Is the Tuttio Soleil01 Street Legal?
Many riders consider purchasing electric dirt bikes like Tuttio’s Soleil01 with the hope of using them on the road as urban runabouts, as well as for off-road riding.
All motor-powered vehicles that don’t meet the legal definition of a bicycle are subject to specific requirements for use on public roads.
The exact requirements vary depending on the jurisdiction, but they typically include Deparement of Transport-approved and correctly installed safety equipment, vehicle registration, and insurance. The driver must also be licensed and above a certain minimum age to drive the vehicle on the road.
Keep reading to find out what it takes to make an electric dirt bike street legal.
The short answer is no. As sold by Tuttio, the Soleil01 is not street legal and it cannot be ridden on any public road, trail, or path. It can only be ridden on private land, and because it doesn’t have pedals, it doesn’t meet any electric bicycle classification.
What It Takes to Make an Electric Dirt Bike Street Legal
Making an electric dirt bike like the Tuttio Soleil01 legal for the street is no small undertaking, as you’re about to find out.
The specific requirements of each state varies, and the regulations can change. We encourage you to carefully read your state’s legislation if you plan to make your electric dirt bike street legal. The following table shows some of the requirements for 10 states. This information may not be up to date, so do your own research before going ahead with the conversion process.
| State | VIN Inspection Required | Proof of Ownership | Registration Required | Insurance Required | Safety Accessories | M-1 License Required |
| New York | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet | 10 kW |
| California | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet (under 21s) | 4 hp (3 kW) or 30 mph |
| Texas | No | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet | 11 kW |
| Oregon | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet | 5 kW or 30mph |
| Florida | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet (under 21s) | 5 kW or 30mph |
| Louisiana | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet | 5 kW or 30mph |
| Nevada | Yes | Yes | Yes | Yes | 2 Mirrors, Lights, Turn Signals, Helmet | 5kW |
| Illinois | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals | 7 kW or 30mph |
| Georgia | Yes | Yes | Yes | Yes | Lights, Turn Signals, Helmet | 5 kW |
| Pennsylvania | Yes | Yes | Yes | Yes | 1 Mirror, Lights, Turn Signals, Helmet (under 21s) | 5 kW or 30mph |
Motorcycle or Motor Driven Cycle?
Firstly, it’s important to understand that there are two motorcycle categories, and their legal requirements differ slightly. The National Highway Traffic Safety Administration (NHTSA) considers a motorcycle “a motor vehicle with motive power having a seat or saddle for the use of the rider and designed to travel on not more than three wheels in contact with ground.”
A ‘motor driven cycle’ is a motorcycle but with “5-brake horsepower or less” (3728.5 watts). The Soleil01 falls into this category. Therefore, in some states, a motorcycle rider’s license isn’t necessary; a regular driver’s license is sufficient. However, in California, for example, a motorcycle license is needed for any motor-driven cycle that exceeds 2982.8W or 30mph. So, the Soleil01’s 37mph top speed means riders would need a full M-1 drivers license.
Remember, all states have a minumum age requirement for driving motorized vehicles. This can be as low as 14 years but more typically is around 15.5 or 16 years.
Safety Accessories and Tires
For use on the public roads, an electric dirt bike must be equipped with safety accessories, including front and rear lights with a rear brake light, front and rear turn signals, a horn, and at least one mirror in most states. Additionally, the rider usually must wear a helmet with the appropriate eye covering at all times.
All of this equipment must be approved by the Department of Transport (DOT). The accessories must be installed in accordance with relevant guidelines to ensure their proper functioning. For example, in order for the lights to be approved in an inspection, they must be the correct color, minimum brightness, and angle, and have the correct flashing pattern.
Stock dirt bike tires are also not suitable for the road, and they must be swapped out with DOT-approved tires for use on paved surfaces. Inappropriate tires will be flagged at a VIN Inspection, and insurers may refuse a claim if the bike is found to have inappropriate tires.
Vehicle Identification Number
To convert an electric dirt bike into a street-legal vehicle, most states require a Vehicle Identification Number (VIN) which requires taking the vehicle, with all of the approved safety accessories listed above, to a VIN Inspection center. Before they issue a VIN, the inspectors will want to confirm that every modification was done correctly.
Vehicle Insurance
Standard third-party vehicle insurance is required in order to ride a converted electric dirt bike on the road. Providers may charge extra to insure a modified vehicle or refuse to insure the vehicle if the modifications aren’t done to their requirements.
Registration at the DMV
All motor vehicles must be registered at the Department of Motor Vehicles and carry a license plate issued by the DMV. Proof of ownership, identification, vehicle insurance, and a fee are required to complete this process. Registration at the DMV may also require an inspection of the vehicle, including cerifications for any modifications.
Cost Considerations and Conclusion
As you’ve probably guessed by now, converting an electric dirt bike to be fully street legal is not only time-consuming, but also quite costly. And, going through all this rigmarole doesn’t even guarantee that the bike will be approved by all the necessary government bodies for use on the road.
With all that said, unless you’re a passionate tinkerer with lots of time on your hands, you’re probably best off just buying either a proper electric bike or an actual moped for use around the city.
