We have read all expert and user reviews on the Canfield Lithium. In summary, this is what cyclists think.
- Canfield states that the aluminum Lithium weighs 33lb, which is lighter than many high-end carbon competitors.
- An expert calls the Lithium versatile, with the stability for tough enduro and the agility for XC trails.
- Reviewers say the relatively short 430mm chainstays increase maneuverability in tight corners and help with maintaining traction through technical sections.
- One tester likes that the upright riding position helps with keeping forward momentum through technical sections.
- An expert finds the rear wheel stays planted when riding over rocks and roots on downhills.
- The balanced geometry inspires confidence on both descents and climbs, says a tester.
- Reviewers praise the Lithium's pedaling efficiency, citing Canfields proprietary multi-link suspension platform that isn't sag dependent.
- An expert says the short cranks (155mm to 170mm) help with avoiding pedal strikes.
- The frame has internally routed cabling, a threaded bottom bracket, chain guide mounts, and clearance for 2.5” tires.
4 reasons not to buy
- The decreased stability from the short rear end hinders speed on the gnarliest downhill courses, laments one tester.
- The Öhlins TTX2 Air rear shock is not as progressive for jumps and drops as experts would like.
- A tester dislikes the position of the bottle cage mounts on the underside of the down tube.
- One expert complains that the 12-speed TRP Evo drivetrain isn't smooth or consistent, and the chain breaks on the second ride.
The Canfield Lithium is a full-suspension enduro bike with 29" wheels. It comes in three mid-tier builds. Testing is limited, but the bike earns praise the efficient pedaling for climbs and the ability to handle rough, technical descents. Experts find the balanced geometry and planted rear wheel inspire confidence on downhills, and the short chainstays provide great maneuverability. The trade-off for this agility is a reduction in stability and speed on the toughest downhill tracks. The TRP drivetrain's quality is also questioned. Overall, testers consider the Canfield Lithium a solid enduro option.Expert Reviews
88/100 based on 2 rated expert reviewsCanfield Lithium Review
Review: Canfield Lithium
Best Enduro Bikes
21 hours ago
21 hours ago
