We have read all expert and user reviews on the Feedback Sports Velo Wall Post. In summary, this is what cyclists think.
- Owners and testers relish this rack's space efficiency, whether keeping a bike up and out of the way or folding against the wall while not being used.
- Experts praise the Velo Wall Post’s robust build. An owner says it remains “sturdy” after four years of use.
- Reviewers and buyers say installation is easy, though installation requires additional tools including a drill and ⅛” drill bit.
- Because the storage beam holds the bike under the saddle, there's zero frame contact. Testers and buyers note that the design supports a wider range of bike styles than other horizontal mounts.
- Buyers applaud how easy it is to load bikes on and off this rack.
- Owners say bikes hang securely on the rubber strips on the beam arm.
- A tester easily loads a mountain bike on the rack, and appreciates that it doesn’t interfere with the brake hoses.
- Experts and owners highlight the beam’s versatile storage possibilities, using it for wheels and other gear, as long as the total weight doesn't exceed 50lb.
3 reasons not to buy
- Installation involves drilling holes into walls and being able to locate hidden wall studs or use alternative fixings to mount the rack to cinder blocks.
- Feedback Sports says the rack holds e-bikes, but relatively few e-bikes weigh less than this rack's 50lb limit.
- Though one expert appreciates the ability to hang an MTB with a 760mm handlebar on this rack, the beam protrudes 15.625" from the wall, so bikes with bigger bars may not fit.
The Feedback Sports Velo Wall Post is a wall-mount storage solution for one bike up to 50lb. The rack's space efficiency and robust build win praise. Owners and testers appreciate the easy installation, although extra tools and drilling are required. Owners say bikes are easily loaded and remain secure on the rack. Because bikes hang from their saddles, there is no frame contact. The rack accommodates a wide range of bike styles, but most e-bikes will exceed the rack's weight limit. Overall, experts feel the sturdy Feedback Sports Velo Wall Post is a highly functional and affordable bike storage solution.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
90/100 based on 2 rated expert reviewsFeedback Sports Velo Wall Post
Review: Feedback Sports Velo Wall Post – Minimalist, Folding, Wall-Mounted Bicycle Rack
Velo Wall Post Bicycle Storage Rack by Feedback Sports Product Review
Best Bike Garage And Storage Racks
Bike Rack Comparison
3 hours ago
2 days ago
