We have read all expert and user reviews on the Rad Power RadRover 6 Plus Step-Thru. In summary, this is what cyclists think.
15 reasons to buy
- A 750-watt hub-driven motor provides the RadRover Step-Thru with 15% more torque than the RadRover 5.
- The RadRover 6 Step-Thru rolls on obese Kenda Juggernaut 26”x4” tires, which are grounded and grippy.
- An adjustable 60mm suspension fork provides the RadRover 6 Step-Thru with comfort on imperfect roads.
- The RadRover 6 Step-Thru’s hydraulic brakes require minimal effort while offering powerful operation.
- The RadRover 6 Step-Thru features a twist throttle that can be operated independently.
- The RadRover 6 Step-Thru’s streamlined design features a low-profile battery and concealed controller box.
- An 11-34 tooth, 7-speed drivetrain equips the RadRover 6 Step-Thru with ample gear-range on hill climbs.
- The RadRover 6 Step-Thru comes fitted with phat-ass fenders.
- The RadRover 6 Step-Thru’s suspension fork is adjustable and can be locked-out.
- Integrated front and rear lights power on and off with the RadRover 6 Step-Thru.
- The RadRover 6 Step-Thru comes equipped with a bell and kickstand.
- A tester successfully rode their RadRover 6 through sand.
- The packaging on RadRover 6 models is described as ample.
- A number of owners found assembly of the RadRover 6 Step-Thru to be easy.
- The RadRover 6 Step-Thru is supplied with Rad Power’s one-year warranty.
12 reasons not to buy
- The RadRover 6 Step-Thru costs 17% more than the RadRover 5.
- The RadRover 6 Step-Thru weighs 3.1lbs more than RadRover 5.
- The RadRover 6 Step-Thru’s 60mm suspension fork offers 40mm less travel than the 100mm fork on the RadRover 5.
- In low or bright light, it can be difficult to read the RadRover 6 Step-Thru’s left-hand display.
- The RadRover 6 Step-Thru is only available in one frame size.
- One reviewer found the RadRover 6 Step-Thru’s sprung fork to be ‘simple’ and weighty.
- The RadRover 6 Step-Thru’s 2-amp charger takes 6 hours to reach full charge.
- A reviewer finds the headlight on RadRover 6 models to be underpowered.
- At 72.5 lb, the RadRover 6 Step-Thru is heavy to lift or to ride with a flat battery.
- Buyers of RadRover 6 models experienced poor communication and response times from Rad Power’s customer service.
- Some buyers who received faulty RadRover 6 models, could not ride them for months after purchasing.
- A tester notes that the motor on RadRover 6 models continues to deliver power after the rider has stopped pedaling.
On the RadRover Step-Thru Class 2 electric fatbike, a 750-watt hub-driven motor offers 15% more torque than that of the RadRover 5. In addition, it comes saddled with ridonkulously phat 4” tires, which do slow it down some up steep hills. By way of upgrades, the RadRover 6 Step-Thru is specced with hydraulic brakes by Nutt, who are a new and relatively unknown brand. Testers said that the Step-Thru version is less stiff and smaller than the standard RadRover. An independent throttle delivers a surge of power that saps the battery swiftly but to a point that makes little impact on short-to-medium distance rides. Under real-world tests, one reviewer achieved max ranges anywhere from 28.47 miles in PAS level 5 to 50.49 miles in PAS 1. The RadRover 6 Step-Thru is available in one frame size, recommended for riders 5’2″ to 6’2″ in height.Expert Reviews
94/100 based on 1 rated expert reviewRad Power Bikes RadRover 6 Plus Step-Through Review 2023
Rad Power Bikes RadRover 6 Plus Step-Thru Review
RadRover 6 Plus E-bike Launched by Rad Power Bikes With New Battery, Dual Screens, and More
Rad Power Bikes RadRover 6 Plus Full Review – The RadRover Fat Tire Ebike Just Got Better
America’s New #1 Selling Ebike? The All-New Radrover 6 Plus
Radrover 6 Plus Trail Test! ($█k Electric Mountain Bike)
RadRover 6 Plus Hill Climb, Drag Races and First Impressions
RadRover 6 Plus Hill Climb Test | Performance Up a Mountain
2021 Rad Power RadRover 6 Plus First Ride Review
The New Rad Power Bikes RadRover 6 Plus Step-Thru
Ride Review: Rad Power Bikes’ Rad Rover 6+ Ebike Refines the Design, Doesn’t Forget the Fat Tire Fun
RadRover 6 Plus Electric Bike Review: Spicing Up Your Daily Commute
12 hours ago
12 hours ago
21 hours ago
Giveaway
700c KENT retro bike24 March – 7 April
