Ride1UP REVV 1 DRT
83/100
5 Hours
60 Miles
34 mph
1000 W
95 Nm
52V 20Ah
94.1 lb
We have read all expert and user reviews on the Ride1UP REVV 1 DRT. In summary, this is what cyclists think.
  • Riders can quickly switch between Class 2, Class 3, and ‘Off-Road’ modes via the display. In its unrestricted mode, the bike can only be used on private property.
  • With the bike in Off-Road mode, testers reach speeds up to 34mph using the throttle on flat pavement.
  • Reviewers enjoy the upright riding position and say the suspension, especially at the rear, provides a very comfortable ride on pavement and dirt trails.
  • The four-piston hydraulic disc brakes and 203mm rotors demonstrate great stopping power in testing.
  • An expert praises the bright LED lights. The taillight has brake activation, and the headlight has multiple beam modes.
  • Testers appreciate the relatively gentle throttle acceleration in Class 2 and Class 3 modes. Boost mode provides maximum torque, for faster acceleration.
  • Ride1UP provides a 4A fast charger for a five-hour charge time.
  • The display has a USB port for charging devices.
  • Experts agree the REVV 1 DRT looks great.
11 reasons not to buy
  • Two reviewers report the controller overheating after short, steep climbs. This reduces power, cutting the max speed to roughly 10mph.
  • All experts say pedaling for extended periods is uncomfortable and impractical.
  • Because full power is always available, it is difficult to modulate speeds using the throttle.
  • A tester receives a bike with a faulty fork that makes a “terrible” sound when topping out its travel.
  • This bike weighs 94lb and measures 78” long, making it extremely difficult to maneuver unpowered, lift, or transport.
  • The REVV 1 DRT is very tall, with a 34” standover height. This will make mounting a challenge for shorter riders.
  • Experts say the 4" Innova tires lack the grip needed for technical off-roading and struggle to hold grip when cornering. The bikes easily slides out on loose sand in testing.
  • The “tiny” fenders are ineffective at blocking dirt and debris.
  • Battery range disappoints, especially compared to the regular REVV 1 FS. Reviewers get around 26 miles of throttle-only riding on primarily flat routes.
  • The bike’s heavy weight makes assembly a two-person job.
  • Reading the display is difficult in direct sunlight.
The REVV 1 DRT is the off-road member of Ride1UP’s motorcycle-style model family. Changes for this version include a longer frame, more suspension travel, knobby tires, and spoked wheels. Testers praise the fast acceleration in Boost mode, plush rear suspension, powerful brakes, and thrilling top speed. The main concern is a controller that easily overheats, as recorded by two testers following short hill climbs. Additionally, the tires lack grip, battery range is poor, and speed is hard to control using the throttle in Off-Road mode. While ride reviews are positive, the low-quality controller and underwhelming off-road performance should give buyers pause.
83/100 based on 2 rated expert reviews
Ride1UP REVV 1 DRT Review | If the Road Ends, the Ride Won’t
A little enhanced speed control might be nice… But those in the market for a fun all-around moped option will be more than happy with the REVV 1 DRT, so long as it fits the budget.
If you plan to conquer any serious hill climbing, this might not be the machine to do it on. If you’re looking for a versatile e-bike that you can pedal and get some exercise on, it’s still not the right bike for you.
Ride1UP REVV 1 DRT Review: The Ultimate Off-Road Moped-Style E-Bike
The Ride1UP REVV 1 DRT is a top contender in the moped-style e-bike category, offering impressive power, comfort, and design. While it’s on the heavier side and less optimized for pedaling…
Shreddie McSkate
Ride1UP REVV 1 DRT: Off-Road Electric Moped Beast! Speed Test, Review, & Racing!
I’ve had a lot of fun on today’s review, even though we had one overheating issue. But that taught me that you can’t go super hard when you have this in boost mode.
#294 Best Electric Bike
Bottom 50%
#22 Best Moped Bike
Top 40%
#8 Best Ride1UP Bike
Bottom 20%
#543 Best of All Bikes
Bottom 50%
Ride1UP REVV 1 DRT in comparison to averages
