Burchda RX80
78/100
7 Hours
65 Miles
30 mph
85 Nm
48V 20Ah
74.8 lb
We have read all expert and user reviews on the Burchda RX80. In summary, this is what cyclists think.
7 reasons to buy
  • The RX80 comes with a headlight, taillight, fenders, a rear rack rated for 150lb, side mirrors, and a phone mount.
  • Owners get 30 to 45 miles of range in real-world testing.
  • The RX80 has an above-average payload capacity of 400lb.
  • Testers relish the RX80’s unrestricted top speed of 29-30mph using the throttle.
  • The angle-adjustable stem allows quick modifications to fit.
  • Buyers appreciate the responsive customer support.
  • The color display includes a USB-C port to charge devices on the go.
13 reasons not to buy
  • Testers complain of a two-second delay to both throttle and pedal assist activation.
  • Burchda markets this bike for off-road, but experts find the ride rough over light off-road terrain.
  • The hydraulic disc brakes and small 160mm rotors deliver weak stopping power.
  • Reviewers find it difficult to maneuver the RX80, citing a heavy front end and a wide turning radius due to the dual-crown fork.
  • Experts find the “cheap” tires loud and lacking in grip. One tester says the front tire bead popped off when inflating it above 20psi.
  • A 5’9” reviewer feels the claimed height range of 5’6” to 6’5” is exaggerated at the low end.
  • The saddle-mounted taillight is externally powered, lacks brake activation, and can be obstructed by cargo on the rear rack.
  • Testers and owners report issues like vibration from the motor and rattling fenders.
  • The throttle’s 29mph top speed exceeds the 20mph legal e-bike limit.
  • Owners and experts say the rear shock is stiff and does little to absorb bumps.
  • The low IPX4 water resistance means the RX80 shouldn't be ridden in heavy rain.
  • A tester and multiple owners complain of the gears jumping.
  • Buyers find the instruction manual severely lacking in detail.
The Burchda RX80 has a solid range and decent accessories for the price, but those are its only highlights. The list of cons is seemingly endless. Lagging power delivery, weak brakes, “lethargic” handling, underwhelming climbing ability, and low-quality tires are among the most notable drawbacks. Additionally, the rear suspension is stiff, and despite being marketed for off-road, the bike is uncomfortable over light off-road terrain. Problems like handlebar motor vibration and a tire bead popping off raise more doubts over build quality. With all these issues, experts recommend avoiding Burchda's RX80.
71/100 based on 3 rated expert reviews
HeroesNStuff
Best Cheap Fast E-Bike With Full Suspension? 2024 Burchda RX80 Electric Bike (E-Bike) Review 29mph
I think it’s a decent bike for the price… fresh out the box, on a scale from 1 to 10, I give this bike a 7.8.
MrCentralDriver
Burchda RX80 – Looks Expensive but It’s Affordable!
There’s tons of bikes that are a little bit more expensive than this, and I think that are probably worth buying over this one.
This E-Bike “Used to Be Cheap” but I Would Not Recommend It in 2025 – Burchda RX80 Review
Overall, you know, I think the bike is a pretty decent value for the money…
Eric Hernandez
Is It Any Good!? | Burchda RX80 Full Suspension Fat Tire E-Bike Review
Overall, if you happen to be looking for a fat tire full suspension e-bike with a good amount of range on it, this one here is definitely a good option to look at.
Fire and Ice Outdoor Gear
RX80 Bike Review: Full Suspension E-Bike With Major Flaws – Honest Unboxing! | fireandiceoutdoor.net
I’ve had a bad experience putting this together, headlight doesn’t work, I can’t ride it, so I don’t recommend this bike.
MobiliTest
Burchda RX80 – Full Review of the Nearly Perfect 1000W Fat Bike [French]
I also really liked its value for money.
FUNKFIEBER
Burchda RX80 E-Fatbike: Review and Mods [German]
I wanted a robust everyday bike, and the Burchda RX80 definitely solves this problem.
81/100 based on 99 ratings
    64%
    11%
    6%
    4%
    15%
#434 Best Electric Bike
Bottom 20%
#230 Best Fat Tire Bike
Bottom 30%
#2 Best Burchda Bike
Top 40%
#790 Best of All Bikes
Bottom 20%
Burchda RX80 in comparison to averages
