We earn affiliate commission.
Learn more
Type
53.0, 50 lb
We have read all expert and user reviews on the IZIP Tristar. In summary, this is what cyclists think.
- The Sturmey Archer 3-speed drivetrain shifts easily, even while stationary.
- Owners report that rear coaster and front V-brakes operate well.
- The Tristar’s hefty construction struck riders as sturdy and solid.
- A resilient metal fender is included for the front tire.
- The included chainguard keeps clothing grease-free.
- A thumb-operated parking lock is incorporated into the rear brake lever.
- ‘Metal-flake brown’ was described as a ‘rich’ color.
- The IZIP Comfort Tractor saddle is wide, large and comfortable for planted butts.
- Some reviewers found it easy to climb with the provided gear range.
- Pro Palm grips are ergonomic for maximum comfort.
- The provided basket carries at least 45lb worth of shopping, laundry or pets.
- One reviewer felt that smaller wheels offered greater stability.
- Some riders felt that the Tristar lacked traction on unsealed surfaces.
- For several riders, climbing was hard work.
- At nearly 60lbs, including an 8.5lb steel cargo crate, the Tristar is a dumpy rig.
- Assembly was not difficult but was time-consuming and somewhat involved.
- Small wheels delivered a bumpy ride and didn’t aid acceleration.
- Sometimes, pre-assembly was lacking; with rusty headsets, bottom brackets, warped bearing washers, scratches, sharp edges to the basket...
- In a couple of situations, screw threads were shot and needed re-threading.
This tricycle performed very well at moderate speeds on flat ground and gentle inclines. Owners found it perfect for running errands, shopping trips, laundry jaunts or toting the dog to the park. It’s a chunky machine, though. And this means that some riders, especially those of senior years, found it a struggle to get up real hills. Also, some buyers received dud specimens once and even a second time, before the manufacturer delivered a damage and flaw-free example. Once a clean rig was assembled, owners were pleased with a practical and casual workhorse.Expert Reviews
0/100 based on 0 rated expert reviewsBest Tricycles
Tricycles with the highest BikeRide Scores
IZIP Tristar in comparison to averages
8 hours ago
2 days ago
