We earn affiliate commission.
Learn more
6, 7 Hours
45, 60 Miles
1000 W
160 Nm
48V 17.5Ah
73 lb
We have read all expert and user reviews on the Addmotor Wildtan M-5600. In summary, this is what cyclists think.
17 reasons to buy
- A huge 1000W Bafang Mid-Drive motor crushes mountains with 160Nm of torque.
- The M-5600 has absolutely massive 4.5” wide tires, for riding across quicksand.
- A real-world range of 30 miles can be expected, due to a big 48V 17.5Ah battery.
- Reviewers say the Shimano Alivio 9-speed drivetrain is strong under load.
- Shimano’s Alivio shifter allows fast shifting of up to 3 gears at a time.
- Tektro Auriga hydraulic brakes & 180mm rotors bring the M-5600 to an abrupt halt.
- Motor inhibitors better slow the M-5600 and prolong brake life.
- The M-5600 is rated to carry 350lb of rider and cargo.
- Impacts are cushioned by a 120mm-travel, inverted, air suspension fork.
- The M-5600’s battery is lockable and removable, for security and remote charging.
- Buyers have three colors to choose from; ‘Classic Black’, ‘Volcanic Ash’ & Camo.
- The camouflaged Wildtan M-5600 suits backwoods hunters.
- Front and rear Spanninga lights are included. The headlight is integrated.
- Internal routing keeps the M-5600’s cables protected and tidy.
- A USB-C charging point allows you to juice up your devices, on the go.
- The M-5600 uses a large color display.
- At this time, a durable rear rack is included in the M-5600’s package.
- The M-5600 lags in engaging and disengaging assistance because it is equipped with a cadence sensor.
- You can't lug 73lb of e-bike up to your walk-up and hang it on your wall.
- This pricey pedelec doesn’t come cheap.
- Due to its corpulent build, the M-5600 exhibits lethargic handling characteristics.
- The unbranded air suspension fork bottoms out easily on rough trails.
- The M-5600’s display can be difficult to read under bright sunlight.
- Testers say the included lights increase visibility but could be brighter in pitch darkness.
The Addmotor Wildtan M-5600 Mid-Drive E-Bike is a large and powerful option. A 1000W BBSHD Bafang mid-drive motor outputs 160Nm of torque for capable climbing. The M-5600 tramples backwoods, dirt roads and fields with its inconceivably wide 4.5” tires. But testers also enjoyed using it to cruise downtown areas. With this hefty build, it isn’t the nimblest of rides and won’t be easy to carry upstairs. Pedal-assist delays are present with the cadence sensor used. A torque sensor is more common with other higher-priced mid-drive bikes. If you’re after a hardtail e-bike that can climb every mountain and ford every stream, check out the Wildtan. It could be your scene.Expert Reviews
76/100 based on 2 rated expert reviewsAddmotor Wildtan E-bike Review: 1,000 Watts of Fat Tire Electric Bike Excess!
Addmotor Wildtan M-5600 Review: World’s Fattest Fat Tire Electric Bike
Addmotor Wildtan M-5600 Review – Best Off-Road E-Bike?
The Fastest Most Powerful Electric Bike We Tested // Addmotor Wildtan M-5600 Detailed Review
Addmotor Wildtan M-5600 in comparison to averages
12 hours ago
1 day ago
