We have read all expert and user reviews on the Rad Power RadTrike. In summary, this is what cyclists think.
15 reasons to buy
- Experts say the RadTrike is stable, with 18” wheels that lower its center of gravity.
- Reviewers say the backrest-equipped saddle is pedal-friendly and places them in a comfortable, upright position.
- With a low standover height, its easy to mount and dismount.
- The RadTrike can carry a 415 lb payload, a 325 lb rider, and 60lb on its rear rack.
- A tester ranged 25-59 miles, from one charge of the 480 Wh battery.
- Testers say the RadTrike’s 750W motor proves powerful on flat terrain.
- Testers say a front mechanical disc & rear coaster brake combine to provide ample stopping power. A parking brake allows riders to park on a slope.
- One reviewer says this one of the most “affordable, quality” e-trikes available.
- Rad Power says the RadTrike fits riders from 4’10” to 6’4”.
- Riders can back-it-up, with an “easy to use” reversing function.
- A tester was able to “do full 360° turns in the width of a sidewalk”.
- Integrated lighting includes an LED headlight and tail/brake light.
- A steel frame allows for small-bump absorption and flexibility on turns.
- The RadTrike folds at the stem to reduce its profile for storage or transport.
- Testers say it fits through household doorways.
- The RadTrike’s top speed is 14 mph.
- A tester notes that 18” wheels transmit vibration when riding over uneven terrain. An owner says the RadTrike provides a “rough ride” on roads and sidewalks.
- With its single-speed drivetrain, a tester finds the RadTrike is hard to pedal from a dead stop. For one tester, the front wheel spun out when taking off on grass.
- An expert notices a lag in motor-assistance, due to the cadence sensor.
- A tester feels that gear range is limited at both lower and higher pedal speeds.
- At 82 lb with a steel frame, the RadTrike is heavy.
- Speed and odometer info is missing from the RadTrike’s display.
- One buyer received their RadTrike with a bent rear axle, another reported small parts breaking easily.
The RadTrike is a small-wheeled, low-speed run-around that impresses reviewers with its eminent stability. One tester said they “...could even take turns at full speed” (14 mph). Experts say its tuned for efficiency, allowing the 480Wh battery to provide ranges of up to 59 miles. It weighs a husky 82 lb but can carry a hefty 415 lb max. payload. Reviewers believe the price is right for a quality e-trike.Expert Reviews
94/100 based on 3 rated expert reviewsRad Power Bikes RadTrike Review, 2023
RadTrike Review:
Testing of Rad Power Bikes Slickly Designed Electric Trike
Rad Power Bikes RadTrike 1 Review
3 Wheels of Power:
Why You Should Consider the Rad Power RadTrike Electric Tricycle
The RadTrike Is Rad Power Bikes’ First Electric Three-Wheeler
— And I Got to Test It Out
Tested: The Rad Power Bikes RadTrike
Rad Power Bikes RadTrike Test Ride: A Fun Electric Tricycle for Adults
Rad Power Bikes’ RadTrike Brings Electric Mobility to More People
Best Tricycle Bikes
Latest Discussions in the Forum
15 hours ago
18 hours ago
Giveaway
14 September – 1 October
