We earn affiliate commission.
Learn more
40 Miles
1000 W
160 Nm
48V 17Ah
70 lb
We have read all expert and user reviews on the Rambo The Prowler. In summary, this is what cyclists think.
20 reasons to buy
- Say Watt? The Prowler’s 1000W Bafang motor puts out 1500 peak watts of power.
- An Enviolo CVT (continuously variable transmission) hub provides the Prowler with a 380% gear range, using a simple, step-free shifting system.
- The Prowler is brought to a stop by strong Tektro 4-piston hydraulic disc brakes.
- A reviewer was able to easily reach 30mph, using only the Prowler’s throttle.
- A reviewer was able to achieve 35mph on flats with pedaling and assist.
- The Prowler comfortably conquers obstacles on huge Maxxis Minion FBF and FBR 27.5" x 3.8" tires.
- Many bosses and mount-points cover the Prowler’s frame to attach accessories such as racks, a trailer, bottle-holders, bags, baskets and extra batteries.
- The Prowler’s Bafang display is clear, easy-to-read and its angle can be adjusted.
- The Prowler is rated to carry a 300lb payload, be it rider, cargo and/or catch.
- The Prowler’s battery is lockable and removable, for security or off-bike charging.
- For some owners, the Prowler is easy to assemble.
- Riders from 5’10" to 6’2” say they love the fit of the Predator.
- Owners say the Prowler moves very quietly, almost silently.
- With a wide gear range and powerful motor, the Prowler smashes steep hills.
- A concealed internal battery gives the Prowler a sleek physique.
- A tester says the Prowler’s torque sensor is very precise, giving smooth support.
- Thru-axle hubs stiffen up the Prowler on real mountain bike trails.
- Wide, 770mm Promax handlebars provide lashings of control.
- A GT860 air suspension inverted moto-style fork equips the Prowler with 120mm of trail-smoothing travel.
- The Prowler is draped in Rambo’s own in-house ‘TrueTimber VSX’ camo colorway.
4 reasons not to buy
- The Prowler is pricey.
- The Prowler is only available in a single 19.7″ frame size.
- Information is scarce on the Prowler’s fork, from the little-known brand GTMRK.
- A reviewer found that the Prowler’s powerful motor ‘chewed through the juice’, sapping the battery quickly.
The Prowler is one of the higher-quality offerings from ‘huntbike’ specialist Rambo. It’s quiet, it’s stealthy, it’s built to silently stalk through the boonies. Bafang’s 1000W ‘Ultra’ mid-drive motor equips the Prowler with a whopping maximum 160Nm of torque and 1500W of peak power. Most of the Prowler’s components are quality, including the easy-to-use Enviolo CVT (Continuous Variable Transmission) internal hub, which has no steps between gears and provides a 380% range. There are multiple places to attach racks, a trailer, bags, bottle cages and even an extra battery. It’s powerful, but this means the battery can be quickly sapped by over-zealous throttle use. The fork is made by new, fatbike-centric brand GTMRK (details are scarce). Not surprisingly, the Prowler’s feature-laden build comes at a high price.Expert Reviews
0/100 based on 0 rated expert reviewsRambo Prowler Review: Extreme Hunting, Backwoods Electric Mountain Bike
Rambo The Prowler in comparison to averages
3 hours ago
3 hours ago
4 hours ago
