We earn affiliate commission.
Learn more
6 Hours
45 Miles
68 Nm
48V 14Ah
74.2, 73.4, 72.5 lb
We have read all expert and user reviews on the Rad Power Bikes RadRover 6 Plus. In summary, this is what cyclists think. Published Nov 15, 2021 by Owen Jesse.
15 reasons to buy
- A 750-watt hub-driven motor provides the RadRover 6 with 15% more torque than the RadRover 5.
- The RadRover 6 rolls on obese Kenda Juggernaut 26”x4” tires, which are grounded and grippy.
- An adjustable 60mm suspension fork provides the RadRover 6 with comfort on imperfect roads.
- The RadRover 6 features a twist throttle that can be operated independently.
- An 11-34 tooth, 7-speed drivetrain equips the RadRover 6 with ample gear-range on hill climbs.
- The RadRover 6’s streamlined design features a low-profile battery and concealed controller box.
- Integrated front and rear lights power on and off with the RadRover 6.
- The RadRover 6’s hydraulic brakes require minimal effort while offering powerful operation.
- The RadRover 6 comes fitted with phat-ass fenders.
- A tester successfully rode the RadRover 6 across sand.
- The RadRover 6’s packaging was described as ample.
- A number of owners found assembly of the RadRover 6 to be easy.
- The RadRover 6’s suspension fork is adjustable and can be locked-out.
- A one-year warranty covers the RadRover 6.
- The RadRover 6 comes equipped with a bell and kickstand.
13 reasons not to buy
- The RadRover 6 costs 17% more than the RadRover 5.
- The RadRover 6 weighs 4.8 lb more than RadRover 5.
- The RadRover 6’s 60mm suspension fork offers 40mm less travel than the 100mm fork on the RadRover 5.
- In low or bright light, it can be difficult to read the RadRover 6’s left-hand display.
- A reviewer wanted more color choices than the black-only offered on the standard RadRover 6.
- Standard and Step-Thru RadRover 6s are only available in one frame size each.
- One reviewer found the RadRover 6’s sprung fork to be ‘simple’ and weighty.
- The RadRover 6’s 2-amp charger takes 6 hours to reach full charge.
- Reviewers find the RadRover 6’s headlight to be underpowered.
- At 73 to 74 lb, the RadRover 6 is heavy to lift or to ride when the battery goes flat.
- Many RadRover 6 buyers experienced poor communication and response times from Rad Power’s customer service.
- Some buyers who received faulty RadRover 6s, could not ride them for months after purchasing.
- One tester noted that the RadRover 6’s motor continued to deliver power after the rider had stopped pedaling.
On this Class 2 electric fatbike, a 750-watt hub-driven motor offers 15% more torque than that of the RadRover 5. In addition, it comes saddled with ridonkulously phat 4” tires, which add comfort but do slow it down some, up steep hills. The RadRover 6 has been upgraded with hydraulic braking, covered by Nutt, who are a new and relatively unknown brand. Testers said that the Step-Thru version is less stiff and smaller than the standard RadRover. An independent throttle delivers a surge of power that saps the battery swiftly but to a point that makes little impact on short-to-medium distance rides. Under real-world tests, a full battery covers anywhere from 28.47 miles in PAS level 5 to 50.49 miles in PAS 1. RadRover 6 models come in one frame size each, recommended for riders 5’2″ to 6’2″ (on the Step-Thru) and 5’4″ to 6’2″ (on the standard frame).Expert Reviews
87/100 based on 3 scored reviews (14 reviews in total)RadRover 6 Plus Review
Rad Power Bikes RadRover 6 Plus Review 2023
Rad Power Bikes RadRover 6 Plus Fat-Tire E-Bike – Test and Review
RadRover 6 Plus E-bike Launched by Rad Power Bikes With New Battery, Dual Screens, and More
America’s New #1 Selling Ebike? The All-New Radrover 6 Plus
Radrover 6 Plus Trail Test! ($█k Electric Mountain Bike)
Rad Power Bikes RadRover 6 Plus Full Review – The RadRover Fat Tire Ebike Just Got Better
RadRover 6 Plus Hill Climb, Drag Races and First Impressions
RadRover 6 Plus Hill Climb Test | Performance Up a Mountain
Ride Review: Rad Power Bikes’ Rad Rover 6+ Ebike Refines the Design, Doesn’t Forget the Fat Tire Fun
2021 Rad Power RadRover 6 Plus First Ride Review
RadRover 6 Plus Electric Bike Review: Spicing Up Your Daily Commute
The New Rad Power Bikes RadRover 6 Plus Step-Thru
Rad Power Bikes RadRover 6 Plus in comparison to averages
32 minutes ago
8 hours ago
