-drives we have tested, but had the most elevation gain in the group.
Trail laps were part of our range loop.
Range at medium assist
Miles · longer is better · the Ramblas ADV in Trail mode
Aventon Aventure M51.67 mi
Velotric Summit 146.63 mi
Aventon Ramblas ADV Trail mode46.38 mi
Himiway Rambler42.62 mi
TENWAYS AGO X35.36 mi
Aventon Ramblas ADVComparison bikesAverage of similar bikes (46.7 mi)
Ramblas ADV, Trail mode: 46.38 mi · 2,239 ft climbed · 4 h 7 min · 11.3 mph avgAverage of similar bikes at medium assist: 46.7 miMost climbing in the groupThird of five in the group
Where the Ramblas ADV sits: range
Compared to the 6 mid-drive e-bikes we have tested at medium assist
Ramblas
35 mi (shortest mid-drive result)Range, medium assist58 mi (longest)
Range vs. claimed
Derived
Aventon claims up to 90 miles, for a 165 lb rider in Eco mode on flat pavement. Our only range run, 46.38 miles in Trail mode, is 52% of the claim, inside our tolerance.
Claimed: 90 miOur test: 46.38 mi (Trail mode)52% of claim vs. the 57% average for mid-drive e-bikes
Efficiency
Derived
Dividing battery capacity by measured range shows how far a bike stretches every watt-hour. At 15.3 Wh per mile, the Ramblas ADV is close to the 14.9 Wh/mi average of the mid-drive e-bikes we have tested at medium assist, and fourth of five in this group.
Energy used per mile
Wh/mi · lower is better · battery Wh ÷ medium-assist range
Himiway Rambler16.9
Aventon Ramblas ADV15.3
Velotric Summit 115.1
TENWAYS AGO X14.3
Aventon Aventure M13.9
Aventon Ramblas ADVComparison bikesAverage of similar bikes (14.9 Wh/mi)
Where the Ramblas ADV sits: efficiency
Ramblas
13.8 Wh/mi (most efficient mid-drive e-bike)Efficiency, medium assist16.9 Wh/mi (least)
Charge time
Calculated
The 36V battery charges on the included 4A charger, so by our calculation a full charge takes at least 4.9 hours (19.67Ah ÷ 4A), quicker than the 6.3-hour average across our database. The charge port sits behind a rubber cap on the seat tube. If you move the bike while it's plugged in, watch the cable because the pedal can hit it.
The Aventon Ramblas ADV's charge port on the seat tube, with its rubber cap open
The charge port, behind a rubber cap on the seat tube.
Charge time: 4.9 h (calculated)Claimed: 5 hAverage: 6.3 h
Fact check
The 36V 19.67Ah battery (708 Wh, LG cells) sits in the down tube behind a removable plastic cover, with a keyed lock whose keyhole is under the cover. The cover sits flush with the frame, seals well, and is easy to open and close. The battery weighed 8.4 lb on our scale. It is certified to UL 2271 and the electrical system to UL 2849, and Aventon rates the bike IPX6 and the motor IP67.
The battery unlocks with a key and slides out of the down tube.
✓ Removable battery, keyed lock under a flush coverBattery weight:  8.4 lb measured (8.44 lb claimed)✓ UL 2849 electrical system, UL 2271 battery✓ IPX6 bike, IP67 motor
Charge-gauge accuracy5/5The range estimate was accurate in our range test.
Battery removal and locking5/5A keyed lock under a flush cover that seals well and opens easily.
Trail Performance
1 verdict · 3 ratings
Climbing on the trail
Verdict
Climbing is where the Ramblas ADV shines. The mid-drive pairs well with the wide 12-speed range, so we could hold a steady cadence on steep grades while the natural-feeling assist worked its magic. In Trail mode, steep climbs felt half as hard, though our legs still worked and our breathing rose, and our tester could ride several laps of trails he usually rides just once on his regular mountain bike.
Rooty singletrack, seen from the handlebar.
Descending
Rated
Going downhill, you feel the 55 pounds. On flowy green and blue trails the Ramblas ADV felt stable and planted, but push into technical terrain with drops and jumps and you quickly reach the limits of the tires and the entry-level fork.
Flowy singletrack from the handlebar.
Descending confidence4/5Stable, with good fork behavior on flowy green and blue trails.
Stability at top speed5/5Very stable at 28 mph, and it tracks straight.
Cornering and agility
Rated
The Ramblas ADV handled flowy trails well, but we quickly found its limits on tighter, more technical sections. On steep or loose ground, the high weight and modest grip from the XC tires meant picking our lines carefully.
