Rattan Pinus
84/100
4.5, 9 Hours
80, 150 Miles
80 Nm
48V 20Ah, 48V 40Ah
81, 92 lb
We have read all expert and user reviews on the Rattan Pinus. In summary, this is what cyclists think.
  • The Pinus is available with one 960Wh battery or two batteries totaling 1,920Wh.
  • The immediate acceleration from the responsive throttle impresses testers.
  • Reviewers enjoy the comfort provided by the upright riding position, suspension fork, fat tires, and sprung saddle.
  • An expert easily climbs a 20% grade using throttle only.
  • Experts praise the strong stopping power of the Fast Ace hydraulic brakes and 180mm rotors.
  • The Pinus comes with a headlight, taillight with brake activation, turn signals, fenders, and a rear rack rated for 100lb.
  • Reviewers say the low step-through standover height of 15.75” makes it easy to mount and dismount.
  • Testers appreciate the easy-to-use color display and the inclusion of a USB-A charging port.
  • The Kenda Krusade Sport 20” x 4” knobby tires have good traction in varied terrain, according to experts.
  • Testers easily reach this bike's 28mph top speed.
  • The 4.5A fast charger means one battery charges in about 4.5 hours.
  • A reviewer finds the Pinus easy to maneuver.
12 reasons not to buy
  • This bike's high weight (81lb with one battery, 92lb with two) and large size, even when folded, may make it hard to transport.
  • The controller on a test bike fails after half a mile.
  • The Pinus is delivered with a 28mph throttle, which doesn't comply with any e-bike classes.
  • A reviewer is unimpressed by this bike's off-road abilities despite the knobby fat tires.
  • Testers notice no difference in performance when changing the slow-start setting or switching between ride modes.
  • At 31.1” x 35.4” x 53.1”, the folded Pinus is larger than most other 20” e-folders.
  • The controller blocks the seatpost, preventing it from being lowered fully.
  • Two experts find it difficult to install the second battery.
  • A tester thinks the bike needs a bigger chainring, but the folding design might make this impossible.
  • The dual-battery Pinus comes with only one charger, meaning long charging times.
  • Although the stated rider height is 5’3” to 6’4”, an expert says this bike only suits riders under 6’.
  • A tester complains of pedal strikes in corners and thinks the cranks are too long.
Rattan's Pinus is a folding fat-tire e-bike with a 750W motor and choice of one 960Wh battery or two. The responsive throttle, quick acceleration, and hill-climbing ability impress experts who praise the comfort, strong brakes, and fast charger. However, the Pinus is big and heavy for a 20" folder, the torque sensor requires too much pedal effort, and changing performance settings has no discernible effect. The two-battery model includes only one charger, the 28mph throttle may be illegal, and one test bike fails in under half a mile. Ultimately, in a crowded market, the Pinus fails to convince experts.
80/100 based on 3 rated expert reviews
Electric Revolution
Rattan Pinus Electric Foldable Fat Tire E-Bike Review
The most appealing feature about this bike for me has got to be the dual batteries.
Jeremiah Mcintosh
Rattan Pinus Dual Battery Long Range E-Bike Review
You do have to put a little bit more effort into this torque sensor than some other bikes I’ve tested, but the throttle overrides it very easily. When you’re in PAS 5, you can go max speed with the throttle.
Mountain Weekly News
Rattan Pinus E-Bike Review
… the Rattan Pinus is a feature-loaded e-bike that’s after the hearts of long-distance riders. The overloaded design could probably do without a folding hinge and front suspension…
Riding My Pinus: Rattan’s New Awkwardly-Named E-bike Is a Lot of Fun!
Ultimately, the Rattan Pinus isn’t that different from many other 20″ wheel folding fat tire electric bikes out there. Sure, it’s got a funny name, but at the end of the day, it’s still your basic high-power, high-speed, moderate-quality runabout.
How the Pinus Gets Big Range – Rattan Pinus Review
It’s topping us out right around 28mph… these brakes are strong. We do have a little bit of extra rotational mass on those mag wheels compared to spoke wheels, and the extra battery on here brings a little extra weight.
#268 Best Electric Bike
Top 50%
#48 Best Folding Bike
Top 50%
#3 Best Rattan Bike
Bottom 50%
#499 Best of All Bikes
Bottom 50%
Rattan Pinus in comparison to averages
