We have read all expert and user reviews on the Ibis HD6. In summary, this is what cyclists think.
14 reasons to buy
- The HD6 is available in seven builds, all featuring FOX's top-of-the-line Float X2 Factory rear shock. All builds use the top-tier FOX FLOAT 38 Factory fork, except the Deore, which uses the still-impressive FOX FLOAT 38 Performance.
- Experts enjoy the agile handling produced by the mullet wheel setup and short chainstays.
- Weighing around 31–34lb, depending on the build, the HD6 is considered light compared to other enduros.
- Reviewers relish the efficient climbing provided by the impressive traction and support.
- Testers say the short rear end makes lifting the front wheel, popping off ledges, and jumping effortless.
- Experts find the HD6 comes alive descending at high speeds, remaining controlled but lively.
- Reviewers savor how the DW-link suspension platform eats small and big hits without hindering pace.
- Testers find the HD6 easier to pedal on flatter terrain than similar bikes.
- Experts enjoy the precise steering through tight, techy trails.
- According to reviewers, the HD6 powers into and out of corners with momentum.
- Testers appreciate the balance of stiffness and compliance in the frame and suspension.
- Reviewers praise how this bike plows over anything, thanks to the monstrous 180mm front travel and 29” wheel.
- The frame can accommodate a 190mm fork, a coil shock, and a 2.5” tire.
- Ibis covers the frame, pivot bushings, and Ibis-branded rims and handlebar with a lifetime warranty for the original owner.
9 reasons not to buy
- Some reviewers feel the short chainstays and low, long-travel front end reduce stability on the steepest descents.
- The HD6 is only available with MX wheels and offers no geometry adjustment.
- A tester feels the XL frame's long reach and short 435mm chainstays cause the rear wheel to break away in hectic moments.
- Experts say the big difference in travel between the fork and rear suspension makes it hard to set the bike up so it feels balanced. One notes that using the Ibis setup guide yields a too-soft, under-damped suspension.
- A reviewer complains that the pricey, optional Ibis S35 Carbon rims lose spoke tension too quickly.
- Testers lament the front wheel wander caused by the rear weight bias.
- Two testers experience pedal strikes due to the low bottom bracket.
- Experts on the size 3 (extra medium) wish the 185mm dropper post had more travel.
- Two reviewers had to have a fork or shock rebuilt by FOX under warranty.
The Ibis HD6 is an enduro bike with 180mm front and 165mm rear travel. It comes in seven builds, all with MX wheels only. The HD6’s low weight, climbing ability, and playfulness impress for a long-travel enduro. Downhill, the HD6 is composed, thanks to its supportive suspension platform, and maintains speed and precision. However, the geometry can contribute to instability on the steepest descents, the chainstays are too short on the larger frames, and the rear weight bias causes the front wheel to wander. The HD6 is generally deemed a race-worthy rig, with the modest builds offering the greatest value.Expert Reviews
81/100 based on 3 rated expert reviewsIbis HD6 XT Review | Enduro Bike of the Year Contender
Ibis HD6 Ride Review and Impressions (Can It Handle Hardline?)
Field Test Review: 2024 Ibis HD6 – Sporty and Smashy
Ibis HD6
Ibis HD6 Long-Term Review—Hard-Hitting Enduro Perfection
Ibis HD6 Review- I Didn’t Change Anything!
2024 Ibis HD6 Test Ride & Review
Ibis HD6 GX AXS– In Our Big 2024 Enduro Comparison Test
Long Term Review 2023 Ibis HD6
Ibis Cycles HD6 First Ride Impressions
Ibis HD6 in Review: The Purple Loamer Bear [German]
An Enduro Rawhide of Dimensions [Norwegian]
Best Mountain Bikes
3 hours ago
2 days ago
