We earn affiliate commission.
Learn more
Type
6, 7 Hours
65 Miles
20, 25, 28 mph
48V 17.5Ah
73 lb
We have read all expert and user reviews on the Addmotor M-430. In summary, this is what cyclists think.
22 reasons to buy
- The M-430 is designed to fit shorter riders, from 5’2” up to 6’0”.
- With a small frame and wheels, the M-430 is a good size for younger riders.
- The M-430’s step-through frame avails it to less-flexible and older riders.
- A 750 watt hub motor supplies plenty of power in urban settings.
- Addmotor says the M-430 can be unlocked to reach a 28 mph top speed.
- Gigantic 4”-wide tires allow riders to traverse snow, sand, grass and dirt.
- Addmotor says the M-430 can travel 65 miles on a single charge.
- The M-430 features 5 levels of pedal assist, to supplement a 7-speed drivetrain.
- Braking duties are covered by Tektro mechanical disc brakes with 180 mm rotors.
- Motor inhibitors cut power on braking, reducing stopping distance on the M-430.
- The M-430 features an integrated headlight and brake light.
- A highly-adjustable stem makes the M-430 suited to a range of rider heights.
- An 80 mm suspension fork helps to alleviate vibration on uneven surfaces.
- Including rider and cargo, the M-430 can handle a total payload of 300 lb.
- An owner says they “easily assembled” the M-430 in 1½ hours.
- There are 6 color options available to M-430 buyers.
- A USB port is available to attach accessories, on the M-430’s display.
- The M-430’s battery is removable for security and off-bike charging.
- Bolts in the bike’s headtube provide a sturdy mount for a front basket.
- The M-430 comes fitted with a sturdy and handy rear rack.
- Addmotor equip the M-430 with full fenders, front and back.
- The M-430 has a wide and comfortable saddle.
3 reasons not to buy
- At 73 lb, a tester says many owners will be unable to carry the M-430.
- The Addmotor M-430 is only available in one size.
- A reviewer says the M-430’s step-through frame could be lower and more accessible.
The Addmotor M-430 is a smaller-wheeled, smaller-framed e-bike with a laid-back ride-style and geometry. Testers are impressed by the acceleration and power offered. It’s equipped with 24” wheels and fat 4”-wide tires. Paired with an 80 mm suspension fork, this allows the M-430 to travel across a range of surfaces, in comfort. It uses a 750W motor and can be configured as a Class 2 e-bike reaching 20 mph or Class 3 at a top speed of 28 mph. One tester reached a top speed of 25 mph. A reviewer considers 33 miles to be a realistic range estimate, while Addmotor say 65 miles is possible, in PAS 1.Expert Reviews
78/100 based on 2 rated expert reviewsAddmotor M-430 Review: Beautiful 28 MPH Fat-Tire Step-Thru Electric Bike
Addmotor M-430 E-Bike Review: A Surprisingly Powerful and Easy-to-Ride Fat-Tire Electric Cruiser Bike
Bob and His Wife on an Addmotor M-430 Cruiser E-Bike and an M-5500 E-Bike
Addmotor M-430 in comparison to averages
6 hours ago
9 hours ago