Through a berm on a forest trail.
Cornering and agility3/5Handles well on flowy MTB trails, but the weight and tires struggle on technical sections.
Suspension and Setup
1 rating · facts
Coil fork
Rated
The RockShox Psylo Silver R is a coil fork with 130 mm of travel and rebound adjustment only, with no compression adjustment or lockout. Lighter riders may find it stiff and heavier riders may bottom it out easily. At 200 lb, our tester found it performed better than its spec suggests on flow trails and moderate singletrack, and it bottomed out far less than he expected.
The Aventon Ramblas ADV's RockShox Psylo Silver R coil fork and front tire, seen from the front
The 130 mm RockShox Psylo Silver R coil fork.
Suspension, fork3/5Better than its spec suggests for a 200 lb rider, but rebound is the only adjustment.
Dropper post
Fact check
The X-Fusion Manic LC dropper post has 150 mm of travel on all three frame sizes.
The dropper post's 150 mm of travel.
Travel:  150 mm, all sizesSaddle height:  33.5"–44.5" from the ground (size L)
Tubeless setup
Fact check
The Maxxis Rekon tires are tubeless-ready and the rims come pre-taped, so converting is easy: you only need sealant and valves. We converted our test bike, and it was simple. Running tubeless at a lower pressure helped on steep and loose terrain.
Setting up a wheel tubeless in the workshop.
✓ Tubeless-ready tires✓ Pre-taped rimsTo convert:  sealant and valves
Ride Quality
1 descriptor · 5 ratings
Riding the Ramblas ADV
Rated
At 6'0" on the size L, our tester found a comfortable position almost immediately. Trail mode was the sweet spot for most riding, and the motor's power delivery felt refined and natural.
Scott on the Ramblas ADV on a gravel road.
Overall comfort and composure5/5A comfortable position from the start, and stable on flowy trails.
Riding unpowered3/5Pedaling is hard work without the motor.
Tires and traction
Rated
The 29×2.4" Maxxis Rekon tires have a cross-country tread. Going tubeless and running a lower pressure helped their grip, but on a bike this heavy we would want a slightly more aggressive tire, and it would be our first upgrade.
The Maxxis Rekon tread on the Aventon Ramblas ADV's rear tire, beside the seat stay
The Maxxis Rekon's cross-country tread.
Tires3/5A good match on flowy trails, but modest grip on loose terrain.
Saddle, grips, and pedals
Rated
The Aventon saddle sits on the 150 mm X-Fusion dropper, the Aventon grips lock on, and the pedals are aluminum platforms.
The Aventon saddle on the Aventon Ramblas ADV's X-Fusion Manic LC dropper post, outdoors on a dirt trail
The Aventon saddle.
A lock-on grip and SRAM DB6 brake lever on the Aventon Ramblas ADV's handlebar
A lock-on grip and the SRAM DB6 brake lever.
Saddle comfort3/5Typical mountain bike saddle.
Grips and pedals3/5Good lock-on grips, but basic platform pedals.
Riding position
Descriptor
Where the Ramblas ADV sits on the spectrum from fully upright to fully aggressive, on its 760 mm bar with 33 mm of rise:
Braking and Safety
2 tests · 2 ratings
Brake test: 20 to 0 mph
Measured
The SRAM DB6 four-piston hydraulic discs, with a 200 mm front and a 180 mm rear rotor, stopped the Ramblas ADV from 20 mph in 19.5 feet, 0.6 feet shorter than the 20.1-foot average of the mid-drive e-bikes we have tested, and fourth of five in this comparison group. On flowy green and blue trails, the brakes worked well.
The Aventon Ramblas ADV's front SRAM DB6 caliper and rotor on the Psylo fork
The front 200 mm rotor.
Braking distance, 20–0 mph
Feet · shorter is better
TENWAYS AGO X20 ft
Aventon Ramblas ADV19.5 ft
Himiway Rambler18.5 ft
Aventon Aventure M17 ft
Velotric Summit 114.5 ft
Aventon Ramblas ADVComparison bikesAverage of similar bikes (20.1 ft)
Where the Ramblas ADV sits: braking distance
Compared to the 7 mid-drive e-bikes we have tested
Ramblas
17 ft (best mid-drive result)Braking distance25.5 ft (longest)
Ramblas ADV: 19.5 ftAverage of similar bikes: 20.1 ftFourth of five in the comparison group
Brake feel and modulation4/5A good match for the bike on flowy green and blue trails.
