We have read all expert and user reviews on the BMC URS 01. In summary, this is what cyclists think.
- The URS 01 comes in two builds, both SRAM AXS: ONE (Force/X0, carbon rims), and TWO (Rival/GX, alloy rims).
- The 10mm of micro suspension in the rear adds suppleness to the ride quality without feeling bouncy. The elastomer can be swapped to suit different riders.
- The Redshift ShockStop suspension stem does a “great job” of smoothing out rough pavement and less-technical singletrack.
- Experts rave about how comfortable the URS 01 is, with one calling it among the most comfortable bikes they’ve tested.
- The URS 01 has multiple accessory mounts, an integrated and removable seat tube accessory strap, and a down tube storage compartment.
- Experts praise the stability and confident handling at high speeds and over rough terrain.
- Testers highlight the flawless shifting of the URS 01 ONE’s X0/Force drivetrain.
- The 10-52t cassette is ideal for bikepacking and tackling steep off-road sections.
- One expert dislikes the suspension stem’s behaviour on more aggressive trails, saying the front end is less predictable and more difficult to lift over roots.
- A reviewer says the suspension stem's movement leads to some instability during hard efforts and when climbing.
- 47mm tire clearance is disappointing for an adventure gravel bike.
- An expert finds that the low bottom bracket results in more frequent pedal strikes over “techy” sections.
- Two reviewers complain that their legs rub on the accessory strap mount, even with the strap removed.
- The stem and bars on one test bike need to be replaced because the bars were slipping while riding.
On paper, the URS 01’s Gravel+ geometry and front and rear micro suspension make it the perfect tool to tackle the “rowdy,” as BMC claims. Experts give the bike top marks for comfort over long days in the saddle, and the low, slack geometry inspires confidence. However, the suspension stem hinders control in certain situations, and the underwhelming 47mm tire clearance doesn’t match the bike’s otherwise forward-thinking design. What could be a hugely capable machine is further hampered by a too-low bottom bracket. If comfort is the priority, the URS 01 is a top choice. If not, better options may exist.Expert Reviews
84/100 based on 2 rated expert reviewsBMC URS: Modern Gravel Bike With a Retro Twist
New BMC URS Suspension Gravel Bikes Tested
First Ride: The BMC URS Doubles Down on Being a Drop Bar XC Bike
Best Gravel And Adventure Bikes
14 hours ago
2 days ago
