We have read all expert and user reviews on the Retrospec Koa Rev 2. In summary, this is what cyclists think.
- The Koa Rev 2 is available in a step-over or step-through frame.
- Multiple testers get more than 40mi in PAS 1 and 20mi in PAS 6. Though these results fall short of the stated 52mi range, experts deem them respectable and practical.
- Reviewers say the 4” wide fat tires and suspension fork do a good job of absorbing most bumps.
- Experts appreciate the combination of agile handling and stability, thanks to the 700mm handlebar and fat tires.
- Testers are impressed by the instant motor engagement and smooth, controlled power delivery from both throttle and PAS.
- In testing, the Tektro mechanical disc brakes demonstrate better stopping power than the brakes on similar e-bikes.
- The Koa Rev 2 can be set to Class 2 (20mph) or Class 3 (28mph) operation.
- Reviewers find the upright seating position comfortable.
- Testers are pleased with the 26” x 4” knobby tires' traction on mixed surfaces.
- The Koa Rev 2 has a headlight, a taillight with brake activation, and fenders.
- Retrospec publishes no useful data on rider fitment or the bike's geometry or weight. Getting information out of them is like pulling teeth.
- Testers find the Koa Rev 2 can’t climb a 12% incline using the throttle, and is very slow using PAS.
- A 230lb tester finds the suspension fork too soft, even after increasing the preload.
- An expert reports ghost pedaling from around 25mph.
- Reviewers 6' and taller find the reach too short. The high minimum seat heights of 35" (step-over) and 32.5" (step-through) make the bike too big for smaller riders.
- A reviewer highlights the risk of damage to the exposed cadence-sensor wire hanging under the bottom bracket.
The Retrospec Koa Rev 2 is a fat tire e-bike with a 500W motor and 500Wh battery. It is available as a step-over or step-through. Reviewers praise the agile yet stable handling, strong brakes, comfortable ride, and smooth, responsive power delivery. Battery range is decent, but the bike struggles up steep hills. Reviewers are less impressed by the too-soft suspension fork, ghost pedaling, and uninspiring design. Also, Retrospec provides no guidance whatsoever on geometry or rider fit. Overall, experts think the Koa Rev 2 is good value as a no-frills ride for pavement and smooth trails.Expert Reviews
90/100 based on 1 rated expert reviewRetrospec Koa Rev 2 ST Review | Stable & Simple
Retrospec Koa Rev 2 Review: Simplicity Meets Value
Retrospec Koa Rev 2
19 hours ago
24 hours ago
