Eahora Juliet Pro II
70/100
8.5, 10 Hours
110, 220 Miles
34, 43 mph
1500 W, 4400 W
120, 190 Nm
52V 60Ah, 60V 70Ah
116, 168 lb
We have read all expert and user reviews on the Eahora Juliet Pro II. In summary, this is what cyclists think.
  • Eahora offers this bike in two builds: Juliet II (1,500W motor, 3,120Wh battery) and Juliet Pro II (two 2,200W motors, 4,200Wh battery).
  • Both versions of the Juliet II handle steep inclines with ease.
  • This bike comes with a rear rack, fenders, a headlight, and a taillight with brake activation.
  • The 7A charger makes for quick charging times.
  • Given the bike’s powerful acceleration, an expert appreciates the safety feature that requires pulling in brake levers to activate the throttle after a minute of inactivity.
  • Pro II riders can easily switch between motors, and the all-wheel drive setting has low and high-power modes.
  • The display has a USB-C port to charge devices on the go.
  • The Juliet II's range impresses reviewers, though none does a full range test.
11 reasons not to buy
  • A tester says the throttle acceleration is overpowering at takeoff with the default settings, and pedal assist is jerky even regardless of the settings.
  • The motor power and unlocked top speed greatly exceed legal e-bike limits.
  • At 116lb and 168lb, both builds are very heavy, and an expert weighs the Juliet Pro II at 20lb heavier than Eahora's claim.
  • Testers find the pedals can scrape over bumps or in turns.
  • With a 32.3” minimum saddle height, this bike is unlikely to fit riders at the lower end of the stated height range (5’4” to 6’1”).
  • A tester of the Pro II says the rear suspension is squeaky.
  • One tester reports ghost pedaling at 20mph.
  • A reviewer complains of frequent tire punctures.
  • The display on one test bike occasionally fails to power on, especially in cold weather.
  • The taillight is dim, and the brake light is hard to see in daylight, according to a reviewer.
  • An expert finds the manual confusing and poorly written.
The Eahora Juliet II is a fat-tire e-bike available in a single or dual-motor build (Pro II). Both the motor and unlocked top speed exceed e-bike limits. Testers relish the high speed, climbing ability, and battery capacities, but none test the full range. High weight, jerky pedal assist, meager pedal clearance, puncture-prone tires, and cheap suspension count against the Juliet II. Eahora also overstates the height range and lists a wildly inaccurate weight for the Juliet Pro II. Overall, reviewers struggle to see the bike’s appeal.
74/100 based on 1 rated expert review
74
Ready Set Drone
Eahora Juliet Pro II E-Bike: Watch This Video if You Are Considering This E-Bike
It’s very fast, it’s very powerful, it’s an advanced e-bike that you really wouldn’t want to start off with as your first e-bike.
Terry Owens
Eahora Juliet II (Upgraded) Blatantly Honest Review | Maintenance Issues
So far, I’ve covered just over 100 miles, and for the most part, I have no complaints.
eBike Explorer Milo
2024 Newest Juliet II 1500W 52V 60Ah E-Bike
For the price it’s at, yeah, you get the power, you get the range, you get a nice back rack…
#510 Best Electric Bike
Bottom 10%
#279 Best Fat Tire Bike
Bottom 10%
#3 Best Eahora Bike
Bottom 30%
#913 Best of All Bikes
Bottom 10%
Eahora Juliet Pro II in comparison to averages
