Velotric Nomad 2 vs Aventon Aventure 3
Velotric Nomad 2
92/100
Aventon Aventure 3
92/100
Specifications
Specifications
Velotric Nomad 2
Aventon Aventure 3
Men, Women
Men, Women
Type
Fat Tire, Comfort, Electric
Electric, Fat Tire, Comfort
2025
Velotric
Aventon
5 Hours
5 Hours
65 Miles
65 Miles
90 Nm
80 Nm
48V 14.7Ah
36V 19.88Ah
Class 2, Class 3, Unrestricted
Class 2, Class 3
Hub-Drive
Hub-Drive
26"
26"
8
External Derailleur
External Derailleur
82, 84 lb
77, 78 lb
Front, Seatpost
Front, Seatpost
Disc: Hydraulic
Disc: Hydraulic
Aluminum
Aluminum
Velotric Nomad 2
We have read all expert and user reviews on the Velotric Nomad 2. In summary, this is what cyclists think.
  • Velotric’s Nomad 2 comes as a step-through or step-over, both available in Regular and Large sizes.
  • Experts say the 4” puncture-resistant Kenda tires provide excellent traction on loose gravel, sand, snow, and dirt trails.
  • The Nomad 2 has both torque and cadence sensing modes.
  • Testers praise the comfortable ride over varied terrains thanks to the 100mm RST Guide fork, 50mm suspension seatpost, and fat tires.
  • Reviewers appreciate the steady and strong throttle power, which can overcome steep hills.
  • Pedal assist is smooth and responsive in torque-sensing mode.
  • The Tektro hydraulic disc brakes (203mm front, 180mm rear) prove powerful in testing.
  • The Nomad 2 has reach-adjustable brake levers and an adjustable stem with 60 degrees of movement.
  • The Nomad 2 is rated to carry a massive 421lb payload and tow up to 1,000lb.
  • Riders can switch between torque and cadence-sensing modes, customize throttle and PAS speeds, and switch e-bike classes using the display or Velotric’s app.
  • The bike features a USB-C port and Apple Find My tracking, though the tracking doesn’t work with Android devices.
  • The Nomad 2 comes with fenders, a 66lb-capacity MIK-HD rear rack, an auto-on headlight, and a taillight with turn signals and brake activation.
  • Velotric lists the weight at 75lb, but reviewers weigh the bike at 82lb (step-over) and 84lb (step-through).
  • The throttle can be unlocked to a max speed of 28mph, breaching the legal limit. Testers also report reaching up to 32mph with pedal assist.
  • Weighing 82 to 84lb, the Nomad 2 is very heavy.
  • Using PAS 5 with the torque sensor and Boost mode, a 160lb reviewer gets just 23.6 miles of range on a flat paved route. Experts say the battery drains even faster in cadence sensor mode.
  • The 15 PAS settings (three modes with five levels each) are “overkill,” according to testers.
  • Riding in cadence-sensing mode, a reviewer complains of jerky power delivery.
  • Experts agree the bike’s high weight and size limit its maneuverability.
Velotric’s Nomad 2 is a fat-tire e-bike with a 750W motor and 705.6Wh battery. Upgrades over the Nomad 1 Plus include a torque sensor, rear rack, suspension seatpost, a longer-travel fork, and a move to branded components like Tektro, RST, and Kenda. Experts praise the climbing performance, braking power, grippy tires, high payload capacity, and comfortable ride over rough terrain. The customizability of assist settings also impresses. The actual weight is higher than advertised, the unlocked throttle exceeds legal speed limits, and range is underwhelming. Overall, reviewers consider the Nomad 2 among the best fat-tire e-bikes on the market.
Aventon Aventure 3
We have read all expert and user reviews on the Aventon Aventure 3. In summary, this is what cyclists think.
  • The Aventon Aventure 3 comes as a step-through or step-over, each available in two sizes.
  • Experts praise the smooth and responsive power delivery, whether using pedal assist or the throttle.
  • In testing, the Aventure 3 handles steep hills under throttle power alone.
  • Testers find the ride comfortable over light off-road terrains like grassy trails, dirt roads, and gravel paths.
  • The Aventure 3 comes with a MIK-compatible rear rack rated for 59lb, fenders, a headlight, and integrated taillights with brake activation and turn signals.
  • A 155lb reviewer gets an above-average range of 35.8 miles using PAS 5 in Class 2 mode on a flat paved route.
  • Multiple testers say the Aventure 3 is easy to maneuver for a fat-tire e-bike.
  • The Aventure 3 has GPS tracking, Geofencing, keyless battery access, auto rear wheel lock, and a motion sensor alarm.
  • The 4A charger returns reasonable charge times of up to five hours.
  • Riders can customize the PAS top speed in mile-per-hour increments (up to 28 mph) and tune the power output for each level using Aventon's app.
  • The display has a USB-A charging port.
  • Aventon has over 1,800 dealers in the US for easier access to support and servicing.
  • At a tested weight of 78lb, the Aventure 3 is heavy, though this weight is typical for 26" fat-tire e-bikes.
  • The Aventure 3 doesn't have a bell or horn.
  • Aventon’s security features require a small subscription fee after the first year.
  • Two reviewers say the built-in alarm isn’t loud enough.
  • The battery’s charging port is awkward to access, according to a tester.
  • One reviewer finds the rear wheel lock makes tire removal and replacement difficult.
Aventon's Aventure 3 is a fat-tire e-bike with a 750W motor and 715.7Wh battery. The bike comes as a step-through or step-over. Upgrades over the previous version include a suspension seatpost, improved cable routing, PAS customization, and security features. The responsive power delivery, climbing ability, solid range, and comfortable ride impress. Smart security features, ride customization, and accessories also win points. Complaints are minor, but the lack of a horn disappoints. Overall, reviewers feel the Aventure 3 offers excellent value as a fat-tire e-bike.
Velotric Nomad 2
Aventon Aventure 3
Velotric Nomad 2
Comparison to averages
Aventon Aventure 3
