We have read all expert and user reviews on the Burchda HC26 AWD. In summary, this is what cyclists think.
7 reasons to buy
- The HC26 AWD comes with a headlight, fenders, a color display with a USB-C port, and a rear rack with a stated 150lb capacity.
- Riders can choose between three settings: front-wheel drive, rear-wheel drive, or dual-motor mode.
- This bike easily overcomes steep gradients in dual-motor mode.
- A tester is impressed with the bike’s traction over sand in dual-motor mode.
- The HC26 AWD arrives mostly assembled.
- A 300lb tester gets around 50 miles of range per charge when using both motors and primarily riding in PAS 3.
- The HC26 AWD’s payload capacity of 399lb is above average.
13 reasons not to buy
- The large HC26 AWD is only suitable for taller riders with its height range of 5’8” to 6’9”.
- Burchda says the bike comes with 180mm brake rotors, but a test bike arrives with a 160mm front rotor.
- The non-adjustable rear shock is too stiff for a 300lb rider, and the fork only has compression adjustment.
- The large 30Ah battery takes a lengthy 10 hours to charge with the 3A charger.
- The included taillight is externally powered.
- At 101.4lb, the HC26 AWD is extremely heavy.
- An expert warns that the brakes lack stopping power.
- The front motor and high weight result in “sluggish” steering, according to an expert.
- One reviewer struggles to mount the rear rack because the hole is misaligned by a quarter of an inch.
- A tester says removing the heavy battery takes a lot of effort.
- The HC26 AWD doesn't have bottle cage mounts.
- The dual-crown fork creates a large turning radius.
- One reviewer complains the aggressive acceleration “launches” the rider.
The Burchda HC26 AWD is a dual-motor fat-tire e-bike. The combined 1,750W of power propels this bike up steep climbs and over sand, but the fast acceleration may overwhelm beginners. While the 1,440Wh battery provides good range, it's very heavy, as is the bike overall, which contributes to slow steering and makes riding without assistance impossible. The cheap basic components are expected at this price, but the lack of comfort is disappointing. All in all, the HC26 AWD fails to impress, though competing dual-motor e-bikes don't perform much better.Expert Reviews
70/100 based on 2 rated expert reviewsI Tested an “Affordable” Dual Motor E-Bike – Burchda HC26 Review
Burchda HC26 AWD Review Pros and Cons
18 hours ago
2 days ago
