We earn affiliate commission.
Learn more
17.3 lb
We have read all expert and user reviews on the Alchemy Ronin Carbon. In summary, this is what cyclists think.
24 reasons to buy
- Testers report that the Ronin performs capably as both a gravel and a road bike.
- The Ronin’s carbon frame is hand-built to be lightweight and compliant.
- At 17.3 lb, the Carbon Ronin does not carry any excess weight.
- The Ronin Carbon’s tubing is subtly tapered, to enhance ride quality.
- By all reports, the Ronin tackles rutted roads with poise.
- A tester contends that the Ronin Carbon is good value, even at this premium price.
- The Ronin Carbon is available in one Shimano GRX and three SRAM eTap builds.
- Alchemy’s carbon wheelset is light, fast and accelerates quickly.
- On builds with electronic drivetrains, the Ronin avoids messy gearing cables.
- Testers say the Ronin Carbon handles confidently on loose surfaces.
- The Ronin Carbon is described as being “stiff and responsive”.
- One tester says the Ronin Carbon excels on longer, fast rides.
- A tester feels that the Ronin Carbon suits short bikepacking jaunts.
- The carbon Ronin is available in four distinct colorways.
- Alchemy can build your Ronin to custom geometry and color specifications.
- All Ronin builds feature wheels using Industry Nine / Alchemy carbon rims.
- Clearance allows for a maximum tire size of 700 c x 45 c.
- The Ronin’s Carbon frame is kit out with three sets of bottle mounts.
- Eyelets are provided for fenders, on the Ronin’s Carbon frame.
- Top-tube mounts are provided, to attach a bento box to the Ronin Carbon.
- Reviewers appreciated the carbon Ronin’s “clean lines”.
- A short headtube contributes to a racy ride position on the Ronin.
- The Alchemy Ronin is made, built and designed in the United States.
- There are 4 color schemes available, each clear-coated to reveal the Ronin’s underlying carbon construction.
- One reviewer would appreciate a 2x drivetrain option on the Ronin Carbon.
- A tester feels that the Ronin Carbon can be fatiguing on longer rides.
- The Ronin Carbon has limited mounting points to carry cargo.
- Given the bike’s high quality, the Carbon Ronin’s starting price is not low.
- The Carbon Ronin’s maximum tire width is limited to 700 c x 45 mm.
At least one tester sees the Carbon Ronin as a versatile option to fulfill your road, cyclocross and gravel-biking duties, while also being worthy of short backpacking trips. This is a lightweight and precision machine, built with a handmade attention to detail. Handling, performance, shifting and componentry are all lauded. Accordingly, the entry-point price is quite high. While one tester says the Ronin Carbon feels “planted” and well-suited to longer rides, another found distance rides could be “fatiguing”. There are no mounts on the fork or for a rear rack, though there are top-tube bolts for a bento box. Builds start from a svelte 17.3 lb. Excelsior!Expert Reviews
99/100 based on 2 rated expert reviewsAlchemy Ronin
The Best Gravel Bikes of 2021 – Alchemy Ronin
Best Gravel And Adventure Bikes
Gravel and adventure bikes with the highest BikeRide Scores
Alchemy Ronin Carbon in comparison to averages
11 hours ago
1 day ago
1 day ago