Lights and visibility
Measured
Aventon includes a removable headlight, and the taillights are integrated into the seat stays. On our center-beam measurement the headlight put out 397 lux at 15 feet, below the 579 lux average of the 17 e-bikes we have measured.
The Aventon Ramblas ADV from behind in the studio with its seat-stay taillights lit red
The taillights, lit, in the seat stays.
The Aventon Ramblas ADV's cockpit from the front in the studio, with the headlight lit
The removable headlight, lit.
Headlight: 397 lux @ 15 ftAverage: 579 luxTaillights: integrated
Reflectives and side visibility1/5No reflectors or reflective trim, only the headlight and integrated taillights.
Fit and Sizing
2 measurements · 2 checks · 2 ratings
True to size?
Verdict
Aventon makes the Ramblas ADV in three sizes, and the size L we tested is listed for riders from 5'10" to 6'2", a 4-inch span served by 11 inches of saddle-height adjustment, dropper included (33.5" to 44.5" from the ground, measured on our test bike). By our rule of thumb that span is likely. At 6'0" with a 33" inseam our tester found a comfortable position almost immediately.
MeasurementAventon claimsWe found
Rider height range, size L5'10"–6'2"6'0" fits well
Saddle height, ground to top of saddle—33.5"–44.5" (851–1,130 mm), 11" of adjustment with the 150 mm dropper, measured on our test bike
Fits our tester (6'0", 33" inseam)Inside the claimed rangeYes, comfortable almost immediately
Claimed height range accuracy4" span of rider height(4 − 2) ÷ 11 = 0.2×, inside our 2.0× limit
Standover28.0" (712 mm)As published
Our verdictSize L fits 5'10"–6'2"Plausible
True to size5/5Fits our 6'0" tester comfortably, with plenty of saddle-height range for the 5'10" to 6'2" claim.
Cockpit adjustability
Rated
The 760 mm bar has a 35 mm clamp, 33 mm of rise, 3° of upsweep, and 9° of back sweep. It carries the full-color display in the middle, with the control pad on the left grip.
The Aventon Ramblas ADV's cockpit from the saddle: both grips, the color display in the middle and the RAMBLAS top tube
The cockpit from the saddle: a 760 mm bar with the display in the middle.
Cockpit adjustability5/5Standard MTB bar and stem sizes, easy to swap or upgrade.
Build and Components
1 test · 5 ratings · facts
Weight, verified
Measured
Aventon lists the Ramblas ADV at 54 lb. Our scale read 55.0 lb for the size L, 1.9% over the claim. It's the lightest bike in this comparison group and the lightest mid-drive we have weighed, but it's heavy for an e-MTB, especially one without rear suspension, and you feel it on the trails.
55 lb for the size L.
Measured weight
Pounds · lighter is better
Aventon Aventure M73.6 lb
Himiway Rambler67.0 lb
Velotric Summit 164.6 lb
TENWAYS AGO X61.0 lb
Aventon Ramblas ADV55.0 lb
Aventon Ramblas ADVComparison bikesAverage of similar bikes (65.0 lb)
Where the Ramblas ADV sits: measured weight
Compared to the 6 mid-drive e-bikes we have weighed
Ramblas
55.0 lb (lightest mid-drive e-bike, the Ramblas ADV)Measured weight73.6 lb (heaviest)
Measured: 55.0 lb · size LClaimed: 54 lb2% over the claimLightest in the group
Rated
The 6061 aluminum hardtail frame is SRAM UDH compatible, with 12×148 mm Boost dropouts, and comes in M, L, and XL. It looks great and feels well made, but one annoyance stayed with us: a cable rattle inside the frame on rough terrain.
The Aventon Ramblas ADV on its kickstand, from the non-drive side in the BikeRide studio
The size L from the non-drive side.
Frame welds and finish5/5Looks great and feels well made.
Cable and wire integration4/5Internal routing keeps the bike clean.
Rattles and squeaks3/5A cable rattle inside the frame on rough terrain.
Drivetrain and shifting
Rated
The 12-speed drivetrain mixes SRAM NX and SX Eagle parts: an NX derailleur and shifter, a 34t chainring, and a 10–50t cassette. The shifting came pre-indexed from the factory, and the wide range works well with the mid-drive, letting us hold a steady cadence on steep climbs.
The derailleur shifting across the 10–50t cassette.
Shifting performance4/5Good shifting, and pre-indexed out of the box, with plenty of gear range.
Included accessories
Rated
For commuting, Aventon includes a kickstand and a removable headlight, and the taillights are integrated into the seat stays. Fenders aren't included, but Aventon sells a rear rack and fender set for the Ramblas ADV.
