View all prices
Show fewer prices
26.39, 24.87 lb
We have read all expert and user reviews on the Trek CheckOUT. In summary, this is what cyclists think. Published Oct 06, 2025 by Jordan Grimes.
15 reasons to buy
- Trek offers the CheckOUT in two builds: SL 5 (Shimano GRX, alu rims) and SL 7 AXS (SRAM Force, carbon rims).
- All experts praise the ride quality, comfortably traversing washboard descents, rocky singletrack, and rough gravel.
- The “forgiving” handling on descents impresses a tester.
- A reviewer commends the CheckOUT’s ability to "eat up miles" over varied terrains.
- Testers love how the "forgiving" handling boosts confidence compared to the rigid gravel bikes they’ve tested.
- One expert enjoys how this bike’s ample gearing and ability to maintain traction enhance its capacity for steep off-road climbs.
- A reviewer says the RockShox Judy XL 60mm fork performs well over a variety of gravel tracks.
- One tester commends the Bontrager GR bar as the most comfortable “hyper-flared” bar they’ve used.
- The frame and fork have clearance for 2.2”/56mm tires.
- The Bontrager tires offer good grip on muddy, leaf-strewn singletrack.
- The CheckOUT frame's wide and versatile range of mounting points accommodates varied bikepacking setups.
- The down tube mounts can be moved to suit different setups.
- The CheckOUT has a suspension-optimized rear rack with three-pack mounts and a 22lb load capacity.
- Cables can be routed through the head tube, down tube, or externally.
- In partnership with Topo Designs, Trek offers a bespoke frame bag for sizes M-L.
- The suspension components and linkage, and the pivoting rear rack's bearings will all require regular servicing, and complicate maintenance, especially on bikepacking trips in remote areas.
- The CheckOUT’s relatively heavy weight makes its presence known on climbs.
- One tester says the CheckOUT responds poorly to hard efforts with the suspension locked out.
- This bike lacks remote suspension lockout.
- One expert gravel racer thinks the "excessive" 12cm handlebar flare feels weird.
Trek's CheckOUT is the first full-suspension gravel bike to appear since Niner launched the segment with its MCR 9 RDO, which ultimately failed but may simply have been ahead of its time. Early testing is positive, with experts calling the CheckOUT a “delightful” ride that could be the ultimate adventure bike. The CheckOUT comfortably eats up miles at speed over varied terrains, but is overkill for those who mostly ride smooth gravel. Overall, it’s hard to say if, on long-distance adventures, the CheckOUT’s comfort and versatility make up for the weight and inevitable maintenance overhead of its mechanical complexity.Expert Reviews
88/100 based on 3 scored reviewsTrek CheckOUT Full Suspension Gravel Bike Review: When the Meme Becomes Fact
Is It Gravel, Mountain, or Something Else? Trek’s CheckOUT Refuses to Be Categorized
Gravel or Mountain Bike? Trek CheckOUT Full Suspension for €7000 — Revolution or Marketing Bluff? [French]
Best Gravel And Adventure Bikes
Gravel and adventure bikes with the highest BikeRide Scores
Trek CheckOUT in comparison to averages
2 hours ago
