We earn affiliate commission.
Learn more
Type
22.15 lb
We have read all expert and user reviews on the Diamondback Haanjo 5C EXP. In summary, this is what cyclists think.
25 reasons to buy
- A hallmark of this rig is its versatility; as a bikepacker, commuter & gravel bike.
- Experienced tourers made good use of the 5C EXP’s front and rear rack eyelets.
- Unloaded, this bike was fast and nimble on gravel.
- The 27-speed drivetrain offers 571% range for steep, loaded climbs and fast flats.
- At a total weight of less than 22 pounds, this rig is incredibly lightweight.
- Deore components were of high quality.
- Off-road riders found the 5C EXP very comfortable with wide, low-pressure tires.
- Several users reported excellent customer service from the manufacturer.
- Buyers described excellent, safe and secure packaging with no damage to the bike.
- The 5C EXP screamed value and was significantly cheaper than the competition.
- 5C EXPs performed well saddled with large loads, as tested with 45lbs of cargo.
- Numerous buyers found it easy to assemble, even with little bike experience.
- Low-rider mounts on the fork provide multiple touring rack options.
- Mudproofing is ensured, withh fender eyelets on the frame and fork.
- A 73mm threaded bottom-bracket shell accepts MTB bottom-brackets and cranks.
- Internal cabling like this was usually seen on more expensive options.
- Barcon bar-end shifters were durable and didn’t interfere with front packs.
- On-road, an owner likened it to a classic Reynolds 531 steel road bike.
- The 5C EXP’s performance impressed on forest roads, singletrack, gravel and roads.
- This rig proved comfortable on long rides, loaded down with kit.
- 21mm HED Tomcat tubeless rims provided ample room for 2.1” wide tires.
- Bikepackers and tourers appreciated understated natural tones in olive or brown.
- Unloaded, the EXP 5C was a thrill-ride on rugged singletrack.
- Flared, 46mm wide DB X-Durance Gravel drop bars were lauded for their comfort.
- The stock DB Eldorado saddle received no complaints, even after epic rides.
- Some riders would have liked hydraulic brakes, especially when loaded up.
- Bar-end shifters made it difficult to change gears while braking.
- 27.5 x 2.1” Schwalbe Smart Sam tires were noisy on pavement.
- To run tubeless, a reviewer felt that an immediate tire-swap was necessary.
- Variations in reach-length were limited across 5C EXP size options.
- The front wheel’s 12mm thru-axle wouldn’t accept standard 15mm MTB wheels.
- An owner noticed the EXP 5C’s low bottom-bracket could lead to some pedal-strike.
This is an intrepid bike. The manufacturers shirked current fashions to create an uncompromising off-road touring and bikepacking rig. With the massive spread of gears available from the 3x9 (27-speed) drivetrain, riders reported being able to continually pedal up steep dirt climbs while their riding companions had to walk their own bikes. Weighing in at 19.15lbs with a move to tubular wheels and tires, one cyclocross expert saw the 5C EXP as perfectly suited to cyclocross or gravel racing. Commuters were also delighted with its performance. With an all-carbon frame and bar-end shifters, modernity meets durability in this high-value and wildly versatile adventure bike.Expert Reviews
100/100 based on 1 rated expert reviewDiamondBack Haanjo EXP Adventure Bike Review
Bike to Splitboard to Fly Fish – Wasatch Mountains Adventure!
Bike Review: Diamondback’s Haanjo EXP Carbon Adventure / Touring Bike
Tested: Diamondback Haanjo EXP Carbon
Review: Diamondback Haanjo EXP Carbon…
Why You Should Think About a Road Bike With Mountain Tires
Best Bikepacking Bikes
Bikepacking bikes with the highest BikeRide Scores
Diamondback Haanjo 5C EXP in comparison to averages
16 hours ago
17 hours ago
17 hours ago
