We have read all expert and user reviews on the Puckipuppy Beagle. In summary, this is what cyclists think.
- Reviewers find the Beagle comfortable on pavement and light off-road terrain.
- One expert says the responsive motor quickly gets the bike up to speed.
- Testers enjoy how easy it is to ride at high speeds thanks to the cadence sensor and 750W motor.
- The Beagle is available in four colorways, including a camouflage finish.
- A tester is impressed with the traction provided by the 4” tires on sand and light trails.
- The Beagle comes with a headlight, a taillight with brake activation, fenders, and a rear rack.
- The Beagle’s 400lb payload capacity is above average.
- Reviewers find assembly easy, and Puckipuppy provides the required tools.
11 reasons not to buy
- The Beagle is a large, heavy bike.
- Tests show the unbranded mechanical disc brakes are weak, and one reviewer says they're noisy.
- A tester finds the pedal assist acceleration underwhelming.
- A 255lb reviewer says the suspension fork is soft.
- The wide saddle causes discomfort while pedaling, according to a reviewer.
- The Beagle is rated for 5'4" to 6'6", but a 5’9” tester with a 30” inseam can't stand over the top tube due to the 32.7" standover height.
- A reviewer has difficulty seeing the display in sunlight.
- The basic 2A charger means long charging times.
- The instructions for installing the headlight and front fender are incorrect.
- When unlocked, the Beagle exceeds both pedal assist and throttle speed limits, making it illegal in most jurisdictions.
- Puckipuppy's customer reviews are manipulated and untrustworthy.
The Puckipuppy Beagle is a fat-tire e-bike with a suspension fork, 750W motor, and 720Wh battery. Reviewers praise the ride comfort, ability to cruise at high speeds, responsive motor, and grippy tires. However, the Beagle is a large and heavy e-bike, and the high standover height means it won’t suit riders under 5’9”. Additionally, the mechanical disc brakes are weak, the suspension fork is too soft, and the wide saddle makes pedaling uncomfortable. Overall, the Beagle fails to stand out in a competitive fat-tire e-bike segment.Expert Reviews
81/100 based on 2 rated expert reviewsUnveiling the Secrets of Puckipuppy Beagle Test Drive
Puckipuppy Beagle E-Bike Review: Good for Commuting and Off-Roading
Trail Testing the Puckipuppy Beagle! Way Better Than I Expected!
Great E-Bike for Beginners: The Puckipuppy Beagle
17 hours ago
3 days ago
