Küat Sherpa 2.0 vs Küat NV 2.0
Küat Sherpa 2.0
93/100
Specifications
Specifications
Küat Sherpa 2.0
Küat NV 2.0
Rack Type
Hitch, Vehicle
Hitch, E-Bike Compatible
Küat
Küat
Maximum Load Capacity
2 Bikes
2 Bikes, 3 Bikes, 4 Bikes
Maximum Weight Per Bike
40 lb
60, 50, 40 lb
Vehicle Type
Hatchback, Minivan, Sedan, SUV, Truck
Hatchback, Minivan, Sedan, SUV, Truck, Van
32, 35 lb
52, 89, 111 lb
Material
Aluminum, Steel
Powder-Coated Aluminum, Plastic
Küat Sherpa 2.0
We have read all expert and user reviews on the Küat Sherpa 2.0. In summary, this is what cyclists think.
  • Buyers feel the Sherpa 2.0 is “a fine piece of engineering” and worth the price.
  • Owners agree the Sherpa 2.0 is easy to install and remove.
  • The Sherpa 2.0 can tilt forward, allowing easier trunk access when bikes are mounted.
  • The rack's relatively low weight means it's easy to install without a second person. Multiple seniors highlight this as a key benefit.
  • Owners appreciate that the Sherpa 2.0 “doesn’t wobble” while driving.
  • Reviewers appreciate the aesthetics and color options.
  • This rack folds for tidier storage.
  • Küat offers a range of accessories to enhance functionality, including wall storage and a pivoting arm.
9 reasons not to buy
  • The rack is only for paved roads. Küat says it cannot be used on “unpaved surfaces.”
  • Experts and owners say the tilt latch is “a pain” to reach.
  • The rubber on the ratchet arm gets “chewed up” with use. Some owners report it detaching.
  • The rack may block license plates and backup cameras on certain vehicles.
  • Multiple owners say their exhaust melted the plastic ratchet arm positioned close to it.
  • Owners must buy an adaptor to transport bikes with wheels between 20” and 24.”
  • One expert demonstrates that bikes can easily fall inward and damage the trunk upon lifting the ratchet arm, as it's positioned on the outside. Users must constantly hold the mounted bikes to prevent this.
  • Küat only uses 20 different locks for the hitch lock on all units sold, so the possibility of theft is higher.
  • Küat warns that the Sherpa 2.0 is not compatible with all RVs.
The Küat Sherpa 2.0 is a platform hitch rack available for 1.25” or 2” hitches. Experts and reviewers praise the stability, sleek design, low weight, and ease of use. Potential buyers should consider license plate visibility and the distance to their vehicle’s exhaust pipe. Complaint center around the plastic ratchet arm that wears quickly and allows the bikes to fall inward once lifted. While it’s not designed for driving off-road, those in need of a stable, lightweight hitch rack for general transportation of bikes under 40lb find it worth the considerable price.
Küat NV 2.0
We have read all expert and user reviews on the Küat NV 2.0. In summary, this is what cyclists think.
  • This rack comes in two versions: the NV 2.0 (with a work stand) and the NV 2.0 Base (no work stand).
  • Long-term testers of up to five years deem the rack durable.
  • Bikes remain stable during transit, according to reviewers.
  • Testers say the rack is secure, with no sway or wobble while driving.
  • Experts agree that loading and unloading bikes is easy.
  • The NV 2.0 tilts to give access to the vehicle's rear when bikes are loaded. The lever used for tilting is also used to fold the rack up when not in use.
  • Küat provides a lifetime warranty for the NV 2.0
  • A fat tire adapter kit is included with this rack.
  • Reviewers and buyers say assembly is tedious and time-consuming, suggesting it’s a two-person job.
  • The trays can't be adjusted horizontally, so avoiding bike-on-bike contact can be tricky.
  • The heavy three and four-bike versions (89lb, 111lb) are poorly suited to users who frequently remove their racks.
  • The NV 2.0 isn't compatible with bikes that have fenders.
  • This rack isn’t rated for use on RVs.
Küat's NV 2.0 is a platform hitch rack available with a work stand (NV 2.0) or without (NV Base 2.0). This rack is available in two, three, and four-bike versions. The two and three-bike NV 2.0s are compatible with add-ons for carrying up to four bikes. This rack supports 50" wheelbases, 5" tires, and 20" to 29" wheels, but fenders won't fit. Experts praise the build quality, ease of use, and durability. However, assembly can be tedious, and bike-on-bike contact is an issue for some. Overall, the Küat NV 2.0 is deemed a high-quality, versatile rack worthy of its price.
Küat Sherpa 2.0
Compared to other bike racks
Küat NV 2.0
Küat Sherpa 2.0
Comparison to averages
Küat NV 2.0