The kickstand on the Aventon Ramblas ADV, seen low beside the motor and crank in the studio
The kickstand, included in the box.
Included accessories4/5A kickstand, integrated taillights, and a removable headlight.
✓ UL 2849 electrical system, UL 2271 battery✓ IPX6 bike, IP67 motorFrame:  6061 aluminum hardtail, M, L, and XL
Display, Controls, and App
3 ratings · facts
Display and controls
Rated
The full-color display sits in the middle of the bar, with the control pad on the left grip. Its range estimate was accurate in our range test, which took away any range anxiety.
The Aventon Ramblas ADV's full-color display on the handlebar, outdoors
The color display.
✓ Range estimate accurate in our range test
Display readability5/5A small but bright color display that's easy to read, with an accurate range estimate.
Controls5/5A simple control pad on the left grip that's easy to reach and use.
Companion app
Rated
The Aventon app can customize all four assist modes and switch the bike from Class 1 to Class 3, raising the assist limit from 20 to 28 mph.
Raising the speed limit from 20 to 28 mph in the app.
✓ Assist modes customizable✓ Class 3 unlock, up to 28 mph
Companion app4/5Customizes all four assist modes and unlocks Class 3.
1 test · 6 ratings · facts
Assembly and setup
Rated
The Ramblas ADV arrived well packaged, and Aventon's clever box design made unpacking simple. Assembly was easy: we installed the handlebar, front wheel, and pedals, plus the optional headlight and kickstand. The shifting came pre-indexed and the brakes ran true out of the box. Our factory audit found no issues.
The Aventon Ramblas ADV in its open shipping box in the BikeRide studio, still in its packaging
The Ramblas ADV in its box.
Front wheel running true out of the box.
✓ Shifting pre-indexed✓ Brakes ran true
Assembly difficulty5/5Easy and relatively quick.
Manual and documentation5/5Quick-start guides in the box, and good online information.
Support response, tested
Measured
Every brand we review gets the same test. We send one short, everyday support question through the brand's public support channel, from a regular customer account with no BikeRide affiliation, so the test is equal for everyone. We then time how long the first useful reply takes, counting weekday hours only. For Aventon the first useful answer arrived after half an hour, far quicker than the 18.1-hour average across the brands we have tested.
First useful reply: 0.5 hAverage across brands: 18.1 h
Rated
The fork, drivetrain, brakes, and dropper are entry-level MTB parts, but from recognized brands (RockShox, SRAM, and X-Fusion), so they should be easy to service, replace, or upgrade. The A100 motor, the battery, and the display are Aventon's own. Aventon covers the bike with a two-year warranty and the frame for life with registration.
Maintenance burden3/5Typical maintenance for a hardtail.
Serviceability and parts5/5Budget-level parts from recognized brands: easy to service, replace, or upgrade.
Component level for the price
Rated
Solid for the price. A 100 Nm mid-drive, a 708 Wh UL-certified battery, a 12-speed SRAM Eagle drivetrain, four-piston SRAM brakes, a 150 mm dropper, and tubeless-ready Maxxis tires.
Component level for the price4/5The component list reads well. Tires would be the first upgrade.
Value for money
Rated
Weighing everything we measured against the price at the time of publication: the fastest steep-hill climb of any mid-drive we have timed, 46.38 miles with the most climbing in our comparison group, the lowest weight in the group, and natural mid-drive power with wide 12-speed gearing. Against that, a basic fork, XC tires, and a cable rattle. The Ramblas ADV demonstrates good value.
The Aventon Ramblas ADV parked on a dirt trail, side-on from the drive side
The Ramblas ADV from the drive side, on the trail.
Value verdict4/5A capable entry-level hardtail that delivers real value.
Warranty:  2 years, lifetime frame warranty with registration
Data
Full test results
Every measurement from this review in one table, against the average of similar bikes and the average of all 90 e-bikes we have tested.
