Puckipuppy Rottweiler
85/100
7.5 Hours
55 Miles
15 mph
90 Nm
48V 15Ah
120 lb
We have read all expert and user reviews on the Puckipuppy Rottweiler. In summary, this is what cyclists think.
13 reasons to buy
  • The Rottweiler comes with a backrest, fenders, two headlights, two taillights with turn signals, and a rear cargo basket.
  • The motor's reverse mode makes it easier to maneuver the Rottweiler.
  • Experts are pleased with the responsive motor’s smooth but “peppy” acceleration.
  • The frame folds to reduce the space needed for storage.
  • The butterfly handlebars allow more varied hand positions and give extra accessory mounting space.
  • The height and position of the seat and backrest are adjustable, and handlebar tilt and height are adjustable.
  • Testers appreciate the top speed of 15mph for safety. This can be lowered further in settings.
  • Reviewers say the 4” fat tires and full suspension effectively cushion the ride.
  • Testers appreciate being able to make sharp turns thanks to the narrow turning radius.
  • The three hydraulic disc brakes deliver good stopping power.
  • The display is large, bright, and easy to read.
  • The Rottweiler has a high payload capacity of 500lb.
  • The 15” step-through frame makes it easy to mount and dismount the Rottweiler.
  • Testers struggle to fold this unwieldy, large, and heavy trike, and lifting it is out of the question.
  • A 295lb reviewer gets just 15 miles of range from the battery.
  • Reviewers say assembly is time-consuming, and the manual misses a couple of instructions.
  • With the seat raised high enough for a 6' reviewer to pedal comfortably, the trike's stability is negatively impacted.
  • Cruise control automatically activates after holding the throttle for five seconds, and there are no settings to change it.
  • A 5’11” tester finds the reach too long, and they say riders at the low end of the stated height range (5’ to 6’2”) probably won't fit.
Puckipuppy's Rottweiler is a folding fat-tire electric tricycle. The highlights for reviewers are its reverse-drive feature and rear suspension. The reverse function and short turning radius add maneuverability on and off the trike. Unfortunately, nothing masks the large size and weight, meaning the folding feature is impractical. The sizing is also inaccurate at both ends of Puckipuppy's range. Otherwise, testers praise the smooth, comfortable ride, deeming the Rottweiler a solid option in the e-tricycle segment.
80/100 based on 3 rated expert reviews
Electric Bike Review
Puckipuppy Rottweiler Review, a Full-Suspension Trike With Reverse!
… the Rottweiler is a capable trike with some genuinely smart features that solve real problems. If you value that reverse function, want full suspension, and can work with the longer reach, it’s worth a look.
E-Biking Today
Puckipuppy Rottweiler Review: Why Everyone Wants This E-Trike!
For older riders, larger riders, or anyone who values stability and comfort, this trike is an excellent option. It’s all about feeling secure, hauling what you need, and enjoying the ride.
The Ride with Lance
Is This E-Trike the Coolest Ride Ever?
I like when you have the seat down. It is a decent cruiser. Once you get your center of weight down lower, it improves the ride much more.
Papa`s Product Reviews
Puckipuppy Rottweiler E-Trike Review | Torque Sensor | Differential | Reverse
I like the cockpit. You really could just put everything on here you wanted. Cornering, I’m not really leaning. I just leaned a little bit. It felt pretty good. I didn’t feel like anything was tipping.
Mike Rochester
I Rode the Puckipuppy Tricycle With Dual Suspension and Reverse Mode – Here’s What Happened
You don’t have to really push down hard on the pedals to keep the tricycle going. When you’re pedaling with this torque sensor, it seems like it gives you a decent amount of assist.
IMBruceECLECTIC
The Puckipuppy Rottweiler… Newly Designed Innovative Electric Trike. Get Out… Live Electric Life!
I don’t have anything bad to say except I wish the battery had more life.
100/100 based on 1 ratings
Puckipuppy Rottweiler in comparison to averages
