We have read all expert and user reviews on the Feedback Sports Velo Column. In summary, this is what cyclists think.
5 reasons to buy
- Installing the Velo Column doesn't require drilling.
- Buyers say the stand is easy to assemble and install.
- Most owners report no issues, saying the stand is stable and holds bikes securely.
- The cradle arms are height-adjustable.
- Feedback Sports offers an optional accessory for installing the Velo Column to an exposed ceiling beam.
3 reasons not to buy
- Two owners report the stand failing, which causes damage to bikes and walls. This could be due to the spring losing tension over time.
- Some full-suspension mountain bikes may not fit.
- Several say the cradle arms are stiff and difficult to move up and down on the pole.
The Feedback Sports Velo Column is a drill-free storage solution for two bikes up to 40 lbs each. It fits ceilings from 7 to 10 feet high and has adjustable cradles that accommodate most frame shapes. Optional cradles can be purchased for holding up to four bikes. Installation is straightforward, and the column is generally secure. However, to prevent potential slips—sometimes linked to loss of spring tension—owners should periodically check the tension. Overall, the expert-approved Feedback Sports Velo Column is deemed a solid storage option that doesn't require permanent fixtures.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
80/100 based on 1 rated expert reviewFeedback Sports Velo Column Storage Review
CT Recommends: Best Indoor Bike Storage Solutions
Best Bike Garage And Storage Racks
Bike Rack Comparison
13 hours ago
2 days ago