TestAventon Ramblas ADVThis bikeAverage of similar bikesSimilarBikeRide averageAll bikes
Motor and performance
0–20 mph, max pedal assistvs. 7 other mid-drive e-bikes6.0 s7.3 s8.4 s
Gradual hill climb, 20 mph capvs. 5 other mid-drive e-bikes3:193:133:18
Steep hill climbvs. 5 other mid-drive e-bikes2:282:492:36
Motor noise @ 20 mph, unloadedvs. 16 other e-bikes57.0 dB(A)66.6 dB(A)66.6 dB(A)
Assist engagement delayvs. 16 other e-bikes0 crank rev0.2 crank rev0.2 crank rev
Range and charging
Range (medium assist, Trail mode)vs. 5 other mid-drive e-bikes46.38 mi46.7 mi39.1 mi
Range vs claimedvs. 7 other mid-drive e-bikes52%57%54%
Efficiency (medium assist)vs. 5 other mid-drive e-bikes15.3 Wh/mi14.9 Wh/mi19.4 Wh/mi
Charge time 0→100%vs. all e-bikes tested4.9 h6.3 h6.3 h
Braking and safety
Brake test, 20–0 mphvs. 6 other mid-drive e-bikes19.5 ft20.1 ft19.3 ft
Headlight @ 15 ftvs. 16 other e-bikes397 lux579 lux579 lux
Build and ownership
Measured weightvs. 5 other mid-drive e-bikes55.0 lb65.0 lb74.7 lb
Battery weightvs. 13 other e-bikes8.4 lb11.7 lb11.7 lb
Support response, tested (weekday hours)vs. 31 other brands0.5 h18.1 h18.1 h
Similar bikes are the mid-drive e-bikes for acceleration, the climbs, range, efficiency, braking, and weight, and all e-bikes for the other rows. Support is averaged per brand. Range and efficiency compare our Trail-mode run with medium-assist runs. Charge time is calculated from charger output and battery capacity.
Compare it with every bike we've tested
Range, hill climbs, braking and 31 ratings in one sortable table.
Bike Test Results
Detailed specs
As published by Aventon for the Ramblas ADV we tested, with component details from our tester's notes. Values we verified in testing are covered in Claimed vs. measured.
E-bike system
Electric bike classClass 1 as shipped, Class 3 in the Aventon app
MotorAventon A100 mid-drive, 250W nominal, 750W peak
Max torque100 Nm (claimed)
Battery36V, 708 Wh (19.67Ah by our calculation), LG 21700 cells, removable, keyed lock
Range claimedUp to 90 miles (Eco mode, 165 lb rider, flat pavement)
Top speed20 mph as shipped, 28 mph in Class 3 (claimed)
ThrottleNone
Pedal assistEco, Trail, Turbo, and Auto, customizable in the Aventon app
SensorDual-sided torque sensor
Charger42V 4A
Charge time5 hours claimed, 4.9 hours calculated
DisplayFull-color LCD (Aventon BC201)
CertificationUL 2849 (electrical system) and UL 2271 (battery)
Water/dust ratingIPX6 bike, IP67 motor
Warranty2 years, lifetime frame warranty with registration
Components
Frame6061 aluminum hardtail, SRAM UDH compatible, 12×148 mm Boost, sizes M, L (tested), and XL
ForkRockShox Psylo Silver R coil, 130 mm travel, rebound adjustment only
BrakesSRAM DB6 four-piston hydraulic, 200 mm front and 180 mm rear rotors
DrivetrainSRAM NX Eagle 12-speed derailleur and shifter, SX Eagle cassette
Chainring / cassette34t / 10–50t
Rims / tires29" 32-hole, tubeless-ready and pre-taped / 29" × 2.4" Maxxis Rekon, tubeless-ready
Dropper postX-Fusion Manic LC, 150 mm travel on all sizes
Handlebar760 mm, 35 mm clamp, 33 mm rise, 3° upsweep, 9° back sweep
GripsAventon lock-on
SaddleAventon
PedalsAluminum platform
LightsRemovable headlight, taillights integrated into the seat stays
Fenders / rackNot included. Aventon sells a rear rack and fender set
KickstandIncluded
Payload capacity300 lb
Geometry details
As published by Aventon for the size L. ✓ measured = Aventon doesn't publish this figure, so it's our own measurement.
MeasurementSize L (tested, claimed 5'10"–6'2")
Seat tube17.7" (450 mm)As published
Reach17.9" (455 mm)As published
Stack26.2" (665 mm)As published
Standover height28.0" (712 mm)As published
Virtual top tube25.3" (642 mm)As published
Head tube angle66.5°As published
Seat tube angle74.5°As published
Chainstay18.3" (465 mm)As published
Wheelbase48.4" (1,230 mm)As published
Saddle height, min–max33.5"–44.5" (851–1,130 mm)✓ measured
More
Video review
Watch Scott's full 10-minute review of the Aventon Ramblas ADV, including footage from every test above, on BikeRide's YouTube channel.
Lead E-Bike Tester · 90+ bikes tested
This bike was supplied by Aventon for testing. Manufacturers never see our reviews before publication and cannot pay for a score. We earn a commission on purchases made through links on this page. It never affects results.
